Like Tree9Likes
Old 05-09-2012, 10:09 PM
  #33811
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
ah yes. i see that now. interesting. i haven't seen the sct-pro in black. i like it better than the blue faux-metal look. i'm sure it's very nice. hobbywing makes top notch stuff. not enough to make me go away from trusty tenshock though...
RC*PHREAK is offline
Old 05-09-2012, 10:19 PM
  #33812
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
Both very nice stuff and very nice motor.
Blitzrockey is offline
Old 05-09-2012, 10:21 PM
  #33813
Mxer59's Avatar
Trader Rating: 114 (100%+)
Originally Posted by 8ight-e View Post
Yup you cannot add voltage to a servo on the internal BEC and expect good things. In order for voltage to make reduced amp draw you need to be able to reduce gearing. Well in a servo you cannot change the gearing so you only add amp draw when you increase voltage; though you get faster speed and more torque.
Typically you can just run a bypass with a 2s lipo setup and jump a wire off your battery direct into your Rx. That or get an external BEC, I wouldn't waste the money on a glitch buster.. fix it the right way. Just my 2c
I prefer running the bec straight to the reciever any time I run a Mamba, but I was just going of what the guy told me with his Losi mmp Novak was having that issue running the pro4 about it sending weird signals, so they did the x-drive boards to fix that. I hear good things about hobby wing though I hear they make the Esc for Orion don't qoute me on it though lol. I looked into doing the hobbywing setup just didn't know what setup I needed
Mxer59 is offline
Old 05-09-2012, 10:24 PM
  #33814
Originally Posted by Blitzrockey View Post
Had the same problem sell the pro 4 and get the hobbywing 540 4pole 4700. Better motor cheeper and u won't have that problem. Its like they made the pro4 to only work with a rx8 to make u buy them. Sad really. I have the hobbywing motor and its as good if not better. Rips good and good temps. EBay for 90 bucks I belive.
haha i was looking at the 4700, sadly none are on ebay at the moment
EDIT: nevermind used the model number in ebay instead of just "hobbywing 4 pole"
EDIT2: ordered.
howse is offline
Old 05-09-2012, 10:41 PM
  #33815
Mxer59's Avatar
EDIT2: ordered.
I can't find the 4700 on there website only 3500?
Mxer59 is offline
Old 05-10-2012, 12:26 AM
  #33816
Hobbywing Xerun 3656SD 4700KV
its on the hobbywing site,it only shows the 4000kv, but their are 4700kv motors as well.
howse is offline
Old 05-10-2012, 01:14 AM
  #33817
ngo8's Avatar
http://www.hobbywing.com/product_show.asp?id=277
This one???
ngo8 is offline
Old 05-10-2012, 01:40 AM
  #33818
Originally Posted by ngo8 View Post
This one???
nope, the one I ordered has a 5mm shaft.
I would post the link but being a new member I am not allowed yet. Just google or ebay Hobbywing Xerun 3656SD 4700KV.
howse is offline
Old 05-10-2012, 02:01 AM
  #33819
.AJ.'s Avatar
Has anyone got a set up for astro turf they would like to share with me????
.AJ. is offline
Old 05-10-2012, 03:02 AM
  #33820
What is wrong my Tekin pro4 4600kv motor because it's heat over 100*C (212*F)? I use 13T pinion and Turnigy 6000mah lipos and Xerun150A esc. I dont have any timing and I drive on small tracks.
GrazyDriver is offline
Old 05-10-2012, 03:11 AM
  #33821
SoCal Jared's Avatar
Thats hot for sure, your gearing is correct and with zero timing/boost you should have no issues.You can also use the current limiter at 70-80% if you run on a small layout to help reduce temps a bit. Heres a few things to check; Make sure your mesh is properly set, make sure there is no visible binding in the drive train, also check the motor bearing and other bearings in the gear boxes.
SoCal Jared is offline
Old 05-10-2012, 03:44 AM
  #33822
WIGMAN's Avatar
Trader Rating: 19 (100%+)
I am having the same problem, goto this thread http://www.rctech.net/forum/electric...s-my-scte.html
There are lots of good suggestions on things to check and try.
WIGMAN is offline
Old 05-10-2012, 04:00 AM
  #33823
.AJ.'s Avatar
Pointless
http://www.rpmrcproducts.com/product...2.htm#SCTEarms
.AJ. is offline
Old 05-10-2012, 04:56 AM
  #33824
omenwolf's Avatar
Trader Rating: 37 (100%+)
Originally Posted by .AJ. View Post
Cool but i agree, I have had my scte for about a year. Bashed it raced it and launched it off bmx jumps and still running original a-arms. the rear bumper looks goofy with the angled flaps. they need to make a better mount for the bumper rather than just the back part.
omenwolf is offline
  #33825
Slotmachine's Avatar
Why does everyone think you need a 4600 4 pole motor on a short track? Just put in a 4000 and stop overpowering your truck , you will be just as fast............
Slotmachine is offline
