Like Tree9Likes
Old 07-19-2012, 11:50 AM
  #37261
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Originally Posted by BlackStarRacing View Post
now thats using the color spots on the top of the springs? lol
Yes it is.
BashemSmashem is offline
Old 07-19-2012, 11:52 AM
  #37262
chucko's Avatar
should the colored dot be up or down when installed ?
chucko is offline
Old 07-19-2012, 12:02 PM
  #37263
It doesn't matter , but the top of the shock takes lets hits from dirt and debris so the paint marker is less likely to rub off if you put it at the top .
Old 07-19-2012, 12:16 PM
  #37264
Trader Rating: 47 (100%+)
Using the Losi ride height gauge, where do you guys take your measurements on the SCTE front and back?
jcbudny is offline
Old 07-19-2012, 12:17 PM
  #37265
Casper's Avatar
Trader Rating: 34 (100%+)
Under rear diff and just past the front kick up.
Casper is offline
Old 07-19-2012, 01:24 PM
  #37266
Default Stock sway bar size
Whars the diameter of the stock sway bars front and rear?
losi b is offline
  #37267
Thank you for the quick reply Casper.
jcbudny is offline
Old 07-19-2012, 02:06 PM
  #37268
Casper's Avatar
Stock is 1.8mm front and 2.0mm rear.
Casper is offline
Old 07-19-2012, 02:07 PM
  #37269
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Remember when you guys said "you get what you paid for"? Well the hudy hex drivers live up to that name. Really expensive but probably the best quality out there. I've also heard the dynamite, mip thorp, ans duratrax hex drivers are good as well. The hudy drivers with the ball ends are fantastic.
Rockthecatbox21 is offline
Old 07-19-2012, 03:13 PM
  #37270
CASPER TO THE RESCUE. AGAIN
thank you
losi b is offline
Old 07-19-2012, 05:52 PM
  #37271
TCCustoms's Avatar
Dood, its a Losi...whats wrong with their 8 in 1 driver? I have it and love it...might order extra bits just incase i lose one but its never let me down with my SCTE
Losi 8 in 1 Hex Driver
TCCustoms is offline
Old 07-19-2012, 07:08 PM
  #37272
Dano628's Avatar
+1 All the sizes you need plus you can use a small electric driver or the handle . I have been using mine for at least two years !
Dano628 is offline
Old 07-19-2012, 08:55 PM
  #37273
BmainStar's Avatar
Originally Posted by goehm View Post
I completely hear what you're saying.
I have a slightly different take:
If you're spending most of your time at the 1-85% throttle range, then reducing the EPA on your throttle to say 90% removes that top 10% from the range and applies it back to the range you're actually using (and note that does not mean 10% of your top end is taken off). So you simply extend the throw of your 1-90% range.
What you're doing is not making your car slow down necessarily. In effect, you're making the throw of your trigger longer thus smoothing out the acceleration and braking of your car, making it smoother, thus run faster.
So you aren't going faster by slowing down, you're going faster by being smoother.
Our fingers and throw are at a finite quantity. Adding 10% articulation is a significant amount.
Not on my radio,EPA is an exact point not a percentage.Think of it as a water faucet,open all the way is full water, set a stop before full open and less water will come out.What You are talking about sounds more like ARC, Adjustable rate control.I can feel and see a significant loss of top speed when decreasing EPA.I run a M11X!Cheers!
I have been using a set of Losi allen drivers that are over ten yrs old and still work perfect!!That is a cool all in one set tho!!!
BmainStar is offline
Old 07-19-2012, 09:07 PM
  #37274
[QUOTE=BmainStar;1099524
I have been using a set of Losi allen drivers that are over ten yrs old and still work perfect!!That is a cool all in one set tho!!![/QUOTE]
You've got way more patience then me using allen drivers. My friend uses a set of allen wrenches to work on his truck and i just sit there like WOW!, how can you just sit there using those terribly slow tools. I offer to let him use my hudy hex drivers but he just says "no i'm good". Bet if i left the room he'd be using them within seconds. Allen drivers without ball heads are pretty much useless. Trying to convince my friend to save up for some quality hex driver wrenches. On a completely different note, losi released the much anticipated 22SCT. Saw it on bigsquidrc.com's front page.
Old 07-19-2012, 09:14 PM
  #37275
goehm's Avatar
Trader Rating: 45 (100%+)
Default Lowered LCG, changed weight distro
I've been tinkering with my SCTE and I was kinda inspired by the MIP stuff, so I figured I'd try balancing my truck up a little differently. The way I made the mount lets me move it back to the stock position (when moved all the way back in the tray), or where it's at now. Electronics sit real low, essentially bottom of the battery sits right on the lip of the side of the chassis and ESC is on the chassis.
It's 5lb10oz w/o body.
Runs real good - I'm liking the new weight distro. Hopefully this inspires posting some custom jobs (or someone to go out and put a dremel, drill, and CF to work )
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-truck1.jpg   Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-truck2.jpg
goehm is offline
