Like Tree9Likes
Old 03-19-2012, 01:08 PM
  #31381
BDRMBULLY's Avatar
Trader Rating: 39 (100%+)
Originally Posted by elex300 View Post
It's not free floating,it actually fits inside the motor mount. It reduces the load by 50% if I understand correctly.
I think he means the way the elite motor mount is, but i think someone maybe chris came up with the size bearing that can be installed on the stock mount and do the same job as the elite mount is.
BDRMBULLY is offline
Old 03-19-2012, 01:33 PM
  #31382
SEF
SEF's Avatar
Originally Posted by 8ight-e View Post
To each his own.. it is far from needed, you won't gain a second of lap time and I highly doubt wear on the motor bearing will change for lifespan. The motor bearing is chosen and designed to run with out it. That said if you are bored and want to blow some time, from what Chris and other stated it doesn't hurt it either.
I'd say be careful, if that bearing isn't sealed or doesn't flow as smoothly as the stock it will create additional drag. Low quality bearings = bad idea. Full rubber bearings while useful to keep dirt out, will not be as smooth as the stock bearing = bad. The only plus would be if you know you're hitting the track on a muddy day and want to keep some debris out of the stock motor bearing, maybe throw it in for that day.. I wouldn't run it all the time this way unless they again are as good if not a superior bearing to the stock.
That's the assumption in question here. I'm not sure what type of analysis Tekin did when they spec'd that bearing, or how much side load that bearing can handle.
But I have seen more than enough reports of the pinion side bearing failing rendering a toasted Pro4.
BTW, the Pro4 bearings are rated as ABEC 5 bearings. Use a metal shielded ABEC 5 bearing, and it seems like a not so bad idea.
SEF is offline
Old 03-19-2012, 01:36 PM
  #31383
J. Schwarz's Avatar
Trader Rating: 51 (100%+)
Keep an eye out later...going to have to respectfully exit the sport...yet again. (Child number 3 due in the next week or so)
SCTE w/ KHZ chassis (super low use)
RX8 w/ Pro4 4600
KO RSX Response HardCase
Transponder
couple NanoTech 6K's
Tires....spares...tons of them are all going on the block this evening..
Photos will be posted in the F/S thread...
gonna keep painting.....just cannot be away for all day races...
J. Schwarz is offline
Old 03-19-2012, 02:01 PM
  #31384
TLR KIT IS IN STOCK AT A MAIN NOW just throwing it out there
rrussell is offline
Old 03-19-2012, 02:18 PM
  #31385
Moogumby's Avatar
Trader Rating: 32 (100%+)
Sorry but im jumping in the middle of a convo and not finding the start of it..
what going on with putting a bearing in the motor mount?
Moogumby is offline
Old 03-19-2012, 02:35 PM
  #31386
SEF
SEF's Avatar
There's been some Pro4 bearing failures. I believe Chris A. had his Pro4 fail on him because the pinion side bearing failed. He figured out a 5x11x4 bearing fits in the motor mount and will help provide more support.
Pros: More support for the motor bearing.
Cons: If a poorly rated bearing is used, or a blown bearing is used, it may hinder performance more than help. And you are also counting on the motor mount tolerances to be relatively tight. Having a shaft ride on 3 separated bearings requires pretty tight tolerances. Even a small misalignment can hinder motor performance. So you want the centerline of all 3 bearings to be very close to co-linear, and you want the motor mount bearing to fit snug in the motor mount so that it actually works.
SEF is offline
Old 03-19-2012, 02:49 PM
  #31387
Dano628's Avatar
Excellent explanation much better then I could done .
Dano628 is offline
Old 03-19-2012, 03:04 PM
  #31388
Trader Rating: 19 (100%+)
You would think if they got TLR kits they would get hd outdrives, but still on b/order, anyone know where to get it? Thanks in advance.
pooldoc is offline
Old 03-19-2012, 03:22 PM
  #31389
We got a bunch in two weeks ago and they were ordered up as fast or faster than we got them. There are over 1500 sets coming in this week.
hacker07 is offline
Old 03-19-2012, 03:32 PM
  #31390
Kewl thanks Ryan
pooldoc is offline
Old 03-19-2012, 03:37 PM
  #31391
8ight-e's Avatar
Trader Rating: 58 (100%+)
Great recap..
I'd love to know how many pro4 failures there have been; for those that failed under what conditions ;P One of those posts made it sound like there was an epademic, and I've never heard of one. Typically I find if the bearings are kept up and the gear mesh is correct, you will get more than a year easily. I've only played w/ my 4600, so I can't speak to the long term quality, but my primary motor is the castle 3800 (at least till the 1/8 scale track opens), and those babies are tough as nails.
8ight-e is offline
Old 03-19-2012, 03:50 PM
  #31392
Trader Rating: 21 (100%+)
Anyone know of any online hobby shops with the SCTE Roller in stock?
REVX is offline
Old 03-19-2012, 04:01 PM
  #31393
Great recap..
I haven't heard of any bearing failures on the Pro 4's at the tracks I run on. I did change mine out after 6 months of racing and could not tell the difference in shaft movement. The old ones were fine but since I was tearing the motor down for cleaning I thought for sure I would have to replace the bearings, boy was I wrong.
As far running that 3rd bearing I tend to disagree with the idea. You are basically relying on oval head screws to maintain alignment for the 3rd bearing and that is a poor idea. Oval headed screws shouldn't be used for machine type tolerances.
I think there are other issues if people are blowing out their motor bearings, like what has been said before, gear mesh being the biggest factor.
Just my $.02, to each his own.
Race-on!
Keith
Old VW racer is offline
Old 03-19-2012, 04:17 PM
  #31394
Trader Rating: 90 (100%+)
Does anyone know the legality of running 1/8th big bore shocks on the scte or any sct at roar events? Big discussion on another regional forum, someone thinks they are illegal and a big advantage over the stocker's.
b121774 is offline
Old 03-19-2012, 04:30 PM
  #31395
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
I can tell you that in my case there wasn't a problem with gear mesh, at least not until the bearing blew. Then there was a 1/8" gap. I did hear a clicking noise just before it let go. I thought that I had chipped a ring gear then the truck just stopped.
I also agree that the motor mount is not designed optimally to hold the bearings in alignment, but I'd rather have the extra bearing than run without it. It costs very little and creates almost zero extra load on the motor. I checked the motor's temp every couple minutes for a run to make sure that the bearing wasn't adding any additional load. So far it seems fine.
It could have just been a bad batch of bearings, but there were several reports of them failing in the Pro4 thread. It does happen to even the biggest names in the hobby once in a while. The only way to tell is to wait and see. Tekin has been very good about getting them fixed. I had my replacement parts in 2-3 days.
Chris
Race-on!
Keith
ChrisAttebery is offline
