Like Tree9Likes
Old 03-13-2011, 02:18 PM
  #3271
Trader Rating: 90 (100%+)
Just got done charging my battery from my 10 minute main yesterday. 1 practise lap, geared 12t pinion, 30 degree on can, no timing in esc, Novak 4.5/Havok pro, 60c/5500mah battery and I put back 3895mah. I think a 10 minute main is max for these trucks unless we start using 8000 or more batteries.
b121774 is offline
Old 03-13-2011, 02:32 PM
  #3272
Originally Posted by infanterene View Post
Ran the Truck last night and it felt pretty good. My tekin 4.5 is running hot 190 and I ran out of battery on the last lap.
I'm using a 14t pinion and a 30c 5200. Our mains are 10min and we run on an outdoor track.
Is anyone else having trouble making time?
Check to make sure your sensor side endbell has not moved.I've seen 2 tekin 4.5 scx4 motor loose right out of the box. 1 died of heat exhaustion, the other was tightened before it was run. Always check to make sure the sensor side endbell is tight.
Neil426 is offline
Old 03-13-2011, 02:47 PM
  #3273
smokinu's Avatar
Trader Rating: 71 (99%+)
Originally Posted by Frank L View Post
Smoke did you get a Losi???
no i was cornering.
i might end up with a 4x4 again soon but it wont be a losi!! but as long as they are racing where i am i will keep up to date on them so i can help the people at the local track.
smokinu is offline
Old 03-13-2011, 02:49 PM
  #3274
smokinu's Avatar
yeah jason. lol some 6000mah packs will make 15 mins.
not to sure if the esc/motor combos can go that long though.
smokinu is offline
Old 03-13-2011, 02:52 PM
  #3275
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
For all who are interested in replaceing the screws that hold the ring gears and spur gear too the diff housing (stockers are 1/16 heads) .
The screws for the Ofna Hyper 10SC are 2.5mmx8mm and are a perfect fit , best of all they use a 2mm hex so no more stripped screws !
http://www.nitrohouse.com/Car-Parts-...duct_info.html
BashemSmashem is offline
Old 03-13-2011, 03:21 PM
  #3276
draggin87's Avatar
Trader Rating: 32 (100%+)
ill add a 15t pinion on the list. I still dint think it will be what i want it to be....I loved it with the 4 cell and mamba 2200.
draggin87 is offline
Old 03-13-2011, 03:46 PM
  #3277
BmainStar's Avatar
Originally Posted by draggin87 View Post
I ran my truck again with the RX8 and novak balistic 4.5 combo and im quite disappointed with the topend performance of this combo. Im running a 14t pinion with a Thunder power 5200 50c 2cell lipo.
Im thinking that 3cell might be better. Our track is large with a 175 foot straight.
The truck on the other hand felt awsome in the infeild. It cleared everything and didnt washout everywhere on the dusy surface.
Sad to say though that it is down for the count with a broken front arm, shock top, and a bent steering turnbuckle.
Manual says 16 tooth for a 4.5 and 17 for a5.5!With the RX8 and Tekin sc4x4 5.5 I ran a 17 and it ran a little warm155-165 but it just flat would haul!I went to a 14 tooth for an small indoor clay track and it was perfect on that small layout with temps at 130 deg!
If you can keep it from getting too hot ,try a 16!!
BmainStar is offline
Old 03-13-2011, 03:52 PM
  #3278
Trader Rating: 31 (100%+)
Default Diff Gear shafts. PLEASE HELP
I ran the truck in our first points series race here in Oklahoma and it was dialed! I won the A-main! Great first race! I am Running a Tekin RX8 and scx 4.5 with Thunder Power 5300MAh 65c packs. I have put 4 packs in practice and we ran (2) 6 minute heats and a 7 minute main. I am running 5-5-2 in the diffs. I decided to pull apart my diff to go with 7 in the center for more acceleration and sure enough my gear shafts are grooved! Parts are not available until June! How much longer can i run before failure? Has anyone found a replacement? I dont want to have to hang up my truck until June after winning the first points race!
flysullivan is offline
Old 03-13-2011, 03:55 PM
  #3279
xxfile's Avatar
start reading about page 200
xxfile is offline
Old 03-13-2011, 03:57 PM
  #3280
instigator's Avatar
Trader Rating: 18 (100%+)
Are you running any timing on esc, motor?
instigator is offline
Old 03-13-2011, 04:28 PM
  #3281
I just read through and have three sets of sc10 rebuilds on the way. Thanks
Old 03-13-2011, 04:36 PM
  #3282
shortcut's Avatar
Trader Rating: 55 (100%+)
I'm using a mmm. I actually only got 8:30. I ran the speed control straight out of the box so I don't know what if any timing is there.
Is the MMM sensored ? I know one of the castles is sensorless.
shortcut is offline
Old 03-13-2011, 04:41 PM
  #3283
Frank L's Avatar
Trader Rating: 148 (100%+)
The MMP is sensored and the MMM is not
Frank L is offline
Old 03-13-2011, 04:43 PM
  #3284
Does the truck come with all the sway bars and both ackerman options?
DJG24 is offline
Old 03-13-2011, 04:47 PM
  #3285
Trader Rating: 103 (100%+)
yeah but at $11 per diff that is rediculous, but may be the solution until we get our items from losi / aftermarket folks.
dan-o is offline
