So limiting the throttle with the TX can cause the ESC to heat up , or so I have heard .
appreciate the replies guys...... Thanks
Hey guys what are the hex sizes we use on the bottom of the chassis and the towers and diff cases? About to grab a few new tips.....thanks
Im sure he will chime in soon....... I looked for some also but could not find right away. Maby look for Clash Pro4 Racing. I'll have someone shoot some this sunday! Your gonna love our track... it will have new layout for sure, when you come down..... here is a layout I realy Loved!
http://www.youtube.com/watch?v=BCgbq...eature=related
There are also a few 1/16 size screws as well.
not so Quick answer: I personally think it over heats the speed control diverting the energy to the cooling fins. when you turn your expo to 85% and current limit to 65% or 80%.. set current limit to reduce start power it still runs at the same speed just at take off. then set you radio at 100% and learn how to drive . MY feeling is this. if you set your transmitter to 80% and your racing and all of a sudden you need extra speed going down the straight you have it in your hand and finger, just my thoughts I like to go fast. don't tell me to slow down to get faster laps. when your whipping my ass on the track..
I have a slightly different take:
If you're spending most of your time at the 1-85% throttle range, then reducing the EPA on your throttle to say 90% removes that top 10% from the range and applies it back to the range you're actually using (and note that does not mean 10% of your top end is taken off). So you simply extend the throw of your 1-90% range.
What you're doing is not making your car slow down necessarily. In effect, you're making the throw of your trigger longer thus smoothing out the acceleration and braking of your car, making it smoother, thus run faster.
So you aren't going faster by slowing down, you're going faster by being smoother.
Our fingers and throw are at a finite quantity. Adding 10% articulation is a significant amount.
I picked up a .050 for the diffs, and just grabb ted a 1/16, 1.0mm, 2.0mm & 3.0mm is there any other I forgot?
In case you don't watch the 22SCT thread...
Key Features
All metric hardware
Extensive instruction manual and build guide
Full ball bearings including steering
All the components included to complete the vehicle to either rear-motor or mid-motor
7075-T6 Aluminum lightened hard anodized chassis
Changeable dirt guards with Short Course body bumpers
Slide rack steering system with optimized steering Ackerman
Two battery mounting configurations to accommodate both motor placements
Hook and loop straps to secure batteries in all configurations
Optimized suspension package for superior handling
Gull wing designed front arms for lower front shock positioning to lower the center of gravity
Increased hinge pin offset from the rear arm to hub for increased rear traction
Front nose clearance has been maximized
Heavy Duty 4.0mm Steel Turnbuckles with HD ball cups
Aluminum rear pivot that can be adjusted to support 1° of pro-squat to 3° of anti-squat. Rear pivot can accommodate 3°, 3.5°, 4°, 4.5°, and 5° of toe-in for various track conditions
Front plastic pivot with 30 degrees of front kick
Titanium Nitride coated hinge pins
4mm trailing axle spindles
Dual Disk Slipper
Steel RCD drive shafts
Ball Differential with optimized ball pattern
Motor centered in transmission for balanced handling
Molded Gear Cover with attached rubber plug
Improved hub and spindle bearings
High Performance SCT body
Key Features
All metric hardware
Dual Disk Slipper
