Nah, I ran the 5200 sc401 (unsensored) for the last couple weeks on our small, tight indoor track with a 12T. Never got over 120.
With brushless motors, you get faster, more power, more torque everywhere when you gear up (not taking into account traction, esc, and battery limitations). The higher the load, the more amps they will draw (when you gear up, you are increasing the load). With that, you gear for the speed/power you want while making sure your temps are in check. 14T on a large track should be plenty.
Are the stock Losi bodies pretty good on these trucks? Don't want to waste time painting it if it is going to fall apart. Thanks
The bodies will crack first just in front of the windshield most likely but they do hold up pretty well. Not really any worse then anything else I see out there.
thanks
we are using a hpi body post mounted in the hole in the top plate with a z bend and it comes thru the the center hole in the windshield. the post uses a pivoting mount just like the stock body mounts.
Shoe Goo and fiberglass drywall tape at any and all stress points(body mounts , front fenders , rear end ect.) will make a body last 4-5 times longer than one without it .
i know all radios are different and servos...esc's and motors.....
I wanted to get an idea of what sub trim, epa, expo, etc....
also drag brake if any?
EXPO is something some play with for throttle as it can give more punch for stock on high traction or help with getting the car rolling out of a corner in low traction.
Drag brake. Depends on the car. For 4X4 SC the trucks tend to have plenty of natural drag due to all the moving parts we tend to turn this off but for something like a 2wd buggy or TC this can be a great tuning aid to help the car naturally slow down for some corners and can be much more conisistant then relying on using the trigger. All things you need to experiement with so you can see how it effects things so you know when you get into certain situations you can make adjustments to help.
Things like sub trim and EPA are used to adjust your cars servo to center and adjust the left and right throw to get max steering from your car left and right.
Ok that provides me with a starting ground.... how is dual rate utilized?
thanks
Daryl
Dual rate will take away steering from both left and right at the same time. If the track is loose or the car is oversteering bad this will desensitize the steering by taking away some throw and numb out the steering some. Something that is used a lot more in onroad then I see it in offroad. In offroad we counter steer a lot and full lock is good for that. In something like pan car this may be required otherwise the car will steer far too much and be uncontrollable.
I have a quick question, what are these for?
http://www.amainhobbies.com/product_...-Screw-Washers
I am not quite sure what they are for as the description is a lil confusing...
These washers work great with 3mm electric motor screws any time the motor mount has an adjustment slot in it. Regular washers tend to deform down into the adjustment slot - you won't bend these bad boys. They are extra thick, and are case hardened besides, so crank down on those motor mount screws to your hearts content...or untill you strip the screw holes in the motor can...
What inserts are recomended for the front end? Is anyone running .5 or 1 of additional kick up? How does it affect steering?
Every setup I have seen has used zero inserts everywhere in the front.
Also, in general, with the tower laid back more, it will feel a little more controlled going over small chop or bumps, but it will be less forgiving on big ones.
