Like Tree9Likes
Old 05-19-2012, 09:46 AM
  #34276
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
Originally Posted by 8ight-e View Post
So what gearing are people running with the tenshock 411 4000kv these days.. large outdoor tracks w/ 80+ degree weather?
Any limiter used on the ESC or just keeping at max? Timing?
i'd start with a 16T. i run my CL at 85% and timing at 10 (which i think is like 4 degrees on the RX8).
RC*PHREAK is offline
Old 05-19-2012, 09:48 AM
  #34277
TCCustoms's Avatar
Originally Posted by Rockthecatbox21 View Post
Get the hobbywing c-xerun 80 or 150 amp or a mamba max pro. Both great esc's. Ran my hobbywing 150 amp in my scte today and it works great. Both offer a ton of programming options. Btw ran my truck without the front sway bars today and it made a huge improvement in my steering.
What motor are you using and kv rating with the HW?
Should i go with a 4000kv or 4600kv if i get any of the above..pry be the MMP or HW 150a if im gonna do it?
Whats the diff between the xerun 150 and the exrun pro 150 amp or why would one be than the other with the tenshock motor? Thanks
TCCustoms is offline
Old 05-19-2012, 09:52 AM
  #34278
RC*PHREAK's Avatar
i would stay away from the 150A XERun if you're going to be using 2S. the hobbywing SCT-PRO is a better choice for 2S.
Old 05-19-2012, 09:54 AM
  #34279
TCCustoms's Avatar
awesome....with this esc and heavy truck 4000kv or 4600kv in the sc411 motor? i know your the tenshock guy so thats why im asking you, lol! Or i guess what kv do you suggest as im not good with all the technicality stuff of motor esc but i can break the car down and work on it, rebuild whatever but this stuff is kinda confusing and i'd rather ask someone WHO KNOWS rather than someone who MIGHT now
Old 05-19-2012, 10:12 AM
  #34280
RC*PHREAK's Avatar
i like the 4600. the 5200 is also a beast. but especially if you haven't done any lightening, i'd go for the 4600. i've run it as high as a 16T pinion (did that last night) and it stays cool enough (i didn't temp it after the run, but i was at 130 with a 15T after a 5 minute qual).
Old 05-19-2012, 03:45 PM
  #34281
8ight-e's Avatar
Trader Rating: 58 (100%+)
It was doggy till I got the 16t in it.. so I agree tell most to start right at 16t for sure... I'm at 95% limiter right now, and 25 timing. I have no idea what temps I'll pull racing but messing around it was 140's. I'll see how it goes tomorrow at the track and really dial it in.
8ight-e is offline
Old 05-19-2012, 04:03 PM
  #34282
elex300's Avatar
Trader Rating: 106 (100%+)
Turned my limiter down to 55 and the truck felt awesome. Hardley any wheel spin what so ever. I was able to power out of the turns without the truck breaking loose which was really nice. Stayed with a 13t pinion and temps where great 140ish after 8 min. Truck was super dialed. Actually my mod SC was too. Still need to work on the buggy.
Erik
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-amain2.jpg
elex300 is offline
Old 05-19-2012, 04:52 PM
  #34283
TCCustoms's Avatar
so what exactly does the timing do? i kno, go ahead and laugh..i understand the limiter but timing throws me off as to what it will do, whatever esc i get i will be buying the program card with it just so i dont always have to have my laptop but always nice to know what the timing is all about
Bought the RPM rear bumper and # plate through RPM as my LHS says their supplier says 6/20 and i just got done waiting it 5/15 or something and thought it would have been there by yesterday and he said, it still says backordered but til 6/20 so i told him i'll go through rpm just so i can get my truck back up and running. I went this route since noticing that while converting that the stock bumper/mud flaps only cover about 1/2 the tire so i think the angle might help cover up alittle more but we will see how i like it
Old 05-19-2012, 05:14 PM
  #34284
scracer68's Avatar
Default Gearing question
I'm running a Tekin SCX 4.5 motor with a 13 tooth pinion and a Hobbywing SCT Pro esc in my scte. I ran a 12 minute moto around my track and my motor temped at 190 and esc at 140. Esc seems fine at that temp but thats pretty hot for the motor I would think. Should I drop down to a 12 tooth pinion? I'm not running a fan or heat sink on the motor right now.
scracer68 is offline
Old 05-19-2012, 05:31 PM
  #34285
elex300's Avatar
I run a rx8/pro4 4600 no fan,13t pinion,10 timing,limiter at 55 and temps were great after 8 min main. Does'nt HW software have a punch control? I would turn it down a little and your temps should come down.
elex300 is offline
Old 05-19-2012, 06:12 PM
  #34286
TCCustoms's Avatar
yes, it is programmable and here is the chart as they show it on their website...
would the sc411 in a 4000kv for $75 shipped be a decent offer...someone bought it and didnt like it and thats the price and said he has receipt saying he got it the 18th?
Or should i stick to the 4600kv for $90 new?
Old 05-19-2012, 06:57 PM
  #34287
elex300's Avatar
Stick with the 4600 its your best bet for this truck. Lower item 4 Punch down to 4 and see how your temps are.
elex300 is offline
Old 05-19-2012, 07:17 PM
  #34288
scracer68's Avatar
My punch control is already on 0. I put on a heat sink a little bit ago, I'll see how it goes tomorrow.
Old 05-19-2012, 07:28 PM
  #34289
tc5 man's Avatar
16t pinion
man on the Tenshock 4600kv motor ? I know i had my with 0 timing and 0 punch and it still ran about 148 degress after 5 min with a 14t . Il would be afraid to use a 16t holy smokes lol.
tc5 man is offline
Old 05-19-2012, 07:37 PM
  #34290
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by tc5 man View Post
16t pinion
I was running a 12 tooth in my truck with punch control set to 5 and my timing to 1 (lowest setting) and had temps from 150-170. I was also using a castle fan on the motor.
My esc lvc was set to 3.4 volts per cell and it cuts off my battery at around 3.6. What gives?
Rockthecatbox21 is offline
