Like Tree9Likes
Old 07-27-2012, 06:14 AM
  #37651
Grandturk's Avatar
Originally Posted by BlackStarRacing View Post
since w are talking about rod ends and ball joints.... when a set up sheet says bump steer up....what exactly is that pertaining to?
There's a flange on one side of the steering ball ends. Compare that to the illustration on the setup sheet - I run the flange down which is pretty much what all setups have. Flange down is bump steer up and flange up is bump steer down.
Grandturk is offline
Old 07-27-2012, 06:27 AM
  #37652
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
ok got it thanks
BlackStarRacing is offline
Old 07-27-2012, 06:33 AM
  #37653
Jake C6R's Avatar
Default Unsolder Motor Connections?
This may be a dumb question - certainly won't be my last one LOL...
When you guys work on your motor, taking it apart to clean it or replace bearings or whatever, do you typically unsolder the wires and then resolder when you are done or leave them connected and work around them?
Jake C6R is offline
Old 07-27-2012, 06:36 AM
  #37654
Its easiest to un soldier it and clean it ... just dont heat up the tabs on the motor too much.
rrussell is offline
Old 07-27-2012, 06:41 AM
  #37655
Grandturk's Avatar
I swapped a front bearing between rounds a couple weeks ago and did not Unsolder the motor. Just worked around it.
Most times sure I'll unsolder it. It takes longer to setup the soldering station and let it heat up/cool down than it does to do the actuAl soldering.
Sometimes if I'm working in my diffs I'm lazy and just leave it soldered in there flopping around...
Old 07-27-2012, 06:44 AM
  #37656
Trader Rating: 47 (100%+)
I just wanted to say that I took the recommendations of a few guys on here and put a new Hobbywing SCT PRO combo in the truck. Ran it last night for the first time at our local races and couldn't be happier. I had it geared with a 14t pinion and did not temp over 130 on the motor and 120 on the ESC. The power and smooth delivery of it made for a very fun night. Anyone on the fence about a motor and speedo for their trucks should not over look this combo.
jcbudny is offline
Old 07-27-2012, 07:05 AM
  #37657
DanielHolloway's Avatar
Well let's see. I checked on Amain yesterday evening and they were backordered. I checked on Horizon this moring, still backordered. Hmm. Nice to see that Amain got the rod ends back. Just wondering how they have them again and Horizon doesn't. Thanks Walmart. That's how I feel Amain is. The Walmart of online RC.
DanielHolloway is offline
Old 07-27-2012, 07:19 AM
  #37658
chucko's Avatar
http://www.largescaleremotecontrol.c...egory_s/79.htm
I found this jem a few yrs ago.. when others are out of parts they seam to have em.. give them a try Jim And Kim that own it go out of there way to help.. Hope this helps someone that needs a part or two
chucko is offline
Old 07-27-2012, 07:36 AM
  #37659
Glad to hear that!!! And I'm sure you have funds for back up parts now as well!!!
Old 07-27-2012, 07:41 AM
  #37660
Grandturk's Avatar
Wow this was a mistake: I inventoried my tires last night... I have 79 tires on SCTE rims. That's 1 lonely tire away from 20 sets. Sheesh.
Old 07-27-2012, 07:43 AM
  #37661
DAMN...... Now thats a collection lol care to sell some lol....
  #37662
Hey Guys i asked yesterday what pinion are you guys running on your 4600kv motors?
Old 07-27-2012, 07:45 AM
  #37663
HighLife420's Avatar
Trader Rating: 49 (100%+)
12-13 at bashers, 14 at springs
HighLife420 is offline
Old 07-27-2012, 08:14 AM
  #37664
Dano628's Avatar
Originally Posted by melloyello1 View Post
I use the end links from a traxxas rustler. I had some new ones laying around. The holes in the balls have to be slightly drilled out but they have lasted much longer than stock losi ones ever would and no slop.
I used another great tip from BFoley Jato rod ends had to trim them about 5 mm then used metric hardware took all the slop out wear like iron and are $8.25 from Amain with enough to do the whole truck . He had some Jato ends lying around and tried them . They worked so good that I had him do my truck for me too .
Dano628 is offline
Old 07-27-2012, 08:15 AM
  #37665
i should have just emailed you lol.... Got a 4600kv tenshock for this weekend really want to get my lap times on average around 32 to be competitive....
