If i have this right going from 5/5/3 to 7/7/3 will give me more off power steering and less on power? My truck pulls too hard in the turns causing the rear end to whip around too much. Im trying to correct this. I guess I could turn down my Pro4 4600 because it's over powering and im getting quite a bit of tire spin. Maybe I should try that first. I know the tire choice is good because that is what the other fast guys are running.
Current set up
Dakotah Phend with a few changes for the tight technical track,Blue groove
Running stock pistons,losi 32.5 front,losi 30 rear,Springs black/orange
frnt camber link position 1 on tower
Pro4 4600 13t pinion
Current set up
Is servo set for max travel
try making small adjustments to the oils like 753 or 532. or 533 I like grease best and it helps with temps keeping them lower. also.. lower you shock oil by 10 in each. Thanks helps with traction.. write all you changes down... ONLY do 1 change at a time test see how it works for YOUR driving skill
turning, break and throttle. if it binds any thing it will glitch. the cap stores energy and helps the speed control hold voltage and amps to the receiver. when you bind it draws more power and shuts off other parts of the receiver. either change radios or set you end points also battery might be issue if to small of C ratings. what battery you using Hope this helps
tried a new sensor cable, still no luck with this hobbywing sct pro esc, might have to give the spare mmp i have a try, will need to order a castle bec first.
Forgot to mention when both flashing lights happen on the esc it knocks it out of sensor mode and into sensorless mode. This only happens when i hit full throttle.
electronics i'm using, Hobbywing sct pro, Savox SC-1258TG, Tekin Pro 4 4600kv, lipo is a zippy 2s 35c 6000mhz.
no caps or external B.E.C.'s here, runs real nice
hey guys,
Been running the Losi Ten Scte for awhile now on the local dusty 1/8th track we have, I been using the Tekin Pro 4 4600kv with 13t pinion with diffs 3-5-2.
I have the hobbywing sct pro esc, I keep getting a green and red flashing light while I run around the track, it runs normal and once i complete a lap it flashes. the book says its a Over current protection, motor demagnetization, or motor is over load. I have set the timing to 0 on the esc.
Anyone have any ideas on how to fix this? could it be a sensor problem?
Also since changing the timing to 0 the esc seems to be getting hotter and the motor gets really hot like burn your hand in less than a second hot.
It might be worth checking all of your connections. It might be worth to trying some new wire (would ensure good wire and good solder connections), and if not directly connected - try that/remove any bullet connector while you rewire. Make sure you don't have solder partially connecting two terminals together. I see you've replaced your sensor wire, but make sure your replacement wire is good as well (unlikely, but I have seen it.. ONCE). See if you can borrow a motor to run as those potential causes seem to be motor related. Also try to upgrade your firmware/software to see if that'll do anything.
All relatively free to check. If that fails, try your hand over on the HobbyWing thread. It's mostly on-roaders there, but they do have HW reps there who actively read and respond.
I think you may be overtaxing your esc and or battery.
I dont have data in front of me to quote so maybe someone else can chime in here.
I believe the Tekin 4600 Pro4 will burst draw 720 or more amps
This is right at the top of your ESC ability
Also your battery is only 35C
Will it actually burst 720amps?
I suggest trying a higher C battery, turning your punch down or maybe a 4000kv 4 pole may solve your issue.
Does anyone have a pic of the new version of dif gears? I just bought 3 sets from amain and to me they look like the old version of them. I Just wanna make sure before I send them back.
What seems to be the best all around motor and gearing for this truck? I just ordered a roller from amain today.
