Like Tree9Likes
Old 07-11-2012, 10:57 AM
  #36811
nismomike's Avatar
Originally Posted by Casper View Post
That is what I thought. I dont' think those weigh much but it is balancing out the rear end some. Expensive counter weight! LOL
Matt has been on a tear lately for sure.
I'm guessing that he got a good deal on it.
nismomike is offline
Old 07-11-2012, 10:58 AM
  #36812
MIP MATT's Avatar
Originally Posted by nismomike View Post
After watching round 5 of JBRL, I'd say its a supercharger. Or its an MIP TG-3 onboard temp guage with a blue case
Hahah you got that right lol yes temp gauge with a blue case they all come in black though.
Also to answer Caspers question its 13 grams which is less than .5 ounces : 1 ounce = 28.3 grams (courtesy of google )
Maybe put one on the speedo to counder the front left lol
MIP MATT is offline
Old 07-11-2012, 11:10 AM
  #36813
Casper's Avatar
Trader Rating: 34 (100%+)
I figured it was not much. That is two lead squares though. Helping out those that want to copy your setup!
Casper is offline
Old 07-11-2012, 12:05 PM
  #36814
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
Originally Posted by kjohnsiii View Post
Anyone know what size the o ring is that goes inside the diff inserts?
kjohnsiii is offline
Old 07-11-2012, 02:59 PM
  #36815
Default shock pistons
do the numbers on the shock pistons go up or go down?
ronsvsix is offline
Old 07-11-2012, 03:01 PM
  #36816
BradS's Avatar
not sure on the exact size, below is a link to a good replacement if you only want to buy the o-rings and not a full rebuilt kit.
http://www.amainhobbies.com/product_...ugen-S5-O-Ring
BradS is offline
Old 07-11-2012, 03:10 PM
  #36817
I guess it depends on where you start but I am not sure I understand your question but maybe this can help...
#1 0.95mm | #2 1.00mm |#3 1.05mm | #4 1.10mm | #5 1.15mm
hacker07 is offline
Old 07-11-2012, 03:13 PM
  #36818
Jake C6R's Avatar
I think he is asking the about the numbers printed on them - up or down in relation to the top of the shock - I don't think it matters, does it?
Jake C6R is offline
Old 07-11-2012, 03:17 PM
  #36819
kjohnsiii's Avatar
Thanks brad.
Old 07-11-2012, 03:28 PM
  #36820
MIP MATT's Avatar
Numbers on the shocks shouldn't matter if its placed either way. The stock pistons are drilled straight through. I always put the number on top so I can see what piston is inside if I happen to forget. Just personal preference though.
MIP MATT is offline
Old 07-11-2012, 03:36 PM
  #36821
Oh, whoops, sorry, totally misunderstood that question...lol.
And I agree with Matt on this one...I do the same.
hacker07 is offline
Old 07-11-2012, 03:37 PM
  #36822
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
not sure how much it matters, but there is a relief on one side of the piston for the washer that goes on the shaft before the piston. just can't recall which side the relief is on.
RC*PHREAK is offline
Old 07-11-2012, 03:39 PM
  #36823
Trader Rating: 20 (100%+)
its on the non-numbered side. so i put it number side down.
dainjarouz is offline
Old 07-11-2012, 05:58 PM
  #36824
chucko's Avatar
I called Chuck at King racing shocks and asked if he could do a miniature version or his race shocks for pro trucks.. he said he would for 1000 dollars. . any takers..
J/K I was thinking about limit straps also.. do you think 3 way adjustable argon filled shocks would work on this truck...???
chucko is offline
Old 07-11-2012, 06:50 PM
  #36825
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
I didnt have any rv so i used shoe goo and it works awesome , no leaks here!
BDRMBULLY is offline
