Like Tree9Likes
Old 05-16-2012, 03:31 PM
  #34141
dtr
dtr's Avatar
Originally Posted by Briguy View Post
Not quite equal parts . Closer to 60% 5K and 40% 3Kto get 4K
Originally Posted by 05PSD View Post
Using some simple math, you would need 56% of 5K and 44% of 3K to get 4K.
Could you post or link some background to these calculations? I understand there must be some fishy chemistry going on. And yes, I saw the formula in the source of the scriptasylum page, but can't see the reason; it's been a looong time since high school.
dtr is offline
Old 05-16-2012, 03:33 PM
  #34142
goehm's Avatar
Trader Rating: 45 (100%+)
Try this:
http://www.scriptasylum.com/rc_speed/oil_mixer.html
Or this:
http://www.rcnerds.com
goehm is offline
  #34143
Trader Rating: 38 (100%+)
Originally Posted by 8ight-e View Post
Stock grease works great in the front and center... Always imo swap to a 2k or 3k max for your rear. No worries.
I'm running 5k front and center, and stock grease in the rear because I haven't had time to get to it. Is working great, although on a tight indoor carpet track(with no front sway) I am walking all over the guys running big 4600kv motors, with the the stock rtr motor and a 14t pinion. They are really just overpowering everything but the back straight...
vw addict is offline
Old 05-16-2012, 03:40 PM
  #34144
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
In theory it should work. I'm not sure you'd benefit from it though. I've been pretty happy with the tray 1/2" back.
Originally Posted by Throwindirt View Post
Hey Chris I have the bump chassis and the battery tray sits 1/2" back from stock will your tray put the tray back even further? Do you know if anyone has used your tray with the bump chassis. Would definitely like to get one if it will work
ChrisAttebery is offline
  #34145
Josey Wales's Avatar
Default carpet mucher
Originally Posted by .AJ. View Post
Here's my problem, ive had the TiNi shock shafts fitted for about 2 weeks and done around 20 packs through them, 3 corners are wearing well and still look fresh, but one rear has pretty much gone silver already
Still good
The bad one :-(
looks like that SCTE has been cutting the rug.
Josey Wales is offline
Old 05-16-2012, 03:47 PM
  #34146
tc5 man's Avatar
Whats with not using the front sway bars ? Does it work better outdoors on a rough track or a smooth track better ? I may try that sometime.
tc5 man is offline
Old 05-16-2012, 03:50 PM
  #34147
I did it so it will rotate better inside on a tight carpet track. Otherwise it's push city, population=you.
Old 05-16-2012, 04:22 PM
  #34148
8ight-e's Avatar
Trader Rating: 58 (100%+)
Actually it will push less with no sway... allows more roll though.. but I've never been on a track that no sway on the front was an issue.. from carpet to high bite clay to hard packed outdoor to loose outdoor. It's also a driving style thing but I've tried all the pro setups and I'll take a scte with no sway and 37.5 oil w/ black or blue springs (stock black work fine too) in the front over ANY setup (#3 pistons ie stockers). Don't knock it till you try it
8ight-e is offline
Old 05-16-2012, 04:28 PM
  #34149
8ight-e's Avatar
Depending how 'packed' your diff is that stock grease feels like a 5k maybe 6k diff fluid.. at least to me... over time it breaks down and feels more like a 4k. I never liked the grease in the rear end even on a high bite track, just personal tastes though. I say stick with anything that works.. never mind what anyone says!!
8ight-e is offline
Old 05-16-2012, 04:50 PM
  #34150
yes, why I disabled the front sway, steering is better, maybe I need to lock down the servo saver cause I could still use more. I imagine it will be worse once I install the CA battery tray, but I will be outdoor soon...
Old 05-16-2012, 05:30 PM
  #34151
Originally Posted by spider882009 View Post
How do I make the tourque rod for the rear work on the stock chassis!!! I went back to it cause I've been running better lap times with a little extra weight!!! Back up to 6.5lbs with Battery and Body!!!
You would be better off adding the weight back in by adding weight to the aftermarket chassis at the ends in front of the diffs.
oldschoolnewb is offline
Old 05-16-2012, 05:46 PM
  #34152
BmainStar's Avatar
Originally Posted by BDRMBULLY View Post
Save your money on weights, get the ape trAy makes jumping alot easier!!!!
Save Your money for track time and practice!!!I say...Ever hand your truck to someone who has never driven a 4-whl drive SCT ? They will jump nose down ,nose up.and maybe if you dont take it away and let them get a few more laps they will figure out how to jump it!!!!!!It is in the run up to the jump, your suspension working proper and the jumps themselves and Practice!!!I have run 3-differant chassis and never had aproblem jumping!!Ever!!!So move the battery, add wieght knock Your self Out!!!!!!
BmainStar is offline
Old 05-16-2012, 09:59 PM
  #34153
nEoNidas's Avatar
Trader Rating: 20 (100%+)
Thanks for the tip.
nEoNidas is offline
Old 05-16-2012, 10:18 PM
  #34154
tc5 man's Avatar
RCPHEAK : Can i use a Hobbywing card on my Toro ESC ? For some reason the Toro programming card is just showing Lipo cutoff and i cant choose anything.
tc5 man is offline
Old 05-16-2012, 10:24 PM
  #34155
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
as far as i know, the hobbywing card will not work with a toro although i've never tried it. i would email [email protected] he has much more experience with the toro's and the programming card. if you send an email now, he'll get back to you in the morning.
RC*PHREAK is offline
