Like Tree9Likes
Old 07-31-2012, 04:32 PM
  #37816
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Originally Posted by Rockthecatbox21
Yeah mine was making a grinding noise. Filled it all the way and now it sounds great. Just top it off and wipe away the excess and you're good to go.
If your gna tear into it you should probably clean it out propperly so it will last longer and feel much smoother ?;@) dont be lazy lol
BDRMBULLY is offline
Old 07-31-2012, 04:33 PM
  #37817
Okay, mine is feeling mildly gritty. Preventative maintenance never hurt, right?
Racer X8000 is offline
Old 07-31-2012, 05:00 PM
  #37818
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Anytime i get my diff out I clean it. I even do the bearings for good measure. On a side note, have any of you guys used the rcmonster motor mount. My stock keeps coming off the slide. If it comes out when i put the socket head screw and washer, i'll be looking into the rcmonster mount.
Rockthecatbox21 is offline
Old 07-31-2012, 05:07 PM
  #37819
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
His products are usually decent , I have an RC Monster conversion on an RC8 and everything is top notch .
IF you can get it though the Elite RC mount is the way too go IMO , its very beefy and holds the motor nice and tight . I run them on 3 different RC's cause I like it so much .
http://elitercd.com/
BashemSmashem is offline
Old 07-31-2012, 05:39 PM
  #37820
Yeah i've heard good things about elite rc motor mounts on the conversion threads. I just didn't know the ten-x mount was for the scte. I agree rcmonster makes a good product, but for motor mounts elite rc is the way to go.
Old 07-31-2012, 05:43 PM
  #37821
BDRMBULLY's Avatar
Elite is great but i cant use an 11 tooth pinion on it and a 12 just barely meshes but at least it never slips
Old 07-31-2012, 05:46 PM
  #37822
It's all right for me. I only run a 13t right now. Like i said if the washer/socket head screw you guys linked me to doesnt work, i'll be picking up an elite motor mount.
Old 07-31-2012, 06:00 PM
  #37823
Quick question for any of you guys that run the APE battery tray.Where are you finding the truck handles best with the battery tray all the way back,all the way forward,etc,etc.Just havent had the time to experiment.
Losi57 is offline
Old 07-31-2012, 06:22 PM
  #37824
Default Titanium Axles
A company named SMP has come out with titanium axles.
http://www.offroadrc.net/news/2012/3...es-by-smp.html
Lunsford has the Shock Standoffs now also
http://www.lunsfordracing.com/mm5/me...Code=TRUC-LTEN
oldschoolnewb is offline
Old 07-31-2012, 06:46 PM
  #37825
TCCustoms's Avatar
well..ordered my TLR Tuning kit locally but he cant get KHz stuff so i'll pry be putting in my order to amain and getting the KH chassis and the dual bearing center diff mount. Im goin with king headz due to the angle they put the center diff on to easy tension in the driveline
I went with the tuning kit even tho i wont need all the parts so i'll be selling the towers, shock caps, collars and stand offs if anyone is looking for that stuff
TCCustoms is offline
Old 07-31-2012, 07:37 PM
  #37826
I use mine one hole short of all the way back. Does that make sense?
If we numbered the holes 1, 2, 3, 4 and 1 was all the way forward and 4 was all the way back, I am on number 3.
My truck is just under 6lbs RTR so your results may vary. But that is the way I have installed it and haven't felt the need to move it.
tonyxcom is offline
Old 07-31-2012, 08:45 PM
  #37827
chucko's Avatar
this is what I did it help keep the nose up .. try it ..
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-7-10-2012-003.jpg
chucko is offline
Old 07-31-2012, 10:37 PM
  #37828
myl3s91's Avatar
Originally Posted by Team T2C
it will go back up once they start the chatter about the TLR 22SCTE Kit!
what would a 22 scte be? 22 Stands for 2 wheel drive 2 motor configuration...If tlr sells this truck, it will probably be the same truck in a tlr box, possibly with the kit installed. But i doubt it as they just released the nitro version through tlr and it is bone stock just like arr.
myl3s91 is offline
Old 07-31-2012, 11:44 PM
  #37829
So if thats right, the 4wd version shoud be called 41 because 4wd + 1 motor configuration. Though the more ear friendly 44 sounds more likely.
Old 08-01-2012, 03:06 AM
  #37830
Has anyone installed the losing adjustable hinge pin set ? Any info on what this part tries to achieve ?
There is front and back set is both necessary?
muzzytt is offline
