Like Tree9Likes
Old 03-21-2012, 02:13 PM
  #31516
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Screw that. Break out the pitchforks and torches.
Originally Posted by Oasis
Ryan..I know Mo and I was just givin him a hard time..sorry guys just havin some fun..
ChrisAttebery is offline
Old 03-21-2012, 03:34 PM
  #31517
wcrase101's Avatar
get a rope!!!!!!!
wcrase101 is offline
Old 03-21-2012, 03:38 PM
  #31518
HighLife420's Avatar
Trader Rating: 49 (100%+)
Originally Posted by rcgod
Try 2.5 first. You'll be surprised at how much difference it will make. Also running rear shocks all the way out on arms helps.
Thanks, will i have to change oil piston to run the shocks all the way out? Will try 2.5 also.
Originally Posted by SEF
Assuming you are talking about the nano-tech 6000mah, I can race an 8 minute main all out on a large outdoor track. I dump just before 10 minutes. I'll have to check how much I put back in when recharging. Not sure on weight, but my only upgrades are a Bump chassis and TLR tuning kit. I run an RX8 and 4600.
Also, try less droop up front to get more on power steering.
I will give that a try, i have a even amount of droop on each side, ill just add more droop to the back.
HighLife420 is offline
Old 03-21-2012, 04:14 PM
  #31519
Trader Rating: 128 (100%+)
with all the talk about the chassis, does anyone here run the Jammin?
Neesh is offline
Old 03-21-2012, 04:17 PM
  #31520
Default gearbox grease?
Just started a full rebuild in anticipation of my new chassis that does not look like a soft taco shell. How much and what type of grease goes on the helical (I think that's what they are called) gears on the outside of the front and rear diffs? The insides of both gearboxes are pretty full of the stuff upon initial post-factory teardown. Thanks,
riverdog is offline
Old 03-21-2012, 04:19 PM
  #31521
Two guys at my local track run the Jammin. One of them is always in the top 3. I just ordered the BCE because is was available and really shiny.
riverdog is offline
Old 03-21-2012, 04:22 PM
  #31522
thanks for the quick response! I may bite the bullet on this...still debating if I should wait for the Kingheadz one instead.
Neesh is offline
Old 03-21-2012, 04:25 PM
  #31523
Default Motor maintenance
One more question as I work through my rebuild...What should I do to my pro4 to keep it running well? I assume I should use motor cleaner, lube the bearings, and give it a good inspection. Anything else?
riverdog is offline
Old 03-21-2012, 04:27 PM
  #31524
Trader Rating: 19 (100%+)
I put a light kote .of mugen super grease on the big gear with a toothpick I love my Jammin chassis.
pooldoc is offline
Old 03-21-2012, 04:37 PM
  #31525
wfdfiremedic's Avatar
So what is the deal with the losi 4 pole 550 motor? Any good on 2s? Is it too slow for 2s and what temps are people getting?
wfdfiremedic is offline
Old 03-21-2012, 04:46 PM
  #31526
larlev's Avatar
They do look good if you polish the bottom. They come pretty dull in the plastic.
larlev is offline
Old 03-21-2012, 04:55 PM
  #31527
larlev's Avatar
Originally Posted by Feint Motion
Translated-
"don't talk about products other than ours"
Ah come one now...
Chassis'........... You'd think we were talking about each other's wives or GF's as heated as it gets.
larlev is offline
Old 03-21-2012, 05:06 PM
  #31528
Kevin_M's Avatar
Originally Posted by mo
I believe the current BCE chassis comes with holes for both braces. I run only the stock scte braces. As Chris was saying, it is stiff enough so no need to buy the other braces.
Thanks alot guys
Kevin_M is offline
Old 03-21-2012, 05:09 PM
  #31529
Registered User
Trader Rating: 25 (100%+)
Got one w/free screws set.
RustyRC is offline
Old 03-21-2012, 05:10 PM
  #31530
Kevin_M's Avatar
Hey MOTOGOD Scott did you buy the Tekin Pro 4 yet or you still running the castle?
Kevin_M is offline
