Like Tree9Likes
Old 06-05-2012, 03:26 PM
  #35101
scoobie1's Avatar
Originally Posted by Tanman11
Stupid question............but where? All I see are the stock bodies??? Not at Amain, unless I missed it.
You missed it TLR8060
scoobie1 is offline
Old 06-05-2012, 03:34 PM
  #35102
TCCustoms's Avatar
why is it that all the nano batteries have the bullet plugs and not direct wired...i hate these bullet plugs and would rather not run this type of battery but if they are decent batteries i might have to start thinking about switching
TCCustoms is offline
Old 06-05-2012, 03:44 PM
  #35103
Several of the fast guys at our track run the 6600mAh 65C Nanotechs. I can't wait to try mine.
electricRCrocks is offline
Old 06-05-2012, 03:53 PM
  #35104
theproffesor's Avatar
Trader Rating: 66 (100%+)
Originally Posted by Casper
The savox is one of the worst servo's for amp draw. It is hard on the ESC BEC. Spektrum are not to far away. This has a little more effect on the ESC you run vs the radio though.
I am going to be running a tekin rx8 and pro4 4600 or sc4x 4.5/5.5 i have looked and dont really see any other servo's with the specs of the savox 1256 orspectrum with same exact stats, which now has me thinking. exact same states, same servo?? any other servo suggestions?
theproffesor is offline
Old 06-05-2012, 03:57 PM
  #35105
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Yeah i only have one nanotec 65C and i wish i had bought more. Good luck to you guys and the race to get them in your cart first when they are in stock again. These things sell out almost instantly. I've been using the regular turnigy 40C in my practice runs and the nanotec 65C for races. The 40C's do get a little hot after a run with my tenshock 401 4600Kv motor.
Rockthecatbox21 is offline
Old 06-05-2012, 03:58 PM
  #35106
Trader Rating: 101 (100%+)
Default Servo
I run ae1015 in all my trucks. I've never had a problem.
Revo Dan is offline
Old 06-05-2012, 04:22 PM
  #35107
Default Ryan Dunford Setup questions
Ryan,
I am running your setup from 2/29/12. It is working well even on an outdoor track. Do you run your shocks emulsion style? I know you run a R10 from Orion whereas I run a RX8 but what current limit do you run?
One more thing, I recently had a bearing fail in the rear diff housing right before the main of a big race. How often do you replace bearings to prevent this from costing you a race? Better yet, how do you check them?
Russell
Old 06-05-2012, 04:27 PM
  #35108
Casper's Avatar
Trader Rating: 34 (100%+)
Yes very similar servos. Not many servo's out there with those STATS and price point. JR makes some great servos as well as there are good hitec, Futaba, KO and airtronics servos. Just a matter of how much you want to spend. I run the RX8 pro 4 4600 with a JR 8717 but a lot of guys run the Spektrum S6040 and have no problems. Most of the problems are with the Castle speedos'.
Originally Posted by electricRCrocks
Ryan,
Russell
I can answer two out of three for Ryan
He runs emulsion shocks.
He actually has a RX8 in his truck right now and runs the same as I do with 80% limiter. That is as high as I would go with the limiter. If you are on looser dirt and looking to take away some wheel spin you could go down to around 60%
Casper is offline
Old 06-05-2012, 04:33 PM
  #35109
thanks for the info. time to do more research
Old 06-05-2012, 04:35 PM
  #35110
TCCustoms's Avatar
ok, what about these if the nanos are always out of stock....65c rating but only 5300mah but if you have a few batteries i dont think 5300mah is terrible??
Gens Ace 65c 5300mah
Old 06-05-2012, 04:46 PM
  #35111
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by vw addict
well perhaps it's time for me to upgrade.......
Valuehobby sells a set of 5 4mm solid bullets for like $2 great deal
BlackStarRacing is offline
Old 06-05-2012, 04:48 PM
  #35112
i run these batts they are great!!!! enough power and depending on how you drive they should last an entire race!!!
Old 06-05-2012, 05:06 PM
  #35113
larlev's Avatar
Hmmm, interesting.... Is it ok to use those for charging? I have solid plugs on the esc wires
No need to change them. I have 14 nano's and haven't had an issue with stock bullets in 1/8 and SCTE.
larlev is offline
Old 06-05-2012, 05:10 PM
  #35114
larlev's Avatar
Not if you set endpoints correctly. I will agree when it's at full throw it is high, not bad at all when backed off a little.
I have a sheet somewhere when I tested draw...back when I had the MMP, spektrum issues. I'll find it and post
larlev is offline
Old 06-05-2012, 05:14 PM
  #35115
larlev's Avatar
Another one to look at is the ProMatch lipos. Have had real good results so far with the 2 I own. It is really hot here in Texas now and these have performed very well.
I have Nano's, gens ace, venoms, and promatch.
IMO, at the pricepoint we can all get nano's, gens ace for. If they last 6-8mths of hard use. It's a no-brainer money wise.
larlev is offline
