Like Tree9Likes
Old 06-02-2012, 03:27 PM
  #34921
Trader Rating: 38 (100%+)
Had my first night racing in 10+ years with my SCTE last night. Qualified 5th even though I cased a jump after losing 4wd, set screw on front driveshaft fell out. Managed to screw up the chassis pretty badly. Put the front end back together and got it running for the main hoping the chassis would hold together. Made it through 4 min, was running in 4th, and while trying to lap a back marker got touched and clipped the wall ending my night and the chassis future on the track. Now trying to decide between a Bump, BCE, and Losi flex tuned...
vw addict is offline
Old 06-02-2012, 03:40 PM
  #34922
TCCustoms's Avatar
yup, its a HW as its a combo! I'll try the timing off also...But after that if i dont get the blinking lights i will stick to the 14t so i have alittle top end for our big track since it has big jumps and 1 long straight on it.
We are gonna hit the track tomorrow so i could go to bed now(6:40pm here) just so tomorrow would come faster, LMAO
TCCustoms is offline
Old 06-02-2012, 03:52 PM
  #34923
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
when you put the 15T in and got the blinking lights, what do the blinking lights signify?
RC*PHREAK is offline
Old 06-02-2012, 04:03 PM
  #34924
Trader Rating: 120 (100%+)
I had 2 rear body mounts pull away from the 4 mounting screws at the shock tower while racing today. Has anyone else had this problem and if so what was your fix?
JoeC is offline
Old 06-02-2012, 04:06 PM
  #34925
larlev's Avatar
longer screws
larlev is offline
Old 06-02-2012, 04:42 PM
  #34926
BAD007SUZUKI's Avatar
Trader Rating: 97 (100%+)
Default NUTS?
HEY JOE,
I GOT TO LOOKING AT MINE. WOULD LONGER SCREWS WORK IF YOU DRILL THE MOUNT OUT THE REST OF THE WAY, AND USE A WASHER WITH A NUT ON EACH SCREW? MINE WAS BRAND NEW BEFORE TODAY, BUT HEARING YOUR ISSUE MAKES ME WANT TO USE LONGER SCREWS AND NUTS JUST IN CASE.
BAD007SUZUKI is offline
Old 06-02-2012, 05:44 PM
  #34927
darryl80's Avatar
Trader Rating: 24 (100%+)
is there a losi part number for the screws on the bottom of the chassis that hold down the battery tray?
darryl80 is offline
Old 06-02-2012, 05:47 PM
  #34928
darryl80's Avatar
actually will this screw set take care of everything on my truck?
http://www.amainhobbies.com/product_...SCTE-Screw-Kit
darryl80 is offline
Old 06-02-2012, 06:05 PM
  #34929
djbclk430's Avatar
Trader Rating: 59 (100%+)
Hey guys just rebuilding diffs taking grease out and want to know what is a good set up for changing to diff fluid front center and rear diif for indoor clay high bite track? THANKS!
djbclk430 is offline
Old 06-02-2012, 06:25 PM
  #34930
scracer68's Avatar
You can't go wrong with any of the 3. I run the Bump and like it but I can drive my sons truck just as fast with the stock chassis.
scracer68 is offline
Old 06-02-2012, 07:02 PM
  #34931
larlev's Avatar
IMO....and I have both the Trick Parts kit is better quality and is stainless.
larlev is offline
Old 06-02-2012, 07:07 PM
  #34932
darryl80's Avatar
they dont have to be stainless cause they are going on a ten t and i dont race i just bash.
darryl80 is offline
Old 06-02-2012, 07:32 PM
  #34933
Dano628's Avatar
If your running at Critters try 5/5/2
Dano628 is offline
Old 06-02-2012, 07:34 PM
  #34934
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Originally Posted by MattP View Post
Have any pics of your BEC setup in your truck?
MOE is offline
Old 06-02-2012, 07:38 PM
  #34935
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
I have the bce and it is great. Pretty stiff chassis and i like it that way. I've also heard the kingheads chassis is pretty good as well.
Rockthecatbox21 is offline
