Like Tree9Likes
Old 04-09-2012, 09:00 PM
  #32461
8ight-e's Avatar
Trader Rating: 58 (100%+)
Anyone looking for a deal on a roller check out this sale.. LINK
Thanks.. see notes ask ?'s first, but quick
8ight-e is offline
Old 04-09-2012, 10:27 PM
  #32462
Trader Rating: 41 (100%+)
Casper,thanks for the RX8 set up.this truck is SICK FAST with this set up and the PRO4600.it ran 135 after 18min of hard WOT street passes..
rifraf is offline
Old 04-09-2012, 11:03 PM
  #32463
tc5 man's Avatar
Now i noticed a few on here have cut off the ESC mount off to take weight off well i already reamed some holes in the battery tray and the ESC mount but im thinking cutting off the ESC mount will for sure sure take a chuck of weight off my stock SCTE .
With the ESC mount cut off would two pieces of double sided tape to the job pretty good and protect the ESC ?
tc5 man is offline
Old 04-09-2012, 11:37 PM
  #32464
Dano628's Avatar
Kyosho makes some nice thick servo tape that is perfect for what your looking for .
Dano628 is offline
Old 04-10-2012, 05:20 AM
  #32465
HomeMade's Avatar
Does any body know if the TEN-T springs and pistons are the same as the SCTE. Spring rate and number of holes in the piston? Thanks.
HomeMade is offline
Old 04-10-2012, 05:49 AM
  #32466
elex300's Avatar
Trader Rating: 106 (100%+)
Yep same thing.
elex300 is offline
Old 04-10-2012, 09:05 AM
  #32467
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
The springs are the same, but I recall that on mine the pistons only had two holes drilled all the way through. The other two were plugged in the middle.
ChrisAttebery is offline
Old 04-10-2012, 09:13 AM
  #32468
Casper's Avatar
Trader Rating: 34 (100%+)
They should all be 4 hole.
Also did anyone see this annoucement?
Makes bleeding shocks emulsion style way easier!
http://www.tlracing.com/Products/Def...ProdID=TLR5062
Casper is offline
Old 04-10-2012, 09:22 AM
  #32469
Buster661's Avatar
Yahoo !! That was the only part of my old SC10 I missed. When can we get them ???
Buster661 is offline
Old 04-10-2012, 09:24 AM
  #32470
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
thats cool but for those of us that have the tlr kit.... will they sell just the rings?.....
BlackStarRacing is offline
  #32471
Casper's Avatar
They are showing 5/10 in the system.
Casper is offline
Old 04-10-2012, 09:40 AM
  #32472
goehm's Avatar
Trader Rating: 45 (100%+)
Originally Posted by thecman26 View Post
Totally normal! I have the 6000's and haven't hit LVC yet but I regularly put back in between 5000 and 5600mah after 12-15min of practice. I think they are underrated on capacity. Great packs for the money!
Thecman: He said he put 6100 back into a 6600 pack. He didn't put 6100 into a 6000 pack, so I don't think what he's reporting is normal. Underrated would mean that he should be able to put more than 6600 into his pack.
Gas Rat: I'd charge the pack up, then do a discharge, and then on the next charge monitor the mah returned to the pack. I believe it should meet or exceed the 6600 rating if the pack is not damaged.
goehm is offline
Old 04-10-2012, 09:44 AM
  #32473
goehm's Avatar
Also - some chargers have a max mah or max time for charging. I think mine cuts off automatically at 5800mah. So if your charger is timing itself out, run another charge to top the battery off and then add the two mah numbers together.
goehm is offline
Old 04-10-2012, 10:08 AM
  #32474
You DO NOT want to run your packs down to 0 capacity on a regular basis. This will seriously shorten the lifespan of your packs. You should set your LVC so that you put 80% or less of the capacity back into the pack.
Old 04-10-2012, 11:00 AM
  #32475
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Figures, i had almost every upgrade, i just found the alloy shock caps with bleeder holes last week and installed them lol
BDRMBULLY is offline
