sad thing is...I ordered from the HK warehouse pry 2 weeks ago around the holiday and still haven't gotten them! SwissPost shows they cleared customs in Jamaica, NY so hoping to see them within the next few days
And they also got the 4's for my buggy - just 2 weeks after I got them from China, of course...LOL
Turnigy nano-tech 5000mah 4S 65~130C Lipo Pack (USA Warehouse)
Bout to order some 6600 nanos and a battery for my starter box.
kinda excited to get them but then i'll have 2 junk batteries that i cant use cuz when i get them i will be doin the esc direct wire to the bullets for the battery and picked up the Duratrax bullets for $2 this weekend. But now i'll have to off my 2S 40c Gens Ace and start goin to the bullet connected batteries!
We will see if i still get the warm wires/connectors and hopefully not melt the pack but i knew that goin into this but i want decent batteries w/o breaking the bank since i dont race or have sponsors and money being tight so im selling things to buy things to keep my ADDICTION goin, lol!
I found out one of the disadvantages of using differing battery packs on the weekend. I tried out moving the battery to the back of the tray and with a "heavy" (6.6 nanotech & others) battery the car handled really nicely. But then I put in my spare "light" (4000mAh) batteries and it handled terribly - front end was too light/vague and rear was swinging wildly.
Since then, I have moved the battery position back to the factory/middle position and lived with the compromise. If all my batteries were the same weight, then I would leave the position in the rearward one.
That's what happened to me a couple of weekends ago. It was the small bearing inside the diff case that sits up against the pinion. It seized up and gave me some pretty warm temps. Changed it to some Avid bearings during teardown and the temps went immediately back to normal.
Doesn't feel like it on my truck. I know it's not on the rx8/ballistic combo as I just put 2 new bearings in that one when I rebuilt the rear diff on Friday. I'm gonna change the combos around tomorrow and do some more testing.
man you guys beat me to tell everyone that nano's are in stock in the US.
I don't know if anybody provided the link though...
http://www.hobbyking.com/hobbyking/s...dProduct=24222
Before the bearing seized, did you notice any grittyness to the feel back there?, or did it just happen all of the sudden. I try my best to make sure my bearings are in tip top shape. If there is even a slightly grittyness or sudden stop to them, i'll clean them out completely.
I can put the revtech on the rx8 and the ballistic on the mmp without a problem. Not sure I understand your comment about the green o-ring though. It has to slide to the bottom of the shaft when the end bell goes on. Tried several of the suggestions today without much success in reducing the motor temps.
If your motor doesnt have the O ring in it, then its probably one of the newest ones that had that problem rectified.
If you've already temped it up over 210 or so, then its probably toast, and it wont operate right, or at a decent temp anymore.
Its a great motor, I ran it with an RX8 in my Losi for about 3 months before I sold the truck. Its still soldered up to my RX8 sitting in my toolbox, ready to drop right into another vehicle. I ran it at full power ONE time... it was waaaaay more than I needed for the track I was at, so I dialed the EPA down to 80% and left it, it was all I needed.
A-arm slop
Hey Guys,
I picked up a "lightly" used SCTE a little while ago and I've been working all the little bugs out and getting it dialed in. It seems to me there is a lot of slop or play in the arms. What I mean is, if I grab the axle while the car is on the stand I can shake the arm back and forth about 3 to 5 mm.. Is this normal, or do I have a problem here? If it's a known issue, what is the fix? Thanks
Yeah i run the tenshock as well and it eats batteries like crazy. Had to order the 6600's, wouldn't feel safe using the 6000's. Even so i've had the batteries dump on me in a race. Think it was really my fault for not balance charging them that time because i was in a hurry, or maybe it was my esc because it has a funky voltage cutoff.
