Well i have owned this truck for a long time and replaced the diff fluid many times, i bought another truck and just did the diffs and the front diff is binding. Not sure why, I know how to build the diffs and seat everything properly but when I tighten it down it still locks up. I got sick of trying to figure it out and just used two gasgets. Figure its just the diff housing that is out. Known problem?
May help and be sure not to snug up the screws tite at all!!!Cheers!
Thanks guys. Guess the stock ones are not very durable. Any recommendations on chassis? I'm not trying to start a chassis war. After reading the thread the KH stands out to me as it changes the front drive shaft angle. But I am open on anyone. Might be able to pick up a TLR slightly used cheap from a friend.
Also, should I swamp chassis before running? Will the changed angle hurt anything if I race tonight before swapping chassis?
I pushed them down all the way with a small hex, Rebuilt the rear fine. But the front is giving me some issues, doubled up the gasget and it works fine. Could the diff housing be out?
Ya it could be ,have you put it in the truck ?Hold the rear wheels aon the ground and give it some gas and let the front seat in some it may just break it self in ,Is it stopping or just feels twitchy?Twitchy break in and run, stopping def, re do!
Somehow these snuck by - I haven't seen any posts about the Louise wheels for SCTE. If anyone has them, thoughts?
Come in white, yellow, or black:
http://www.louiserc.com/products_det...cID=17&Key=115
I can't wait for the new 22SCT wheels.
I bought 6 pairs of the Avid wheels and they seem really soft at the face as almost all of them wobble at the face. AKA wheels are much better in that regard even though they have loose hexes.
It's stopping completely, I'm going to give it one more shot! Hopefully it will work this time. I'm going to drain the fluid and rebuild from scratch!
if and not knowing what ya did. but if you get any glue on the inserts you have done it bad. 2 gaskets fixes it. glue the inserts in when fully installed. other wise you have that 1000th of an inch of glue thats messing you up. Hope this helps
It could be that, the truck is literally brand new, i have not even put electronics in it. I took it out of the box and stripped it down. to do the diffs. Could it be their binding cause there BRAND new?
Just taking a roll call of any and all SCTE drivers running the BCE chassis...
I have enjoyed the performance out of the one on my truck.
Just got done installing my ha pivotballs and new rod ends. The fit is alot better and there is a lot less slack. Set my steering turnbuckles at 45mm to give it just a slight toe out. The suspension action is a lot smoother now too. Also did the socket head screw and washer on the motor mount like you guys suggested. Will see how it all works out on race day.
