I'm guessing that's for turning reasons? Anyway after hearing that i think i'll leave the rear stock and go to black up front. The front is way too undersprung.
diffs
I'm sure that this has been brought up, and I'm sorry for that, but what have people done to stop the diffs from leaking? I rebuilt a diff, raced 1 full night, and rechecked, and it was 1/2 full
thanks for any help
thanks for any help
Ca can be tricky to get it right the first time. Try using some rtv silicone or some permatex high-tack gasket sealant. The gasket sealant works great and requires no drying like the rtv does. It won't effect oils in your diff either. Ran 3-4 races so far with no leakage. The center diff doesn't really leak much at all without doing anything to the inserts.
Tuning spring rates
Front Rear
3.6 green 2.7 red
3.9 blue 3.0 orange
4.2 black 3.3 silver
4.5 purple 3.6 green
Stock springs are 4.3 front 3.3 rear
Front Rear
3.6 green 2.7 red
3.9 blue 3.0 orange
Thanks guys, and I know exactly setup all depends on track conditions etc, but are there any general rules to follow when the truck is lighter apart from keep trying?
I am not competing in races, so am not looking for a winning formula, Just learning to tune the truck and fix the wallowing, which I can see is less than ideal.
Thanks all!
And thanks to the person who PM'd me some hints. Much appreciated.
Thanks all!
Thanks all!
Thanks all!
MIP Bypass setup and body question
Hello everyone, has anyone tried the MIP bypass shock setup ? If their system works like a full size off road shock this should bring a new tuning option to the RC world. I read a couple days ago people talking about running +3 mm offset rims, what bodies are you running to get those wider rims under the body when the suspension compresses ? I have some and wind up with the outer treads of the tires ripped off from them rubbed the edge of the body, I just bought a new JC Raptor body and have the same problem. It's just not wide enough for these + offset rims I have. I raised the body up and that didn't seem to help all that much. That extra width does wonders for this truck at the track I run at. High speed high bite sweeping turns. Thanks for any info.
Thanks for the hints on shock oil weight.
how is the box stock setup? The shocks seem way to stiff, is it normal to run them that way? All new to the truck so bear with me. I have read the truck is on the heavier side, I have a novak 550 4.5. That enough motor? Also what is the lowest mah lipo to make the truck finish 10 min race?
well...got the nano's the other day! So took the molex charging plugs that came with my duratrax 245 and desoldered the bullets and used those bullets on the plugs that came with the batts so i have charging plugs w/o spending more on the bullets since i would never use the molex anyways! Here's a pic of them charging up and i only got to run 1 yesterday and with punch still down to 2 the wires got warm but battery never warm like the gens ace did! Seems to be good but need to get out to the track and run...
Hi All,
Since suspension seems to be the topic of the day, please could someone advise me on the following?
I have done some weight reduction on my truck (lightened outdrives (F/C/R), swiss cheese battery tray, and a new BCE chassis (write up coming during the week) and noticed that my truck is not as settled on the bumps anymore - seems to be wallowing a bit or taking a while to settle again.
I have the stock springs front and rear.
Could the problems be due to it now been oversprung / under-dampened?
Also are the racing black front springs and racing orange rear springs softer or harder than stock?
What would you suggest to settle the truck down?
Thanks!
Thanks!
my shocks are #2 pistons all around
32.5 front 1/4 rebound, black aftermarket spring
30 wt rear 1/4 rebound, stock rear spring
stock swaybars
and ive been TQ'ing and winning the last few weeks at my local outdoor track
