Like Tree9Likes
Old 07-27-2012, 05:29 PM
  #37681
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by chucko View Post
I.m getting ready to do a marathon with my SCTE... I have in it now a rx8 and 4600.. I don't want to toast these running for 4 hrs.. what would a good in-expensive motor and speed control that would last 4 hrs of hard running.. I have 9 6800 Pro match 2 cells... so batteries aren't the issue. or should I buy another 4600 and rx8 Thanks ? or maybe a 38 and go 3's ?? any Ideas with out starting a motor war. Please post part numbers if you got em Thanks
Ill sell you my viper copper head 5150 combo with pro guage for 165 shipped used for 2 heats then put my rx8 n 4600 back in
BDRMBULLY is offline
Old 07-27-2012, 05:48 PM
  #37682
chucko's Avatar
not being a smarty but Y aren't you running the copperhead ? I have been reading here on this thread that its a good unit. I was almost thinking about the hobby wing set ups on 2's maybe. I am so confused.. LOL
chucko is offline
Old 07-27-2012, 06:09 PM
  #37683
Trader Rating: 19 (100%+)
I hated the viper combo. I have been running hw sct pro/tenshock 4600 and couldnt b happier
nitro0619 is offline
Old 07-27-2012, 06:14 PM
  #37684
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Hey Nitro what are you running as far as drag punch etc on your esc i got the same set up?
BlackStarRacing is offline
Old 07-27-2012, 06:35 PM
  #37685
justpoet's Avatar
Trader Rating: 16 (100%+)
I don't know that I've hit 4 hours straight, but I've done a couple hours straight a few times during practice by cycling through 6600 turnigy's until LVC. I run an RX8/4600 13t, no timing, no drag brake, 65% current limit, AE heat sink on motor (and airflow through the body). Normal temps after a full pack (or several) are 130ish in 85 ambient or 135ish in 95+ ambient for the Pro4, RX8 below 115 even with the higher ambient, and battery about 105 after a hard full pack.
For reference, here's the heat sink I use (held on with some double sided thermal tape so it won't slide around during hard hits):
ASC3928
As long as you make sure your bearings are good all around, I'd think you'd be fine with a setup like that and not kill your existing electronics.
For further setup reference, I run the common 5/5/3 diff oil setup and my truck is not lightened (CF towers but tbone rear and rpm front bumpers).
justpoet is offline
Old 07-27-2012, 06:54 PM
  #37686
BDRMBULLY's Avatar
I just installed it while my rx8 was in for repair
Old 07-27-2012, 07:56 PM
  #37687
DanielHolloway's Avatar
Originally Posted by AbsolutAdikt7 View Post
its not hurting anything is it? its ok to do that?
Yeah man, perfectly fine. Every unsensored motor will do that. Nothing at all to be afraid of. Now go run the wheels off of it. Just make sure you tighten your wheel nuts or you will run the wheels off. Literally!
Have fun with it!
DanielHolloway is offline
Old 07-27-2012, 09:19 PM
  #37688
Trader Rating: 47 (100%+)
Default tie rods
Originally Posted by Casper View Post
I think some have done that. The 8ight2.0 titanium tie rod kit works on this truck which is what most of use use and then upgrade to the HA balls and you have a great setup.
Could you link the set you are referring to here? Is it a direct fit?
jcbudny is offline
Old 07-27-2012, 09:29 PM
  #37689
Casper's Avatar
Trader Rating: 34 (100%+)
Nope completely normal. Sounds awful I agree but nothing wrong. Again normal.
Casper is offline
Old 07-27-2012, 09:39 PM
  #37690
Rockthecatbox21's Avatar
Savage flux with all metal mod 1 gears= sound like wall-e being murdered.
Rockthecatbox21 is offline
Old 07-28-2012, 05:29 AM
  #37691
ta_man's Avatar
Trader Rating: 165 (100%+)
is this noise on my rtr normal?
this is how it sounded right when i got it.
http://youtu.be/PynO6WUrQXU
The cogging sound to some degree is normal with that motor but making that much noise, it is possible your gear mesh is a little loose. Of course, it is also possible your gear mesh is fine but your microphone was very sensitive and recorded the sound louder than I hear it on my truck.
ta_man is offline
Old 07-28-2012, 11:55 AM
  #37692
BmainStar's Avatar
Friday night Race report,,,,,,I tried the short ackerman plate (ha,ha auto correct wanted to change ackerman to mackerel)Any way what a difference in turning, WoW is all I can say the response is like NOW!!!!!It made it soo quick, I had to slow the servo speed down a Hair.My truck turned very well before, now it turns very well as soon as you touch the wheel .I like the way it feels..TQ and a win so I musta liked it!!!!
BmainStar is offline
Old 07-28-2012, 01:33 PM
  #37693
What rate springs come stock front and rear? Been running them ever since i got the truck and just went to emulsion style 35wt in the rear stock pistons and stock springs. The rear feels a little soft for my liking. Seems like i could go up a rate both front and rear. What kind of springs are ya'll running? Sorry but the search feature doesn't work on mobile devices.
Old 07-28-2012, 01:55 PM
  #37694
BmainStar's Avatar
I think emulsion is gonna feel softer which is more responsive actually.Get the new springs (race sets)Sucks you gotta get the whole set of four for the front and a whole set of four for the rear tho Most set ups sheets are using black front(new ones) not the same as stock black tho!! and orange rear!!I run the #4 pistons rear and #3 front! Also use new pistons when you can!!If your outdoor there than 35 wt in hot weather is fine ,I like 30 here!Cheers!!
Old 07-28-2012, 02:55 PM
  #37695
f/r 3.9/3.3. Source of information is this thread, just couldn't find the exact post where i got that from.
Lomb4rd is offline
