Like Tree9Likes
Old 05-31-2012, 08:47 PM
  #34831
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by TCCustoms View Post
OK, just got it today at lunch from the PO and took it to work like show and tell...how dumb, right?!
So here it is...Hobbywing SCT PRO with the new Hobbywing 4700kv motor and LCD program card. Got it all mounted, wired, and ready to boot up
That looks great fantastic. I just swapped out my Tekin 4600 for the HW 4000 and looking forward to trying it. Let us know how you like the 4700.
One thing I'd suggest is running that ESC wire under your battery tray, and then into the receiver box. If you remove the tray you'll see clips underneath designed to hold the the wires in place. Then you can run in along the tray, under the front brace and into the side slit in the receiver box.
goehm is offline
Old 05-31-2012, 08:59 PM
  #34832
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
+1 on that i do it as well. Also another thing you might do is mount your on/off switch directly to the flat part of the chassis right next to the esc. Double servo tape it or use some of that kyosho zeal gel to mount it.
Rockthecatbox21 is offline
Old 05-31-2012, 09:37 PM
  #34833
dougo96's Avatar
So here it is...Hobbywing SCT PRO with the new Hobbywing 4700kv motor and LCD program card. Got it all mounted, wired, and ready to boot up but time was short tonight so maybe tomorrow and hopefully get some vids of it this weekend in action if the body post come in and hoping they show tomorrow. Combo came with a 15T and 19T and were different pitches with them both being 5mm shafts but the 15 matched the pitch on the scte so thats what im running for now and will stop at the hobby shop and get a 14T also
FYI its a 4000kv motor....
dougo96 is offline
Old 05-31-2012, 10:43 PM
  #34834
Nice! I just got mine in and running today. I have the Tenshock SC411 4000kv though, runs great! Sensored is sooo smooth I have my ESC mounted 90* clockwise of how yours is mounted, figure if anything gets up in that area (sticks or whatever), it won't rip the wires out of the ESC. It is well protected anyway but I didn't want to risk it.
goehm, I'm going to run my ESC wire like you said. I looked at it and it really looked like too much of a pain to route so I routed it like TCCustoms for the time being. I just had to drive it!!
thegame7 is offline
Old 05-31-2012, 11:03 PM
  #34835
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by hacker07 View Post
They are in the wheel wells.
Any chance of "smart diff's" or a front universal coming out any time soon?
8ight-e is offline
Old 05-31-2012, 11:45 PM
  #34836
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
just got a used hobbywing 4 pole motor today to test out. first thing i did was pull it apart. wanted to see the rotor. here are some comparisons of the hobbywing, pro-4, and a SC401 tenshock:
from left to right: hobbywing, pro-4, tenshock:
DIAMETER:
hobbywing: 19.07
pro-4: 19.02
SC401: 14.63
LENGTH:
hobbywing: 27.39
pro-4: 20.06
SC401: 29.86
FINAL STATS:
hobbywing: 19.07 X 27.39
Pro-4: 19.02 X 20.06
SC401: 14.63 X 29.86
the hobbywing should be a beast...
RC*PHREAK is offline
Old 06-01-2012, 12:16 AM
  #34837
RC*PHREAK's Avatar
and as far as saladfork goes. he's fine. just can't get on the intrawebz for a while.
Old 06-01-2012, 05:00 AM
  #34838
8ight-e's Avatar
Thanks for the info.. also Castle 1410 3800kv 17mm x 25mm (magnet area only)
8ight-e is offline
Old 06-01-2012, 05:06 AM
  #34839
TCCustoms's Avatar
Koo guys, thanks for all the input! As far as it all goes and what's where... The power button is just sitting there as I thought it was funny it was a perfect fit sitting there. The esc wire tho...I didn't like it that way anyways so thanks for the info as I had no clue and will fix that tonight but need to get some double sticky servo tape so I can hold down the power button!
TCCustoms is offline
Old 06-01-2012, 07:14 AM
  #34840
criss2115's Avatar
Default Servo arm insert
Can someone please post the Losi part numbers for the metal servo arm inserts. I can not find them to order.
Thanks in advance
criss2115 is offline
Old 06-01-2012, 07:42 AM
  #34841
Integra's Avatar
Originally Posted by cavg View Post
However that Mugen part ain't the best. In the manual it's states that you shouldn't try to replace pins that are more than 50% worn out. My first attempt was a pin that had perhaps 65% left, and the screw tip broke (the part that presses the pin). I have managed to replace some pins with it but would definately not purchase it again. As it stands now the tip is on the remover screw is flush with the screw..so can't press them out enough to get a new one started. And the inserter screw have a crack in it.
Worst rc investment for me by far. Caused alot of grief!
part reason i Suggest the Chain breaker and Not a Branded RC pin remover. Ive had the Chain breaker for darn near 3+ year's. pressed COUNTLESS pins from ALL brands of cars and Have never once broken a press pin. Yes I've gotten some tricks over the year's but I personally feel the Hudy is a Joke of a Tool. A Hammer, really hudy. Not to mention they are Extremely Dangerous to use. Pins can Shatter and sent pieces Fast and Far. I would know, I took on in the hand.
I vote UNI.
Integra is offline
Old 06-01-2012, 07:50 AM
  #34842
RC*PHREAK's Avatar
Hard to believe the 1410's rotor is 25mm long. I'm not measuring the spacer, just the magnet length.
edit: just figured it out. no sensors. that's how they can fit the 25mm long rotor in there.
Old 06-01-2012, 11:38 AM
  #34843
Thanks in advance
Are you talking about the plastic splines that go into the horn itself?
Old 06-01-2012, 12:23 PM
  #34844
criss2115's Avatar
Not plastic inserts that come with the kit. Losi makes metal inserts just like these. I need to order one for myself and a loaner but I can not find a part #
Old 06-01-2012, 12:37 PM
  #34845
TCCustoms's Avatar
Sorry bro, but might wanna get to kno your own products alittle better as the package says 4700kv and so does the motor laser etching. I kno that sounds rude but I kno my products and make sure I got what I ordered. I'll get a better pic tonight of the motor but the only thing I noticed was that with the grooves in the motor sticking out I had to grind down the tab underneath which looks like it would be a support as the motor wouldnt slide into the mount becuz of the additional grooves.
And a Quick question...mine was an 810 now a SCTE so do you think the axles and 17mm hexes stick out farther than the 12mm stock SCTE Hexes would? The 1/8th scale rims look like they might hit the body but did order and do have scte axles and hexes but no scte rims/tires yet
