next dumb question - how do you bleed it? What keeps the fluid from escaping out of the hole in the shock collar if you remove the middle of the bladder?
the hole in the cap is below the top of the gasket. when you bleed it you fill it to the top put the cap on holding it at around 45 degrees. slowly screw the cap on at the angle with the hole pointed to the top with the shock compressed all the way in.. do that until holding the shock level to one another and compress both and see if the rebound the same.. if they dont do it over tell they match in equal rebound..
Those of you using the Attebery diff inserts, do you still need the small shim that goes between the insert and the sun gear with this upgrade?
Man it was so much fun, this truck is so forgiving and adjust in the air. Can't make big adjustments in the air like my Truggy but pretty good!
I only broke a rear bumper support, everything else was flawless! Not ready to give up on nitro but it's nice to have both! I think this truck was a great purchase, and the Tuning kit with the RX8 and Pro4 4600 make it fly! Thanks everyone for the tips as I continue to figure this electric stuff out!
How do I increase my power- on steering on my SCTE Ten? My car steers fine with power off, but understeers terribly when I add the power. I've listed the details of my setup below, but I'm wondering which tuning options have the biggest effect (in what order) to increase power-on steering...balance, shocks, diff oils, etc. Is there a guide somewhere like a troubleshooting guide?
My set up last time at the track was very close to identical to the Dakota Phend set up sheet on the losi web site. Only change was the RC Shox two stage shock pistons with 32.5 front fluid and 30 rear fluid.
The car turned around corners on power very effortlessly with this set up, the Jammin cnc aluminum chassis, and the stock short rear chassis brace.
Next time out I am upping the shock fluids, I am pretty sure I can get away with it with the increased rebound dampening of the two stage pistons. I am trying 40 front and 35 rear with silver front spring and purple rear. I am also going to the middle thickness sway bar in the rear.
Thanks,
Joe
Losi SCTE rolling Chassis
JR Z9100S Steering servo (.06 sec 180 oz)
Suburbs tires
Tekin 4600
Mamba Max
TLR Tuning Kit
Diff oils 6K (Front), 5K (mid), 3K (rear)
450 Shock oil
13 pinion, Stock Spur
More info:
On a clay indoor track (OC RC raceway)
I've got the servo saver cranked tight and glued it so there is no play.
Thanks,
Joe
Suburbs tires
Tekin 4600
Mamba Max
TLR Tuning Kit
450 Shock oil
More info:
Here is JQ's The Guide
http://jq-products.com/the-news/43-t.../160-the-guide
I just got my new hd lightened out drives and ripped into my front diff to start. I decided to clean out the grease and put 5,5,3 in and I noticed my replacement diff pins from horizon with only 8 packs on them were super worn!! Badly gouged!! Like they just sent me the soft pins to replace my original soft pins WTF?? Ryan what could have caused that??? I was so mad I have not opened my other diffs but I suspect I replaced all those pins for nothing!! I know I need Chris pins but thought Losi/Horizon took care of the soft pins guess I got another bad batch??? My truck was bought the second week it was released by the way!!
Ok - rookie question here. I ordered the HA shock bodies and I noticed threads on the tops on bottom. Obviously the top is where the shock cap threads on, but what are the threads on the bottom for? on the original blue shock bodies, there is a black piece on the bottom, but this doesn't seem to be removable.
Thanks for the help
Thanks for the help
Thanks for the help
Thanks for the help
