Like Tree9Likes
Old 07-24-2012, 12:22 PM
  #37501
Grandturk's Avatar
Just installed the Novak Activ8 in my SCTE. I had to put in a new battery tray to mount it as I had chopped my last tray and mounted the smaller Havok Pro to the chassis. This one wouldnt fit on the chassis. Anyway - 4.5lbs. Body, battery and tires are 2lbs so 6.5 lbs RTR.
Last time I raced there was no air compressor so it's a bit dirty dirty.
Grandturk is offline
Old 07-24-2012, 12:40 PM
  #37502
Casper's Avatar
Trader Rating: 34 (100%+)
Dang that ESC is BIG
Casper is offline
Old 07-24-2012, 12:45 PM
  #37503
Grandturk's Avatar
tru dat!
It fills up the whole tray.
Old 07-24-2012, 12:48 PM
  #37504
BFoley's Avatar
Pretty much what I said when I mounted mine. It takes up the entire mounting area.
But I have to say, it works Great! Very smooth, no fan on 2S and roughly 14 minutes on a 6600mah. Geared 12/40
BFoley is offline
Old 07-24-2012, 01:25 PM
  #37505
skrichter's Avatar
Has anyone found a chassis protector worth the investment? The thickest/best I found previously was from AE. However, it was trashed in 2 races.
I know we are off roading here, but the bottom of the chassis looks like a graveyard really quick.. Not sure if the 1/8 scale guys have a suggestion? Something that doesn't incur a ton of drag would be of preference. Thx!
skrichter is offline
Old 07-24-2012, 01:26 PM
  #37506
Ralph289's Avatar
Default Castle 3800 with a MMP pinion question
Got a good deal on a Castle 3800 with a MMP SCT edition for the SCTE I am ordering, want to order a few pinion gears. Any ideas ? Was going to order a pack of 12,13,14 as a starting point need long run time with a 6600 65c battery. Small track. Would those be ok or too small. don't need LOTS of speed.
I know it's not the best ESC & motor in the world but I am on a tight budget
THANKS
Ralph289 is offline
Old 07-24-2012, 01:55 PM
  #37507
THANKS
those will be perfect, start with the 13 and expect about 12-14 minutes depending how hard your going.
boyscout is offline
Old 07-24-2012, 02:10 PM
  #37508
Ralph289's Avatar
Thanks.... I will watch the motor temp also and go from there I guess. Just want a good starting point.
Ralph289 is offline
Old 07-24-2012, 02:47 PM
  #37509
Originally Posted by krits View Post
thinking about going with the BigBore shocks on my SCTE , what are your suggestions? read here and there the Kyosho are recommended , which of them? any other suggestions? what about emulsion style on these? anyone attempted this mod on BB?
Kyosho shocks are awesome but there notr really going to make that much of a difference.Ive tried them and im currently running 8 BB on mine now and theres a little difference but not much.The only reason i threw them on is because i had three sets sitting around.Like Casper said the shocks on the scte are really good.IMO Save your money for some tires.
Losi57 is offline
Old 07-24-2012, 02:48 PM
  #37510
Originally Posted by Losi57 View Post
For those of you that run the 8 shocks on your scte.Have any of you ran kyosho springs on your big bore 8 shocks.I was wondering what color kyosho big bore springs i should get for the scte.Its kinda hard to match them up because kyosho doesnt rate there springs by pounds.
Does anyone know what kyosho springs would be equal to thye losi 8ight red fronts and silver rears.
Losi57 is offline
Old 07-24-2012, 03:29 PM
  #37511
mysupratoy94's Avatar
Trader Rating: 24 (100%+)
Anyone running JConcepts Hazzard wheels?
Also, whats a good starting point with shock and gear diff oil weight?
mysupratoy94 is offline
Old 07-24-2012, 03:46 PM
  #37512
TCCustoms's Avatar
I would be if they wouldnt have been on back order(like everything else) when i placed my order so i went with the Proline F11's but do like the look of the Hazzards but will be buying some soon
TCCustoms is offline
Old 07-24-2012, 03:59 PM
  #37513
Hey Grandturk how do you like that rear brace on your Bump chassis? I have the brace but haven't had a chance to run it yet. Right now I'm running the stock brace, did you notice a difference in the two
Throwindirt is offline
Old 07-24-2012, 04:15 PM
  #37514
Grandturk's Avatar
Notice how clean it is? I just installed it. Haven't run it yet but will report ASAP
Old 07-24-2012, 05:42 PM
  #37515
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Try 30 wt all around if your using the bladders. For emulsion i'd try 35-40 wt stock pistons.
As for diff oil 5-5-3 or 5-5-2 is a good starting point. Right now i'm using 40wt shock oil emulsion style at all 4 wheels and running a 5-5 in the front and center and a half and half mixture of 2000/3000. My truck is the most dialed it's ever been.
Rockthecatbox21 is offline
