Like Tree9Likes
Old 03-26-2012, 07:23 PM
  #31756
Gas Rat Racin's Avatar
Trader Rating: 37 (100%+)
Just wanted to let you guys know I have 2 Brand new never used 6.6 nano techs for sale. I'm asking 60 shipped each. Pm me if your interested.
Gas Rat Racin is offline
Old 03-26-2012, 07:41 PM
  #31757
elex300's Avatar
Trader Rating: 106 (100%+)
Originally Posted by symmetricon View Post
I just wanted to post this up because my results were staggering. I finaly got around to putting the v2 dual stage scte pistons(rcshox) in my truck this last friday, and did alot of tuning. My previose fastet lap at our track was 35s, well after some tuning and playin around with tires, I was able to best my previous fastet lap by 1.5s
and i was able to hit 12 laps for the first time in a 7min main, and if I had run perfectly clean, I have no doubt that i could hit 13 laps. I was blown away! I hit several 33.5s which is very fast.
Oh, and I ordered the 120mp esc from brushlesshobbies.com for 59$ and found that it is the exact esc as the Xerun 120amp esc. Its an amazing deal. It ran great all friday. The esc never got over 110degs running the pro 4 4000kv 15/40 with 20deg of turbo, and the mtor didnt get over 160.
Good to hear some feedback on the speedo. I talked to one of the better racers at the onroad track the other day and he said the Hobbywings are really solid. Smoothe like Lrp with Tekin punch. Not to mention I could sell my back up RS pro and buy 3 of these.. So you don't need a card or anything but a usb cable to program these?
elex300 is offline
Old 03-26-2012, 07:53 PM
  #31758
symmetricon's Avatar
Trader Rating: 27 (100%+)
Nope, it comes with a usb adapter cable... and i put the newest speedpassion software on it, and it felt amazing comming from an xerun 1/8 80amp esc.
symmetricon is offline
Old 03-26-2012, 08:57 PM
  #31759
8ight-e's Avatar
Trader Rating: 58 (100%+)
Anyone looking to unload a new / like new RTR losi 550 2800kv motor that upgraded? LMK.
8ight-e is offline
Old 03-27-2012, 04:32 AM
  #31760
vasidudu's Avatar
Default Castle 1410 / 3800Kv on 3s?
Hi there all,
Would like to know if it is possible to run CC 1410 / 3800Kv on 3s.
Was running my CC 2400Kv (1415) on 2s first then tried the 1410.
Still not enough peps on our 1/8 track.
We do not have limitations in terms of cells.
Is the 3800Kv (1410) ok to run on 3s? It is given for 3s max on CC website...
Thx for the info.
Best,
V
vasidudu is offline
Old 03-27-2012, 04:47 AM
  #31761
8ight-e's Avatar
Originally Posted by vasidudu View Post
Hi there all,
Thx for the info.
Best,
V
Should be fine, 3s puts it at 42k rpm, well within the motors specs. I'd gear way down though, that is a 11-12t otherwise heat will come into play. Should rip though with that kind of RPM.
8ight-e is offline
Old 03-27-2012, 05:02 AM
  #31762
vasidudu's Avatar
Hey thx 8ight-e,
So it is ok then with a 13T + fan on motor?
Does that fan actually provide any cooling; it looks very toyish to me.
Thx for the input.
Best,
V
vasidudu is offline
Old 03-27-2012, 06:04 AM
  #31763
rcus3r's Avatar
Hey thx 8ight-e,
Thx for the input.
Best,
V
From my experience, fan will keep the motor ~15F cooler than without. That being said, with Velineon motor (3800 2-pole, I think), it wasn't enough under some applications with 3S battery.
Did you not think the 1415 had enough 'peps' with 3S?
rcus3r is offline
Old 03-27-2012, 06:49 AM
  #31764
vasidudu's Avatar
Actually that is where I am wondering...
Should I keep running on 2s with 1410 or do I make the move to 3s with my 1415...???
I just want to make sure that if I go the 3s way I will be able to run it on both my 1410 and 1415.
Best,
V
vasidudu is offline
Old 03-27-2012, 06:56 AM
  #31765
8ight-e's Avatar
Best,
V
it's not about the voltage, it's about the work...
if you gear the 1410 for nearly the same MPH on 2s as 3s you won't generate more heat at the motor. It will work just fine.
That said the 1415 2400 is really designed for 3s use, so it will be a monster on 3s vs 2s. This is a bigger motor now on the correct voltage, you can gear for even more top speed with no ill effect vs the smaller 3800.
A fan may buy you 1t on either voltage, past it's normal operating max with out the fan in the given application.
8ight-e is offline
Old 03-27-2012, 07:07 AM
  #31766
Panda-PR's Avatar
Maybe its just me but I preffer a heatsink. No worries about current or getting disconnected. I use them with Artic Silver 5 to transfer the heat.
Panda-PR is offline
Old 03-27-2012, 07:27 AM
  #31767
vasidudu's Avatar
Thx for the input...
Though if we relate to Kv and cells:
1410 on 2s = 28120 RPM
1415 on 3s = 26640 RPM
Will the 1415 have more top end on 3s than 1410 on 2s?
Sorry for debating around this; I am just not used to dealing with current, Kvs etc...
Thx for the valuable info.
Best,
V
vasidudu is offline
Old 03-27-2012, 07:38 AM
  #31768
"Smiley"'s Avatar
Trader Rating: 171 (97%+)
Another win for the SCTE. Won the Pro 4 class at the Dialed Inc race this past weekend in Louisiana. The truck was dialed with my BCE Chassis.
"Smiley" is offline
Old 03-27-2012, 08:12 AM
  #31769
8ight-e's Avatar
Best,
V
Short answer YES, the 1415 is basically a 4-pole 550 capable of more output than the smaller 1410 540 4-pole. On 3s voltage the 1415 can be geared up to exceed the top end of the 3800 easily and do it in proper temp with no fan. Now with 2s setups the 1410 has higher rpm's (higher kv) and can be geared properly so it is a better choice in this application. As many found out on low voltage the 1415 was limited by the motor mount to how high you can gear it so it seemed like a dog w/ the lower rpm and inability to gear it up to make up the ground. With a 3s config again the gearing falls into line (normal sizes) and you can really make the 1415 shine to it's full potential.
8ight-e is offline
Old 03-27-2012, 09:01 AM
  #31770
.AJ.'s Avatar
Ive just fitted the HA servo saver tube to my rig, have i noticed any difference???? Not in the slightest lol
.AJ. is offline
