Like Tree9Likes
Old 05-25-2012, 07:26 AM
  #34501
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by chucko View Post
Hey all you big time racers>>>>>>>>after a race you take apart your car, clean, everything and its going to be a month before you get the chance to race, (BUMMER) how should you store the car ????? with tires off or on? springs adjusted to free it up and store it up side down or what any help would be nice. Thanks in advance
I usually just put it on Car stand ans im done. If you do anything more than that you are probably sponsored and r taking things way too serious.
Rockthecatbox21 is offline
Old 05-25-2012, 07:31 AM
  #34502
chucko's Avatar
this might have happened to you and I just found the fix. at the races you case the feature which is meant for 1/8th scale nitro buggies and your drive shaft pops out of the center diff, dead in the water. USE the shims from the diff and a rubber washer from diff, behind the drive shaft. the washer keeps the bearing in the rear end, the rubber is the spacer and it moves the drive shaft in towards the center diff almost a 1/4 inch helping it stay in, in bad landings. JMO try it you'll like it.
chucko is offline
Old 05-25-2012, 07:45 AM
  #34503
elex300's Avatar
Trader Rating: 106 (100%+)
I remove the tires and I also take the springs off the shocks. Then I push the shafts all the way in. I find when the cars sits with the springs on for a few weeks that air tends to find its way in the shocks.
elex300 is offline
Old 05-25-2012, 08:03 AM
  #34504
Trader Rating: 20 (100%+)
Won't that make it much more likely to bend the center shafts? I have bent several, but never had one pop out.
MX304 is offline
Old 05-25-2012, 09:04 AM
  #34505
chucko's Avatar
in measuring the dog bone to the tabs sticking in the hardened shafts it centers it so it has movement. just a 1/4 in closer so it wont pop out. it wont work for the front end due to the angle of the shaft. as it is it almost hits in rotation now. but you could be right if your chassis flexes so much it could compress and bend. so lets not hope that happens
chucko is offline
Old 05-25-2012, 10:42 AM
  #34506
pistolpete1982's Avatar
Trader Rating: 26 (100%+)
Originally Posted by "Smiley" View Post
Here is the Prototype FTW SC Body. Should be released very soon. Be sure to pick one up from avidrc.com
I was wondering when FTW was gonna make a sc body.
pistolpete1982 is offline
Old 05-25-2012, 01:02 PM
  #34507
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by dumper View Post
www.teamcrc.com
We have the Hobbywing 4000 kv 4 pole motor in stock. This thing is an animal. There is nothing funnier that running over a Tekin 4600 on the straight. It is sensored and smoooooth.
We also have the SCT pro, program box and 4 pole motor in a combo.
Check them out online, or feel free to give us a call 315-338-0867 for any help.
Brian - what are you guys gearing the 4000kv at?
goehm is offline
Old 05-25-2012, 04:09 PM
  #34508
theproffesor's Avatar
Trader Rating: 63 (100%+)
so been out of the RC scene for a while BL motors and lipo weren't out yet. Have decided on Tekin RX8 speedo. will be on a med to large 1/8 track which is better, pro 4 4600/4000 or sc 4.5/5.5 550 motors.
theproffesor is offline
Old 05-25-2012, 04:30 PM
  #34509
Go for the pro4 4600Kv. Great motor and everyone in 4x4 shortcourse at my track has one in their truck.
Old 05-25-2012, 04:32 PM
  #34510
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Go for the new hobbywing 540 4 pole 4700 it rocks. More power then the 4600 pro-4 and cheeper to boot.
Blitzrockey is offline
Old 05-25-2012, 04:55 PM
  #34511
dougo96's Avatar
15T.
dougo96 is offline
Old 05-25-2012, 05:43 PM
  #34512
Trader Rating: 38 (100%+)
Or a Tenshock 411 4600kv...
vw addict is offline
Old 05-25-2012, 05:56 PM
  #34513
Anyone know who might have a King Headz chassis in stock? I destroyed my stocker today and we have a big race coming up next weekend. Amain and King Headz themselves are completely out.
MX304 is offline
Old 05-25-2012, 06:03 PM
  #34514
Jake C6R's Avatar
Default Losi Hi-Performance Body TLR8060
Can't wait till I get mine. Ordered 4/17 from Horizon and still shows backordered. Hopefully they ship soon because it looks awesome! Plus, like others here, my current body is adding an extra pound from the big tube of Shoe Goo that is still holding it together!
If it doesn't make it through a practice day at the track tomorrow, l already have a brand new tube and lot's of drywall tape ready to go! May have to run a bigger motor to carry this shell around! LOL
Jake C6R is offline
Old 05-25-2012, 06:26 PM
  #34515
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
RC*PHREAK is offline
