Like Tree9Likes
Old 03-20-2012, 07:40 AM
  #31426
8ight-e's Avatar
Trader Rating: 58 (100%+)
Originally Posted by Kevin_M
Im going to start racing my scte this year and was wondering what battery size will help me race 8-10 min with stock chassis? I just havent bought any upgrades as of yet but will in future.
I have the tekin pro 4 4600 and the hobbywing esc.
I'd get a 6500mAH 2s pack, 40c or better.
Be careful with the 4600 pro4 according to these guys there is an epademic of bearing failures... you HAVE to run with an extra bearing to work properly. Ask RC*PHREAK he'll back me up on that..
umm ya no worries on the pro4, i'm just being wise.
8ight-e is offline
Old 03-20-2012, 07:42 AM
  #31427
chucko's Avatar
If you want to go 10 min for a amain then a 6200 or bigger mah bat is what you want. I run a 6600 70 C and it gets me 12 min of racing. it sucks not to be able to finish a race
chucko is offline
Old 03-20-2012, 07:47 AM
  #31428
Kevin_M's Avatar
Thanks Chuck Ill have to shop for those size batts. My LHS has a bunch of 5000mah but i keep asking for 6000+mah
Kevin_M is offline
Old 03-20-2012, 08:29 AM
  #31429
Jake C6R's Avatar
Originally Posted by ChefDementia
1. Which motor mount are you using?
2. Why are sealed 5x11x3 bearings so hard to come by? I can find plenty of unsealed, or ones with a seal on one side.
I was just looking at these, Boca Bearing has the sealed stainless version for $6.95 each. Also some with ceramic innards for $13.95. It looks like the rubber sealed ceramics are $15.95. Were you just looking for the rubber sealed bearings?
Jake C6R is offline
Old 03-20-2012, 08:38 AM
  #31430
Originally Posted by Outtacontrol58
Is there going to be a tlr kit version of this truck by any chance? Sort of waiting about pulling the trigger. Thanks and any info would be great!
Maybe someday, but if it does come out, it will be a while. I dont feel its worth waiting for with the roller still available.
hacker07 is offline
Old 03-20-2012, 08:39 AM
  #31431
Casper's Avatar
Trader Rating: 34 (100%+)
I have been running a pro4 4600 since before they were available. No bearing failures. I am not saying it won't happen but I would not shy away from the motor based on the failure of a few. this is by far the most popular motor for this truck to date.
Casper is offline
Old 03-20-2012, 09:33 AM
  #31432
Have there been any updates to this truck in the last 6 months?
Ben Burtle is offline
  #31433
That motor is a amazing.
Old 03-20-2012, 09:35 AM
  #31434
The rollers and RTR's that are out for sale are the most up to date at this time.
hacker07 is offline
Old 03-20-2012, 09:40 AM
  #31435
Casper's Avatar
Like running changes or new upgrade parts?
Casper is offline
Old 03-20-2012, 09:41 AM
  #31436
Ryan, I should have been more informative. The reason I ask is because mine has been in storage for 6 months or so.
I am mainly curious about the diffs. I'm considering machining some inserts for them and having them hardcoated with some other components I'm doing on other projects. Unsure if that is the right approach right now. Especially if there is no more wear issues.
It's a great little truck you guys put out. Very fun!
  #31437
Mainly running changes.
Old 03-20-2012, 09:42 AM
  #31438
Trader Rating: 30 (100%+)
Whats the difference in these ESC's? I am looking at a Tekin 4600 Pro4 and wonder what are the advantages from either ESC?
https://www.ssl-stormerhobbies.com/c...=ns&pn=CRC7015
https://www.ssl-stormerhobbies.com/c...=ns&pn=CRC7003
Jay13 is offline
Old 03-20-2012, 09:45 AM
  #31439
Casper's Avatar
Other then the new diff gears being available now nothing new related to the diffs in the past 6 months.
Casper is offline
Old 03-20-2012, 09:57 AM
  #31440
ScottKelly911's Avatar
The main difference is the SCT Pro is capable of running from 2s to 4s and I don't believe has "Blinky" mode. This one is better if you also have an 1/8th scale car and plan on possibly using it as a back up to use on 4s. The other one the regular 120 amp (The one I use) is only 2 to 3s capable. But on these trucks, nobody runs them on anything more than 3s so it's right at home on the SCTE. I also run 1/10th scale buggy, so the optional "Blinky" mode is great in case I need to pull it out and run it as a back up esc in my 22 which I run in Stock 17.5 No Timing class, so I need the "Blinky" option. I hope that helps you decide which is better for your needs.
ScottKelly911 is offline
