Like Tree9Likes
Old 04-02-2012, 04:59 AM
  #32026
FLHX1550's Avatar
Has anyone tried the M2C rear adjustable hinge pin kits? I have to buy the entire TLR Adjustable Rear Adjustable kit anyways, just to get the rear plate.
M2C SCTE Rear Adjustable Suspension Kit
FLHX1550 is offline
Old 04-02-2012, 05:01 AM
  #32027
symmetricon's Avatar
Trader Rating: 27 (100%+)
Originally Posted by FLHX1550
Any idea on availability of the TLR Ti-Coated Hinge Pins? Of course they are out of stock everywhere I have checked.
First race weekend out with it and ripped a rear hinge pin right thru the Adjustable Rear Toe Plate like so many others.
Are there any other hinge pins out there that work, or are there ones I can cut to length?
Does anyone know how long the Ti-Coated Ones are? (TLR6080)
Get some drill blanks and cut them 1mm longer. The hige pin is approx 3.4mm. I posted weeksa ago about which #drill blank it was but have sincethrown away the package...
symmetricon is offline
Old 04-02-2012, 05:05 AM
  #32028
Originally Posted by symmetricon
I just bought some from the local machinist tool store, and they are #29 HSS drill blanks. I payed 77cents a piece. I cut them 1mm longer.
I just installed them and they work perfectly.
here we go
Old 04-02-2012, 05:56 AM
  #32029
FLHX1550's Avatar
Do you know what the over-all length needs to be?
FLHX1550 is offline
Old 04-02-2012, 06:50 AM
  #32030
Stock is approx 58mm, so go 59mm in length.
Old 04-02-2012, 08:02 AM
  #32031
Originally Posted by Josey Wales
Can someone scan aND SEND A copy of their TLR TUNING KIT MANUALS TO ME. PLEAASE I can't find these. I know it was posted here before but not sure how to search for it. I think hacker07 may have posted it. But I can't Find it
The only instructions the TLR tuning kit comes with are the ones for the inserts for the adjustable pivots. You can look at the ones for the 8ight as they are the same.
These should be in stock in about 2 weeks time here. They are 1mm longer than stock. We made them this way for some of the extreme angles that those blocks make.
hacker07 is offline
Old 04-02-2012, 11:07 AM
  #32032
KarBro's Avatar
The TEN-SCTE seems to bee out of stock almost all over? I hope they will be in stock coming the end of this month (payday) so I can order one.
KarBro is offline
Old 04-02-2012, 11:13 AM
  #32033
Casper's Avatar
Trader Rating: 34 (100%+)
RTR's are in stock. Rollers are expected around 4/22
Casper is offline
Old 04-02-2012, 11:25 AM
  #32034
vasidudu's Avatar
Proof is in the puddin' as they say...
vasidudu is offline
Old 04-02-2012, 01:19 PM
  #32035
Just got an update on these. They are in the air and on the water. This means we should have them late this week or early next and then right back out the doors.
hacker07 is offline
Old 04-02-2012, 02:20 PM
  #32036
larlev's Avatar
Originally Posted by BDRMBULLY
Anyone using viper copperhead with 5150 have a good set up with pro guage. Combo just doesnt have what my rx8 n pro 4 4000 had (sent in for repairs)
Thanks alot
Profile 5, change timing to 5.
That combo has every bit as much as the Pro4 does. What pinion you running?
Need to be 14-16t
larlev is offline
Old 04-02-2012, 03:00 PM
  #32037
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Need to be 14-16t
Just a question, why do you run timing in a 4 pole high kv? Was there any drastic temps changes with that much timing? When I had the 1410 timing added 15+ degrease of heat so ever since ive never used it. I'm currently using profile 5 as well
Mr.juarez is offline
Old 04-02-2012, 03:03 PM
  #32038
8ight-e's Avatar
Trader Rating: 58 (100%+)
I think most that put timing say on the 4600 pro4 are also running with a limiter near 75%
8ight-e is offline
Old 04-02-2012, 03:10 PM
  #32039
Casper's Avatar
Timing and current limit are two very different things. Current limit can take away spikes at startup and smooth things out some and let the motor run a little cooler. Adding timing will give more top end but tend to make the motor run a little hotter.
Casper is offline
Old 04-02-2012, 03:14 PM
  #32040
Mr.juarez's Avatar
Whichs is what I was dealing with the 1410. The viper is still a 4 pole like the castle. So to clarify this, is it a "good" thing or not to time a sensor less 4 motor that is pass 4000kv?
