Like Tree9Likes
Old 08-08-2012, 10:33 PM
  #38176
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Biggie85 View Post
I dunno, I ran it hard twice tonight for 6 and 8 minutes. Never shut off or bogged out. Ill run it until i have a problem with it, then I'll switch it out.
Also, looked this up. The Pro4 4600kv motor at maximum burst is around 126-130 amps. Hobbywing ESC has a max burst of 380 amp.
Yeah don't worry about it. My friend ran the 80 amp in his sc10 4x4 and a tenshock sc401 4600 motor. Believe me the tenshock 4600 pulls just as many or more amps than a pro-4 motor. He ran it fine no issues.
Rockthecatbox21 is offline
Old 08-08-2012, 10:34 PM
  #38177
Mxer59's Avatar
Trader Rating: 114 (100%+)
I know the 4 pole motors are awsome I use to run Tekin Rx8 4600 pro4. I'm getting back into hobby and running 4x4 again. What's some takes on maybe running Sc4x 4.5 so it's easier on batteries or perhaps a 4000kv run good?
Mxer59 is offline
Old 08-08-2012, 10:44 PM
  #38178
Originally Posted by Suteki View Post
So what batteries is everyone running in their scte?
I am using both Gens Ace 5000/50c and 5300/65c with a RX8/4600 and haven't puffed one of the 6 batteries I rotate between me and my sons XXX-SCT. And several times I have run them to cutoff, although I try not to make it a habit as my motor is scorching hot by then.
tonyxcom is offline
Old 08-08-2012, 11:02 PM
  #38179
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by justpoet View Post
I just took a drill to the chassis and put lots of holes in it to lighten it. I managed to get down to about 4 lbs after drilling almost every part. It is really hard to drill out the center of drive shafts, getting straight enough of a shot is just annoying.
Then I got to figuring that if I just need to remove material, I should make parts thinner too. So I got out a file and took the chassis to half thickness, I even got to smooth out the bottom from all the 8th scale rocks I'd been hitting.
After also cutting out holes for most of the body, I was still able to put on a big wing in the back and some air splitters up front to come in at just under 4lbs.
Oh, and don't forget the most important part, carbon fibre pistons. Weight savings and more responsiveness due to meshing with the oil and emulsifying the carbon into the silicon to make the oil even lighter too!
Pics or it never happened Dave!!
suby723 is offline
Old 08-09-2012, 05:35 AM
  #38180
teamlosi906's Avatar
Trader Rating: 235 (100%+)
Post
teamlosi906 is offline
Old 08-09-2012, 06:16 AM
  #38181
will g's Avatar
Trader Rating: 132 (100%+)
Does anyone know about how far the servo saver should be tightened up from bottom ?
will g is offline
Old 08-09-2012, 06:27 AM
  #38182
HighLife420's Avatar
Trader Rating: 49 (100%+)
I tighten mine pretty much all the way and backed off a turn. If you have a good metal gear servo, you can tighten it most of the way. I locktite the bottom piece too, so it doesnt loosen over time.
HighLife420 is offline
Old 08-09-2012, 07:13 AM
  #38183
will g's Avatar
i will be running now a jr 9100s .. was running a hitec 5996tg thnx Will G
will g is offline
Old 08-09-2012, 07:15 AM
  #38184
Youre ok then, ive been using the same servo for over a year and the only issue ive ever had was it coming loose after a few months. Locktite solved that.
Old 08-09-2012, 07:31 AM
  #38185
will g's Avatar
i would assume at this tightness its no longer a servo saver it moves very little ?
will g is offline
Old 08-09-2012, 07:34 AM
  #38186
louperez4's Avatar
Default newest setup sheet
does anybody know a link to the newest update setup sheet
louperez4 is offline
Old 08-09-2012, 07:41 AM
  #38187
Yep, pretty much. Metal gear servos are pretty strong, havent had one go on me yet.
Old 08-09-2012, 07:52 AM
  #38188
will g's Avatar
i will tighted alittle softer than that and give it a try ... thanks for the help ... i wondered why i went thru few servo savers already prob too loose LOL
will g is offline
Old 08-09-2012, 07:56 AM
  #38189
Np
Old 08-09-2012, 08:20 AM
  #38190
Originally Posted by ChrisAttebery View Post
I used the stock shafts for over a year and never had one come loose. The setscrews were not loose. The point looked like about 75% of the cup tip was in contact with the pinion. I'm wondering if the setscrews were a little too soft and the points pounded out.
I've been active in RC since the early 80's. I'm 99.9% sure it wasn't an installation error.
Thanks Chris, that the screws are a little soft makes sense. Both times this happened to me the setscrew looked to be in their proper place. I'll keep a closer eye on them.
Stevemopa is offline
