Like Tree9Likes
Old 05-14-2012, 04:25 PM
  #34021
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Yes they run the mod .08 if your looking!
BlackStarRacing is offline
Old 05-14-2012, 05:33 PM
  #34022
I just picked scte I'm running Orion r10pro and Novak 550 4.5 ballistic on a small indoor clay track airland hobbies and maybe westcoast raceway what pinion ?
kahuna2793 is offline
Old 05-14-2012, 05:43 PM
  #34023
Suspended
Trader Rating: 440 (99%+)
So does this truck use MOD1 pinions?
I'm fixing to order a few before my new SCTE gets here and wanna make sure I order the right thing.
MattP is offline
Old 05-14-2012, 05:45 PM
  #34024
One more thing what the best way to clean grease out of diffs? I don't have any nitro spray will any household cleaner work or anything from Walmart?
  #34025
Mxer59's Avatar
Trader Rating: 114 (100%+)
Yes it's a mod 1 pinion I run a 13t with rx8 & pro4 4600kv
Mxer59 is offline
Old 05-14-2012, 06:20 PM
  #34026
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
I use acetone myself; but a lil dawn, hot water, and elbow grease should work fine! Just use somnething like a q-tip to get the bulk of the goo out first...
thecman26 is offline
Old 05-14-2012, 06:28 PM
  #34027
Dano628's Avatar
Mineral spirits and a tooth brush works really good . You can get it at any hardware store , or Home Depot.
Dano628 is offline
Old 05-14-2012, 06:38 PM
  #34028
i use a cheap wood handle 2" paint brush and mineral spirits makes getting into the tight spots real easy
naterpatater77 is offline
Old 05-14-2012, 06:54 PM
  #34029
TCCustoms's Avatar
ok, as you can see by my avatar i have the scte body sitting on something with 1/8 scale rims....Well, im converting my Losi 810 buggy into a SCTN and see people calling out the week points of the SCTE and no offense but there are way too pages to look through and wanted to see from you experienced guys what are the weak points of the 810 since it is what i actually have...
Its riding on the scte chassis, bumpers, rear drive shaft for longer scte chassis and its pretty much done other than the body post and side skirts its done but i know people say the DIFF PINS suck and what else do i need to to bring attention to...I'd like to upgrade to a real .21 rather than the .20 or whatever the 3.4 nitro motor they put in it is...just afraid the driveline might be weak or whatever is weak i will find it the wrong way rather than catch it now....
So other than the diff pins...What else is a weak point that i need to address on my 810? And yes, im keeping the 1/8 wheels at this moment but things can change down
TCCustoms is offline
Old 05-14-2012, 07:45 PM
  #34030
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
What ever the pitch is , a 48 tooth will not fit , it would rub the chassis 1st and you would have to raise the center diff mount and second it would rub the battery tray, i use the ape tray with the modded 43 tooth losi 2.0 and its a mm awAy from rubbing my nano 6.6. Im going back to stock spur. The 43 was great for carpet racing though
BDRMBULLY is offline
Old 05-15-2012, 03:16 AM
  #34031
48tooth with .8 pitch may fit. Teeth on .8 are smaller than mod1, if you compare 40tooth .8 pitch with 40tooth mod1, you'll notice that .8 spur gear will be smaller in diameter.
asalk is offline
Old 05-15-2012, 07:48 AM
  #34032
I like non-chlorinated brake clean, can pick it up at any auto supply or even Wal-Mart for that matter. Works excellent!
Khwilliams is offline
Old 05-15-2012, 01:07 PM
  #34033
What are the driving differences between these two setups? 5/5/3 and 5/7/3 how do they effect the drivetrain? and steering?
Old 05-15-2012, 01:50 PM
  #34034
suby723's Avatar
Trader Rating: 21 (100%+)
5 7 3 will have a little more forward bite over running 5k. I use 7k on larger out door tracks and 5 on an indoor tight track.
suby723 is offline
Old 05-15-2012, 01:52 PM
  #34035
As you go up in the center diff, it provides more of a 4wd feeling and thus more forward grunt. You can kind of think of it as tightening a slipper clutch as you go to thicker oil. Its not exactly the same, but it can help you think about it kind of close.
hacker07 is offline
