Like Tree9Likes
Old 04-30-2012, 12:28 PM
  #33436
kman16jr's Avatar
Trader Rating: 56 (100%+)
hey guys which bearings are used for diff pinions 5x11x4 or 5x10x4,Im thinking its a 5x10x4 but just wanna make sure.
kman16jr is offline
Old 04-30-2012, 12:50 PM
  #33437
I am trying to decide between a tenshock sc411 4000 or 4600 and need help. We run 10 min mains on a medium size track. Which motor would better and also what pinion gear should I start out with? Would I be able to make a 10 min main with a 5000mah battery on either if the motors on a track that is loamy.
robzzz is offline
Old 04-30-2012, 01:04 PM
  #33438
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
All depends how trigger happy you arebut i doubt you'll be able to make 10min with either motor with a 5000 mah pack
BDRMBULLY is offline
Old 04-30-2012, 01:05 PM
  #33439
RC*PHREAK's Avatar
Trader Rating: 141 (100%+)
i agree. 10 mins on a 5000mah battery is unlikely. between the motors, i like the 4600 better, but to make 10 mins, i would use a 6000mah battery.
RC*PHREAK is offline
Old 04-30-2012, 01:51 PM
  #33440
They are the first one, the 5x11x4
hacker07 is offline
Old 04-30-2012, 04:16 PM
  #33441
tc5 man's Avatar
Do you guys know what the offset rims the SCTE uses ? And i noticed also there might be a tight spot or something on the spur gear because i had my gear mesh set with a little bit of play well i take it off the track and theres no play and i turn the spur gear around more and there is play I did use a washer and blue locktight on the top motor mount screw maybe the motor mount moves or something ?
tc5 man is offline
Old 04-30-2012, 04:40 PM
  #33442
Trader Rating: 20 (100%+)
Check the bearings that the center diff rides in. I have noticed the same thing happening when mine start going bad.
MX304 is offline
Old 04-30-2012, 04:43 PM
  #33443
tc5 man's Avatar
Ok il check the center bearing i was thinking also its the plastic diff mount and top piece flexing also .
Im looking at this part looks good and will solve that issue .
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-khz-scte-035.jpg
tc5 man is offline
Old 04-30-2012, 05:53 PM
  #33444
Hey symm, how is the carbon fiber chassis looking on the bottom now? do you have a wrap or anything on it to prevent scratching or is it wearing fine as is? I need to trim my scte down a bit, sitting at 6lbs 12oz rtr as is.
USP45 is offline
Old 04-30-2012, 05:54 PM
  #33445
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
I am looking at that too, but amain shows them on backorder, and they have been on backorder a while!
thecman26 is offline
Old 04-30-2012, 06:08 PM
  #33446
Trader Rating: 19 (100%+)
I bought mine direct from KHZ shipped it quick and its a great part. Their chassis goes one step further and rotates the mount.
pooldoc is offline
Old 04-30-2012, 06:09 PM
  #33447
thecman26's Avatar
Great idea!
Old 04-30-2012, 06:12 PM
  #33448
tc5 man's Avatar
What offset rims do the SCTE use without mods ? And i did not break the bumpers lol.
Im going to just cut off part of the rear bumper i thought the mud flappers keep the truck cleaner but they dont lol . But they look cool !
RCman: Il look around other online stores or the King Headz site to get it does it work on the stock chassis though ?
tc5 man is offline
Old 04-30-2012, 06:33 PM
  #33449
teknorc's Avatar
FYI,
The Tekno RC driveshaft kits are all in stock now.
http://www.teknorc.com/index.php?cPath=111
teknorc is offline
Old 04-30-2012, 06:52 PM
  #33450
Feint Motion's Avatar
Trader Rating: 24 (96%+)
Originally Posted by teknorc View Post
FYI,
Nice.
going to grab the shafts and outdrive kit
Feint Motion is offline
