Like Tree9Likes
Old 05-29-2012, 09:40 AM
  #34696
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by jlfx car audio View Post
I asked this question back 4pages ago with not one reply. Actualy ive asked it on every page since then.
There should be a little play. Impossible to see but you should feel just a little back lash all around the gears for a proper mesh. If there is no play it is too tight and binding. I have never shimmed my diffs and have not had a problem so far.
Casper is offline
Old 05-29-2012, 09:43 AM
  #34697
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Originally Posted by BashemSmashem View Post
You should shim the pinion to get just a tiny amount of play , less than 1/2mm IMO . I used 4 shims on rear diff of mine but the front only took 2 . The shims go on the pinions shaft first , then the bearings . You want the diffs free without any binding , if it does take it apart and remove 1 shim and reassemble .
Maybe it was just worn out ? They are a reall tight fit on the pinions shaft , maybe it was damaged when you took it off ?
Truck was 8 packs old. Never pulled pinion out the drive shaft holds it in. So ur shimming it for a tighter gear mesh? Which puts more strain in pinion bearing. But by removing all shims from in between pinion and bearing will take stress away but will open up mesh . And create a nosie diff
jlfx car audio is offline
Old 05-29-2012, 09:45 AM
  #34698
Yea i didnt shim mine it was pinion 2bearings then center shaft with a tic of play. Bearings felt good untill bearing blew
Old 05-29-2012, 10:00 AM
  #34699
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
No the 8ight diffs are bigger.
would it be wise to use two of the paper like seals that come with the diffs to help with the leaks on the center diff? Or is there any little trick you guys might have?
BlackStarRacing is offline
Old 05-29-2012, 10:03 AM
  #34700
We are workign on diff cases currently but basically a little black grease on both sides of the paper seal will help.
hacker07 is offline
Old 05-29-2012, 10:08 AM
  #34701
Jake C6R's Avatar
Do you shim these like the 8 2.0 diffs from side to side?
Jake C6R is offline
  #34702
Casper's Avatar
You can.
Casper is offline
Old 05-29-2012, 10:15 AM
  #34703
You can.
does it use the same size shims?
gen3busonoma is offline
Old 05-29-2012, 10:29 AM
  #34704
Casper's Avatar
No I believe the 8ight uses std 8X14 flanged bearings for the outdrives.
the Ten series uses 12X18 bearings.
I am not sure you can use the same shims.
Casper is offline
Old 05-29-2012, 10:34 AM
  #34705
OK thats great..... ill try a bit more black grease
Old 05-29-2012, 10:50 AM
  #34706
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Why would it put any more strain on the bearing than not shimming ? You may have had a bad bearing in there from the start , it happens .....
BashemSmashem is offline
Old 05-29-2012, 10:51 AM
  #34707
Suspended
Trader Rating: 39 (96%+)
what Motor Heat Sink would fit on the tekin pro4 motors? my motr is running a little hot in my scte
JOSH MILLIREN 1 is offline
Old 05-29-2012, 10:54 AM
  #34708
Anything that fits a 36mm motor will work.
Old 05-29-2012, 10:56 AM
  #34709
Casper's Avatar
What is "hot"
Casper is offline
Old 05-29-2012, 11:17 AM
  #34710
Originally Posted by Dano628 View Post
If you need two gaskets you didn't do it right . Make sure that square blocks are seated all the way down in the diff housing if you have to us something to push them down . If they are seated correctly and everything is assembled right your diffs will be butter .
Obviously.Im just saying if he glued the metal insert and it isnt seated all the way 2 gaskets fixes this without buying new parts.
Losi57 is offline
