Like Tree9Likes
Old 06-20-2012, 08:36 AM
  #35776
Trader Rating: 20 (100%+)
Originally Posted by hacker07 View Post
The stock motor mount will hold a 20T pinion. The RTR motor was tested in 105 degree weather with 3 consecutive battery packs or about 35 minutes of running and that is where that stock gearing came from. If you are running a pack, I am sure you could get away with a 20T.
MX304 is offline
Old 06-20-2012, 08:48 AM
  #35777
Originally Posted by Casper View Post
This works on the rear due to the toe in in the rear. Changes the angle of the arm in the blocks. This is not an issue with the front.
You need to keep an eye on motor temps but the kit is undergeared for the motor on 2S out of the box.
Are you using trim or subtrim to center the servo?
Hi Casper, no everything is on 0 (zero)
fivenines is offline
Old 06-20-2012, 08:50 AM
  #35778
Casper's Avatar
Trader Rating: 34 (100%+)
0 inserts for the rear/rear pivot is 3 deg of toe in which angles the arms. Does that make sense?
Casper is offline
Old 06-20-2012, 09:01 AM
  #35779
Trader Rating: 160 (100%+)
Originally Posted by nitro0619 View Post
No they rub....unless u have ones specifically for the scte they dont work
Thanks.
Chris Gierse is offline
Old 06-20-2012, 09:06 AM
  #35780
that's how I'm set
Old 06-20-2012, 09:24 AM
  #35781
HighLife420's Avatar
Trader Rating: 49 (100%+)
So, you guys think i should remove the RPM bumper before i test it out? If i use it, i cant return it.
Just curious as to how much the front skid plate makes a difference with the handling of the truck.
I am racing only, not bashing at all.
HighLife420 is offline
Old 06-20-2012, 09:33 AM
  #35782
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I raced with it fine. Got second in both my heats and am on my way to the a-main with it this weekend (race got stormed out). Made no difference from the stock bumper performance wise. The rear rpm skid plate is not bad either.
Rockthecatbox21 is offline
Old 06-20-2012, 09:38 AM
  #35783
but are you talking about the rear arms? does that affect my steering EPA?
Old 06-20-2012, 09:39 AM
  #35784
Old 06-20-2012, 11:09 AM
  #35785
Adonis_mp's Avatar
Trader Rating: 8 (90%+)
Default Setup Sheet ?
I am pretty new to this truck and have been going through the setup sheets on the Losi web site. My question is about the rear camber link placement. On most setup sheet they have you move the link to the B position (hole) and then I assume that you adjust the camber back to -1 (on most sheets). Why not just adjust the camber to -1 and leave the link alone? What is the point of adjusting the link location?
Is there really a diffrence between 27.5 to 30 shock oil?
Not that i like to question the pros but I am more into the mechanics and the building of the trucks than actually driving them.
Adonis_mp is offline
Old 06-20-2012, 11:21 AM
  #35786
Casper's Avatar
The link will change how the camber changes as the arm moves up and down. Setting it at ride hight to a static -1 is just the starting point for the camber. As the truck leans over or squats under acceleration will change the camber depending on the camber link position.
There is obviously a difference between 27.5 and 30 but it is pretty small. Back in the day we used to only have 5wt changes avaiable but guys starting mixing oil to get "half weights" and losi and AE started releaseing these half weights. Most setups for these cars will run around 30wt oil as this common for offroad 10th scale. We will tune from there.
Casper is offline
Old 06-20-2012, 12:06 PM
  #35787
Adonis_mp's Avatar
Thanks for the answer, it explains alot.
Old 06-20-2012, 12:52 PM
  #35788
fastford's Avatar
Originally Posted by fastford View Post
What diff fluid should I be trying in the center diff to help it rotate around sharp corners? 5-7-3 is what Im currently running on a larger outdoor 1/8 track.
Still looking
fastford is offline
Old 06-20-2012, 01:02 PM
  #35789
Casper's Avatar
Still looking
5 will help with low speed steering.
Casper is offline
Old 06-20-2012, 01:20 PM
  #35790
rccrazy316's Avatar
if any of you on hear know pork chop he is on here alot
i just wanted to let you all know that he has past away and he will be missed
please keep his family in your prayers. he was only about 23yrs. old.
rest in peace Charles Garten.
rccrazy316 is offline
