Like Tree9Likes
Old 08-07-2012, 02:53 PM
  #38101
Cackswayn's Avatar
Trader Rating: 16 (100%+)
Originally Posted by empire39
my scte is traction rolling on hi grip surface like our indoor clay track. im at 27.5wt shock oil front and rear with the losi gold springs. i have the ride height pretty dang low and put some more camber in it, feels like the camber helps but starts to effect my steering a bit. any ideas??
Bigger sway bars.
Cackswayn is offline
Old 08-07-2012, 02:57 PM
  #38102
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Cackswayn
Bigger sway bars.
+1 i have the same problem but i think it's cuz i'm overdriving it. (taking corners to sharp to fast).
Rockthecatbox21 is offline
Old 08-07-2012, 02:58 PM
  #38103
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
I need more mah than 6600 nanos , any suggestions and where to buy them? I was easy on the throttle but i limped in after a ten min main only to lose 2nd place by a half second and was 6 seconds behind 1st due to conserving lol
BDRMBULLY is offline
Old 08-07-2012, 02:59 PM
  #38104
Bigger sway bars.
you wouldnt happen to have a part# would ya? i just have the stock 1's that come with the truck
empire39 is offline
Old 08-07-2012, 03:35 PM
  #38105
jhautz's Avatar
Trader Rating: 86 (100%+)
So.... I have had my SCTE sitting on the shelf for the last 6 mo. while focusing on other classes. But I am gonna break it out again this week and get her tuned up for some racing. What did I miss as far as hot tweeks and setups.
The last time I payed any attention the TLR tuning kit was just about to launch. and there was talk of what chassis was better. BCE, KH, bump or the tlr. lol. So... Which chassis won? . (doesn't matter I'm happy w my BCE)
What I am interested in is if there are any "new" must have options or setups.
I suppose I could go back and read a couple hundered pages but Ill never find the time to actually do that. Whatever happened to saladfork updating he first page of this thread??? I don't see anything new on there.
Thanks in advance.
jhautz is offline
Old 08-07-2012, 04:01 PM
  #38106
Casper's Avatar
Trader Rating: 34 (100%+)
Thanks in advance.
New dunford std setup.
http://www.losi.com/ProdInfo/Files/L...ford-02_12.pdf
New diff gears were release. (same part number just updated).
Not much more then that.
Chassis--- Stick around we just got done arguing about screws so the great chassis debate is due for another go around!
Casper is offline
Old 08-07-2012, 04:24 PM
  #38107
chucko's Avatar
Pro match 6800 mah. it works for me and gets me 12 hard running spinning tire wins..try one and see
promatch.com
chucko is offline
Old 08-07-2012, 04:28 PM
  #38108
jhautz's Avatar
Thanks Casper. So whats the deal with the new gears? I never had any issues with the diffs except needing Chris pins and glueing the inserts and the HD outdrives and the hardened shims and blocks from chris as well, the HPI 2mm hex diff screws and.... Come to think of it I think the diff cups and the gears were the only stock parts left in the diff. Lol. Any plans for new diff cups?
Seriuosly though. Are the gears just a durability upgrade? I wouldn't think a performance gain. I still have a few sets of the old gears NIP i hoarded back during the great gear shortage after the truck first launched and everyone was chewing them up because of the soft cross pins.
Yea. The stock screws are chitty. Just get a set of Tonys and forget about it.
Any and for a TLR version of this truck yet? I think it's about time. Make it come with all the goodies already installed
jhautz is offline
Old 08-07-2012, 04:34 PM
  #38109
Default Xteme Carbon Chassis
I just got my new chassis, do I have to seal edges of chassis? Does anybody know.
Rich68 is offline
Old 08-07-2012, 04:45 PM
  #38110
BDRMBULLY's Avatar
promatch.com
Couldnt find 6800 pro match just intellects, i mainly buy from stormers or a main other than my lhs
  #38111
chucko's Avatar
it wouldnt hurt
chucko is offline
Old 08-07-2012, 04:50 PM
  #38112
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Which motor and ESC are you running? Are you spinning the tires everywhere?
For reference I get about 400mA/minute with my Pro4/RX8.
ChrisAttebery is offline
Old 08-07-2012, 04:53 PM
  #38113
BDRMBULLY's Avatar
Rx8 n 4600 with 13 tooth n yea i spin the wheels here n there , losing the habbit but cant help to drift around certain lines at my track lol running throttle profile 1 seems to generate more heat than 3 as i just tried 1 but will go back to 3
Old 08-07-2012, 05:06 PM
  #38114
will g's Avatar
Trader Rating: 132 (100%+)
i have noticed i have gone thru few too many servo savers ... they work good for about 2 weekends and then start sticking ... they look good from what i can see ... but ive tighted and loosed it up and seems to stick .. now from what i can see the tube the saver goes around has some scratches on it , that would cause it to stick i would assume so i will need a new one ? i posted pic below ... i thought maybe too much torque from servo, im using a hitec 5996tg 180 oz @ .10 secs
will g is offline
Old 08-07-2012, 05:11 PM
  #38115
GeorgePravata's Avatar
Trader Rating: 172 (100%+)
My nephew and I just got back from the SC. Nats. @ rcmadness My nephew ran a Losi scte with Tekin RX8 Revtech 3800 revtech 65x65 batteries and geared 15/40. won his main and did the bump up I just changed the the battery he ran for a full 12mins. plus check in. Nothing happen to the RX8 and nothing happen to the motor. And was just as fast. we are very happy with the rx8 and rev tech set up
GeorgePravata is offline
