Like Tree9Likes
Old 05-24-2012, 02:04 PM
  #34471
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
That is a very nice looking Body!
kjohnsiii is offline
Old 05-24-2012, 02:29 PM
  #34472
weavty1's Avatar
Thumbs up
Originally Posted by "Smiley" View Post
Here is the Prototype FTW SC Body. Should be released very soon. Be sure to pick one up from avidrc.com
Very badass!!! Do want.
weavty1 is offline
Old 05-24-2012, 02:51 PM
  #34473
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by jlfx car audio View Post
hear is a question . All the setup sheets on losi site is for hard clay/blue groove/high/ med/bite tracks . And all the setup look about the same
Well if u have a hard packed dusty dry track then what??? I know the same setyp is not ideal in these conditions...
Yes we run on indoor clay a lot and do our setup devloping in those conditions because they stay so consistant you can really get a feel for a setup change vs chasing track conditions all day. The result is these indoor clay setups tend to have pretty good balance to them and are usually good starting points for other conditions with tire changes of course. I do not change my car much from indoor clay to outdoor dirt unless I go blue groove racing where I will usually bump up the diff fluids and or shock oil depending on outside temps.
Casper is offline
Old 05-24-2012, 03:01 PM
  #34474
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
BSR- Lol, yea. Very true!
"Smiley" is offline
Old 05-24-2012, 03:41 PM
  #34475
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Well i come from running onroad and track conditions change all day and we know what to do to maintain maximum control as the traction comes up.
This same track condition is the same at our onroad track
1st heat its realy dusty and dry(even after watering it 5heats before)
2nd round its holding a lil more water temps r coming down traction is coming up.
3rd even better but but now fluff is coming up out of the groove.
Mains high traction with tons of fluff out of groove its tacky wet .
How would u handle these conditions
jlfx car audio is offline
Old 05-24-2012, 03:45 PM
  #34476
Casper's Avatar
Tire changes.
Casper is offline
Old 05-24-2012, 03:56 PM
  #34477
Trader Rating: 67 (100%+)
Tire changes.
I love buying new tires, I just don't like paying for them! I'm slowly trying to build up my collection and trying out all the brands and styles I can.
Heres my latest build for my cousin. Identical to mine but his is new and pretty
jdrake19 is offline
Old 05-24-2012, 03:59 PM
  #34478
TCCustoms's Avatar
speaking of wheels...is this a 12mm hex on the scte? Selling my other truck and sticking to just my scte now and have quite a few rim/tire combos so id hate to sell them since some havent even been used, lol
TCCustoms is offline
Old 05-24-2012, 04:11 PM
  #34479
Casper's Avatar
Yes the SCTE uses 12mm hex but be careful on offsets. What was the "other truck"
Casper is offline
Old 05-24-2012, 04:14 PM
  #34480
TCCustoms's Avatar
slash 4wd stock tires, then the rest were the proline split six rims all in 4wd so they were the same offset all the way around since the 2wd slash has diff offsets from front to rear
Old 05-24-2012, 04:33 PM
  #34481
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Break out the acetone the slash rims have a wider offset!
BDRMBULLY is offline
Old 05-24-2012, 04:34 PM
  #34482
Casper's Avatar
Yeah all those will be far too wide on the SCTE. They will phisically fit on the truck but the tires will stick outside the body.
Casper is offline
Old 05-24-2012, 04:37 PM
  #34483
TCCustoms's Avatar
dam you scuba steve....lol! As of right now i still have the 1/8 hexes on the truck becuz this use to be a 810 that i converted but did plan to buy the axles and hexes shortly but wanted to get it up and running first
you can see the 1/8 rims in my avatar to the left
Old 05-24-2012, 05:07 PM
  #34484
Bigz84's Avatar
Trader Rating: 23 (100%+)
Default set up
running 3k in front and middle diffs. What handling characteristcs would i expect if i change to 5k front/middle? I am having traction issues and this is one change i'm thinking of making.
I am running on indoor clay. Suburbs.
thanks for any help
Bigz84 is offline
Old 05-24-2012, 05:18 PM
  #34485
Casper's Avatar
thanks for any help
IF the diffs are too light on oil you can diff out and this can lead to inconsistant handling as you dump power to the tire without traction. Thicker front will add some on power steering but take away a little low and make the car more stable. Thicker center will give more forward drive and not dump the power to spin the front tires as much on power.
Casper is offline
