Like Tree9Likes
Old 07-09-2012, 09:07 AM
  #36676
Originally Posted by 4skinz80
2 little problems i found when building.
#1 the body posts do not quite fit the towers. I had to dremel them to allow the nut to sit flush. Even that its not perfect. You will have to redo your holes in your body to accommodate.
To clarify, I believe thats only if you are using the one piece stand offs. I'm still on the out of the box setup and it is not an issue. Because of this, I'm ordering up some titanium button head screws and aluminum nuts.
#2 the steering linkage on the inside requires you to use 2 of the smallest tapered washers i have ever seen. Its dam near IMPOSSIBLE to get them in place without it dropping or flying off the linkage. Took me almost 30mins to do that alone.
I didn't struggle with the two outer ones, but that inner one with the Dubro ends was an experience. I found that using one of my smaller hex drivers through the bottom to hold the washer in place and then use it to pull the Dubro end in made it pretty easy.
J.Pietsch is offline
Old 07-09-2012, 09:24 AM
  #36677
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Kuya_Kimo
Which GensAce did you buy to get the plugs?
They were on the 5000mAh 65c 2s packs (which were working great and staying nice and cool) .
http://www.hobbypartz.com/98p-65c-50...-hardcase.html
Originally Posted by Sierrahotel
I got those plugs with the 50c 5000mah pack. Plugs fits firm but not tight.
The ones I have fit great , you could spread the end of the bullet out a little to make it tighter but then its really hard to get back out .
They fit tight on my 6.0 and 6.6 Nano Techs as well .
BashemSmashem is offline
Old 07-09-2012, 09:35 AM
  #36678
Originally Posted by BADxDREAMS
Hi guys about a year into rc and I want to start racing and like the SCTE. So my question is what motor and esc are you all using? I will being racing it in a 4wd Sct class of course and have no limit on motor or esc. In price I want to be under 250 in the motor and esc. I know I am leaning towards the MMP for the esc. Please any sugession are appereciated. Thanks
Thanks for all the replies. Should I just save and just get the tekin rx8 with Pro 4 motor?
BADxDREAMS is offline
Old 07-09-2012, 09:39 AM
  #36679
Jake C6R's Avatar
That's like asking which chassis to get!
Lot's of strong opinions, and there are many good options.
Jake C6R is offline
Old 07-09-2012, 09:58 AM
  #36680
Trader Rating: 22 (100%+)
I'm looking to get my scte to slide the rear end around in corners more, I have a rear steer style. Can this be accomplished with diff fluid changes? Take off front sway?
I am new to the scte so it's all stock as far as diff and sway bars.
jonasm48 is offline
Old 07-09-2012, 10:00 AM
  #36681
Dano628's Avatar
+1
Dano628 is offline
Old 07-09-2012, 10:11 AM
  #36682
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I took my front sway bar off and switched to 2000 wt in the rear diff. My truck was pushing but now i can kind of do a controlled slide around corners.
Rockthecatbox21 is offline
Old 07-09-2012, 10:27 AM
  #36683
TCCustoms's Avatar
Originally Posted by Dano628
+1
Right...I mean we all said what were good options and all but yet still asking after everyone says what they have, like and prices...I mean when u can get 3 or so combos for less with the same if not better results and u wanna pay big money but the money u can save can go to ALOT of other upgrades so at this point it's in yet hands and how much u wanna drop into a system
TCCustoms is offline
Old 07-09-2012, 10:31 AM
  #36684
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Simple answer to the chassis debate and motor debate: SHOP YOUR BUDGET..... Buy what you are used to using....buy what the locals around your track are running... AND HELL WE ALL KNOW THERES AT LEAST ONE OF THESE BAD BIATCHESSS AT EVERY TRACK lol....
BlackStarRacing is offline
Old 07-09-2012, 10:34 AM
  #36685
TCCustoms's Avatar
Exactly...or if 1 has an option u like and prices are close go with the one that has something u like about it
Old 07-09-2012, 10:51 AM
  #36686
Question on springs: I see there are the sport packs and i was wondering if you guys that have purchased them are using all or just one set? Just wanted to know if i should buy just a certain strength or the total packs because they are all utilized.
Old 07-09-2012, 11:02 AM
  #36687
HighLife420's Avatar
Trader Rating: 49 (100%+)
Id buy them to have them D, just in case.
BTW, i have a rear set if you want. Can bring them to the track this weekend.
HighLife420 is offline
Old 07-09-2012, 11:17 AM
  #36688
Casper's Avatar
Trader Rating: 34 (100%+)
The racing springs only come in full sets. They are worth it though. Work much better then the stock springs.
Casper is offline
Old 07-09-2012, 11:21 AM
  #36689
Grandturk's Avatar
Black front and orange rear are the 90% setup. That's what I run, that's what most people run and the setup sheets show.
Grandturk is offline
Old 07-09-2012, 11:33 AM
  #36690
Thanks guys, ill buy both sets.... Hey HiGHLIFE truck rebuilt loving the TLR chassis thanks for the great buy....now watch out on the track with that evil upgrade of a kit you have.....LOL in my sinister voice (MUST SAY THE MIP KIT DOES LOOK REAL SWEET LOL)
