Like Tree9Likes
Old 05-03-2012, 10:55 AM
  #33556
8ight-e's Avatar
Trader Rating: 58 (100%+)
Loamy - hard packed w/ loose top (usually edges, not the main lines)
no loam - hard packed swept or just nothing loose left on top
wet loam - hard packed w/ loose top that was watered down to control dust
blue groove - hard packed, area where you see tire tread build up wearing out on the track
8ight-e is offline
Old 05-03-2012, 11:35 AM
  #33557
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Why is the 4 holes in front shower slotted ? Seems like it would eventualy slide to the top of hole after a few racedays.
jlfx car audio is offline
Old 05-03-2012, 12:24 PM
  #33558
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
gotcha!!! perfectly explained!!
BlackStarRacing is offline
Old 05-03-2012, 03:09 PM
  #33559
chucko's Avatar
got it down to 6 pounds 9 oz. with bat and body...Is that a good weight ?
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-5-4-2012-007.jpg
chucko is offline
Old 05-03-2012, 03:18 PM
  #33560
tc5 man's Avatar
Attachment 916432
That looks good. Although im curious about if you make it lighter does bit make the truck worse jumping wise when its windy outside ?
tc5 man is offline
Old 05-03-2012, 03:27 PM
  #33561
chucko's Avatar
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-5-4-2012-005.jpg
ChrisAttebery's new battery holder installed. Thanks Chris its a nice add on for the losi
Last month I did some testing for Jeff at pro match racing. a new battery 6800 70 C 2 cell and after twenty packs running down to low volt cut off.. it took 6924 MAH back in a few times. some more some less.... this battery is the best for run times. I got, with a pro 4, 14 tooth pin ,..70 % on rx8 speed control... With weighing 6 ponds 9 oz. with body . I was getting 14 to 17 min of hard racing. so any body needing a battery.. to get to those ten min mains with a few laps to play. I have found it. I also tested a few others and if you want that information to compare too,.. pm me.. I wont start a war about whoe's best and how they handle emails of things that happened a yr ago. Jeffs working on getting you good rated batteries, that are better then most for a better price. under 90 you cant go wrong. and you dont have to wait a month to clear customs.. Thanks
chucko is offline
Old 05-03-2012, 03:34 PM
  #33562
chucko's Avatar
with the pro line body cut to the max for venting..... it flys level..... NOW with a 30 mph wind... thats a different story. I really like the way the BCE chassis handles the track. It didnt work to well when I first put it together ,, It took some tuning to get it right.,, NOW when it gets windy Moving the battery around helps,, and thats another story, another day...
chucko is offline
Old 05-03-2012, 04:16 PM
  #33563
Whats up man ? Ionly reason i can think of is the guys over at losi r nutz who wouod allow a shock tower to potentialy move wile racing?
Old 05-03-2012, 04:20 PM
  #33564
tc5 man's Avatar
=chucko;10688124]with the pro line body cut to the max for venting..... it flys level..... NOW with a 30 mph wind... thats a different story. I really like the way the BCE chassis handles the track. It didnt work to well when I first put it together ,, It took some tuning to get it right.,, NOW when it gets windy Moving the battery around helps,, and thats another story, another day...
Oh ok yea i had some holes cut into the stock SCTE body but not all of them i did notice a couple of times last Sunday while i racing it did funny things in the air . The wind wasnt blowing gusty about 20 mph.
I think actually a heavyer body would help with that i think. My SCTE is stock pretty much.
tc5 man is offline
Old 05-03-2012, 04:34 PM
  #33565
chucko's Avatar
The difference between the losi and the pro line body is... for me... pro line .9 oz heaver. both with three colors, same, stripping, and decals. same holes. no wings on stock losi body. holes in front win shield and back fans cut out
chucko is offline
Old 05-03-2012, 04:39 PM
  #33566
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Which holes exactly?
BashemSmashem is offline
Old 05-03-2012, 04:55 PM
  #33567
This has to do with the angles introduced on that front clip between the tower and the diff case. The tower keys into the case so there is never any reason for it moving. But those holes are at an angle due to as you screw the twoer back in, it changes angles...sounds wierd but before we did this, customers would strip things at times becuase they were not careful.
hacker07 is offline
Old 05-03-2012, 05:01 PM
  #33568
BmainStar's Avatar
Originally Posted by Dakar Dad View Post
Exciting West Coast R/C Raceway race with Chris Blais in 4WD Short Course having a close race with second place and only finishing in first place near the end. Racing on Proline tires bringing him to get the first position at the finish.
+ YouTube Video
And a whole lot more!
Sick stuff for sure!!Thats talent for sure! Thanx for sharing Martin!!
What? Alum tower???
BmainStar is offline
Old 05-03-2012, 05:07 PM
  #33569
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Attachment 916433
Tell me more, sounds interesting!
I was looking at getting some of the 6600 nanotechs, how would these compare? The 70C sounds interesting...
thecman26 is offline
Old 05-03-2012, 05:15 PM
  #33570
yea the stock towers have a sloted hole and so does the snr graphite as i seen them on there web site.
