Like Tree9Likes
Old 05-12-2012, 10:56 AM
  #33961
Originally Posted by .AJ. View Post
not the point of my post tho, would be nice if they lasted longer than a few packs and they have only been run of astro turf and carpet so its not down to dirt, it seem that the coating on one shaft is just very weak
I agree.All the tini shafts in my scte and 22 wear out really fast.For the extra money were paying they should last alot longer.
Losi57 is offline
Old 05-12-2012, 12:05 PM
  #33962
scracer68's Avatar
Originally Posted by jlfx car audio View Post
Finaly got my snr chassis fitted and body painted ( that was the easy part)
Bad ass.
scracer68 is offline
Old 05-12-2012, 03:34 PM
  #33963
would a tenshock 411 work good with a mmp escand if so what gearing
jy144 is offline
Old 05-12-2012, 10:26 PM
  #33964
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Was doing some maintenance on my truck yesterday and i Noticed some weird binding in the drivetrain on the rear diff. Put the bearing carriers in the diff cases just like their supposed to go in and started to turn the ring gear to check for smooth action. Was super smooth for about 7/8 of the way around until one spot where there seemed to be a kind of "grinding, Bumpy" part where the smooth action would stop. I know it's not my bearings considering i cleaned them out right before. Don't know whether it's a clearance issue, some plastic warped or what the deal is. Really need to know if I need a new pinon/ring gear, diff cases or a new diff housing. Any suggestions?
Rockthecatbox21 is offline
Old 05-12-2012, 11:25 PM
  #33965
Dan
Dan's Avatar
Trader Rating: 68 (100%+)
Am I going to be experiencing puffing problems running a 4 pole 4700kv on 5000mah 40C batteries?
Dan is offline
Old 05-12-2012, 11:36 PM
  #33966
Not if you follow basic lipo battery guidlines. 40C will be plenty for that motor.
Old 05-12-2012, 11:38 PM
  #33967
Dan
Dan's Avatar
I'll be careful to gear it but just worried about having a small window before everyone goes nuclear.
My 3800KV Castle motor was making my batteries run a bit hot, and I'm not running advanced timing. 15T pinion too.
Dan is offline
Old 05-12-2012, 11:44 PM
  #33968
What did you exactly mean by "before everyone goes nuclear"?
I have the castle 3800 in my pede 4x4 and the batteries seem warm but certainly not hot running a 13 tooth pinion.
Old 05-13-2012, 12:49 AM
  #33969
.AJ.'s Avatar
I run my 411 4600kv with a Xerun and a 14t is good starting point
.AJ. is offline
Old 05-13-2012, 01:44 AM
  #33970
Dan
Dan's Avatar
What I mean is when the batteries puff, ESC runs too hot, motor too hot, etc.
I think I'll be fine with motor and ESC, but I'm most worried about batteries. I have puffed a 4700mah 40C lipo running a 4800kv 4 pole.
Dan is offline
Old 05-13-2012, 02:15 AM
  #33971
eddomak's Avatar
Questions?? Hobbywing Xerun features?
For those running the HobbyWing Xerun ESC with a sensored motor, does it support a "smart-start" mode like the MMP? Or is it running sensored at all speeds?
Also, are there any problems with the inbuilt BEC on the Hobbywing Xerun that mean you need to run a standalone BEC?
I am thinking of moving from my MMP to the Hobbywing. Having some problems (probably didn't take care of the MMP enough and it got loose and bumped around), and here in Australia it is probably easier to get a new ESC than to try and really fix the MMP.
eddomak is offline
Old 05-13-2012, 05:37 AM
  #33972
BradS's Avatar
Default Upgrades results
Finally upgraded my truck to the lightened outdrives and a BCE chassis. I ran it for the first time yesterday at Spring Sting at Badlands Myrtle Beach and took 2nd. As for upgrades feedback, I didn't notice a huge difference from the stock chassis and outdrives, so anyone on the fence I wouldn't recommend rushing out to upgrade parts. I upgraded the chassis because I wore out my stock one and bent the front coming up short on a huge jump a couple weeks ago. I did like the BCE chassis, definitely stiffer and seems like it will wear better. Didn't notice a difference on outdrives, upgraded because the stock ones had notches from wear. Truck handled well unfortunately, I was still no match for AE's Max Fluer, getting closer though.
BradS is offline
Old 05-13-2012, 07:23 AM
  #33973
chucko's Avatar
You said maintenance. if it worked before, then its what you did. if it did it before your maintenance then you did not fix it. with out knowing what you did, or did not do, its hard to say. but I would start with taking it apart redoing the inside diff, see it your screws are tight plastics are in alignment gear is straight and not melted and turning it, with out the cases together. are the shims in the right spot.? with it together, spin it, if it binds then its the case. it could be when your putting the shaft on.. pushing it together has that effect. good luck Post what it was when you get it fixed ..Thanks
chucko is offline
Old 05-13-2012, 07:43 AM
  #33974
Trader Rating: 90 (100%+)
Yes, some sooner than others.
Kuya_Kimo is offline
Old 05-13-2012, 08:04 AM
  #33975
ta_man's Avatar
Trader Rating: 164 (100%+)
Default Track Eats Losi SCTE!
At the track yesterday practicing with the SCTE and I miss-judged the line trying to get through the rhythm section. Next thing I know, car comes to a dead stop flipped on its back and I find the black maw of the track trying to eat my car (starting with the left front tire)! This is no joke, nor was it staged - I have 3 witnesses that were there and saw it happen. Had to fight to get my car back. Once it had a taste, the track didn't want to let go.
ta_man is offline
