Like Tree9Likes
Old 03-30-2012, 09:47 PM
  #31921
cwilkinson's Avatar
Originally Posted by RC_Woody View Post
Thanks! I'm bookmarking these puppies for future reference. I'm sure I will forget , or when in another 3 pages someone else asks
I see you're in St Helens, OR do you race @ PRCR?
cwilkinson is offline
Old 03-30-2012, 10:06 PM
  #31922
fishboy's Avatar
Quick question for the guys running the Tekin RX8... I walked out of the hobby shop today not paying attention with 14ga. wire for my ESC. Can I run this or should I get 12ga.?
Thanks,
Greg
fishboy is offline
Old 03-30-2012, 11:06 PM
  #31923
Casper's Avatar
Trader Rating: 34 (100%+)
Thanks,
Greg
Assuming it is high quality wire it will be just fine. 12ga IMO is a little over kill most of the time and the wires on the SCTE are not all that long so resistance is pretty low.
Casper is offline
Old 03-30-2012, 11:18 PM
  #31924
RC_Woody's Avatar
I have gone there and practiced a couple times last fall but its a good hour drive one way. I have been mainly playing at Firridge Raceway in Scappoose. Its about a 10min drive and we all just have a blast.
RC_Woody is offline
Old 03-30-2012, 11:25 PM
  #31925
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by DoogieLee View Post
Thanks man, after doing some looking around, I found the Losi shock matching tool, looks like i'll be ordering one of them as soon as the TiNi hinge pins and shock shafts come in stock.
Thanks for the reply
I have this tool too and used it 1x the first day I got it, now it's just taking up space in my tool box
Originally Posted by hacker07 View Post
Just thought I would show the weight of my vehicle ready to go, dirt and all. Requires a bit of a different setup now...5.834 pounds...
What lipo is in that puppy these days? Lipo that is in the picture (under the lid) ;P
8ight-e is offline
Old 03-30-2012, 11:32 PM
  #31926
RC_Woody's Avatar
Default AMain Hardened front/rear out drives in stock
FYI - A Main Hobbies has hardened front/rear out drives back in stock.
I have been watching for a couple of weeks, so a few might of been as well.
RC_Woody is offline
Old 03-30-2012, 11:53 PM
  #31927
cwilkinson's Avatar
I live 15 miles north of longview so nearest track is hour and a half away for me never heard of the track in scappoose is it offroad?
Old 03-31-2012, 04:22 AM
  #31928
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Originally Posted by speeed View Post
Anybody know if Slash 4WD and Jammin SCRT10 4WD wheels fit on losi scte ten short course truck?
Thanks.
You can use pretty much anything with a 12mm hex. I prefer to use slash rear offset wheels, they aren't as wide as the slash fronts.
thecman26 is offline
Old 03-31-2012, 06:09 AM
  #31929
Trader Rating: 20 (100%+)
got mine from a-main this moring thanks for the heads up.
xxxtruck is offline
Old 03-31-2012, 06:15 AM
  #31930
lethal19's Avatar
What is the best way for rebuilding diffs so they do not leak I am going to change out my fluid and I don't want this to be like my 8ight where the fluid is all over the chassis in a week
lethal19 is offline
Old 03-31-2012, 06:22 AM
  #31931
what is the part # for the new shock shafts and hinge pins.
xxxtruck is offline
Old 03-31-2012, 06:35 AM
  #31932
8ight-e's Avatar
make sure they are clean..
1)pop out the inserts in the diff cups (replace if you have a lot of wobble in your outdrives)
2)apply black grease to the edge that will fit into the edge of the plastic diff cup
3)put back together (squish it tight) wipe off any excess grease that comes out (if you over did it)
4)snag outdrive, use small amount of black grease to fill the groove (there is no ring seal like on the 8ights, but I use this on method on the 8ights as well)
5)install the outdrive (if doing with an 8ight bearing first ;P)
6)if using new seals (good idea) get damp with some used shock oil or similar
7)install, repeat for other side.
8)fill diff fluid, pretty full push down top gear and make sure the fluid is not going to over flow.
9)get gasket, use some used shock oil (even diff fluid) to coat or 'wet down' the gasket (don't need to soak) both sides
10)install remaining parts take screws down in a nice even fashion as they snug up go back and forth (one side to the other) sungging them down to final tightness (ensures a good smooth fit w/ gasket).
Seal should last until next service.
**As larlev notes below (great point) if you have an uneven surface, sand it a touch (doesn't take much) this would be a 1x thing for a new housing, that said I've yet to sand any of them.
8ight-e is offline
Old 03-31-2012, 06:38 AM
  #31933
larlev's Avatar
Most important thing is to sand the face of the housing flush. Also do not over tighten the gasket.
larlev is offline
Old 03-31-2012, 07:39 AM
  #31934
RC_Woody's Avatar
yep un-covered so weather permitting of course. Its ran by a guy named Darrell Day he opened last summer. If you ever go to Tammie's or HobbyTown I think he has flyers up.
Also go to:
http://www.portlandrc.com/forum/index.php?topic=236.0 a little forum write up I did on it. (I think you have to register, but its free)
and lastly look up Darrell Day on Facebook. He will usually post up how the track is looking for that day, He also has pics and video's of the track.
I guess I need to talk to him about an official website lol
Woody
RC_Woody is offline
Old 03-31-2012, 08:25 AM
  #31935
RC_Woody's Avatar
http://www.tlracing.com/Products/Def...ProdID=TLR6080
http://www.tlracing.com/Products/Def...ProdID=TLR5063
http://www.tlracing.com/Products/Def...ProdID=TLR5064
So looks like
TLR6080 - Hinge pins
TLR5063 - fr shock shafts
TLR5064 - R shock shafts
RC_Woody is offline
