Like Tree9Likes
Old 03-18-2012, 08:53 PM
  #31351
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by gawith0413 View Post
Where can I find a 5mm/11mm/3mm sealed bearing?
gawith0413 is offline
Old 03-18-2012, 09:02 PM
  #31352
wcrase101's Avatar
avid should have every bearing you will need
wcrase101 is offline
  #31353
Jake C6R's Avatar
Originally Posted by zzztech View Post
Hi
On my TLR upgrade kit, the aluminum shock collars and shock caps are both too tight to be threaded on!??!?
Did anyone else have the same problems? What should I do???
Thx!
I just did this upgrade with no issues. So you could get the plastic caps and collar off but can't get the aluminum ones on? The threads are pretty fine, did you try turning them backwards first to get them threaded correctly? Maybe add some oil to get them started easier?
Jake C6R is offline
Old 03-18-2012, 09:39 PM
  #31354
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 105 (100%+)
Hi
Thx!
Get the HA shock bodies and they go on nice and smooth! Don't bother putting them on the blue stock shocks, you will end up mangling them and being pissed... Trust me! It will look better with the HA bodies also!
thecman26 is offline
Old 03-18-2012, 09:41 PM
  #31355
thecman26's Avatar
I did all of that with mine! Nothing helpes, even vise grips, but that just tore the collars up, got the Hard Annodized shock bodies and they went on like they were made to! Now I get to buy new collars someday cause these look like crap now!
Old 03-18-2012, 09:54 PM
  #31356
thecman26's Avatar
Originally Posted by xxxtruck View Post
has anybody bought the tekno stuff I keep braking the center front drive shaft. Three races is all I`am gettting
Your actually breaking the shaft? Yeah I've never heard of anybody doing that.. Ya running 4S on it? Then maybe then I would say that would be vaguely possible.. Otherwise I would check your bearings, something has to be causing the issue! I've had mine for almost a year, never broke that! I did break my first universal pin this weekend... but those are pretty tiny if ya think about it and VERY easy to replace!
Old 03-19-2012, 01:24 AM
  #31357
ScottKelly911's Avatar
Originally Posted by Dano628 View Post
Even though my SCTE is fully loaded ( tuned flex , tuning kit ,HA shock bodies , torque rod , etc ) if you are not competitive with a stock one you won't be with a hopped up one . Drive it stock and get hop ups as you can the truck works great . As far as AE offering a FT kit they had to the original one needed all sorts of modifications ( I have one that I have a lot more money in then my SCTE and a stock Losi is still easier to drive fast ) enjoy your truck .
^ Best advice! You can spend a ton of money on these trucks (I have) but the truth is, they're so good out of the box that you don't need to. The tuning kit is a great start though because you get a lot of upgrades for a fraction of the cost if you bought them seperately.
no I,m in the top three in 4wd sct. I keep snapping the pin on accelartion.
Ok, so it sounds like you're NOT breaking the center drive shaft, just the pin. But when you break the pin, you end up buying the entire new shaft. I've broken the pin a lot of times. What's happening is they start to wear through the plastic sleeve and then pop out. When they're partially out, they hit and break, sometimes they just fly out completely before they ever break. But now you can get Pin Keepers like these ones from King Headz, the sleeve is metal so they don't wear through them. http://www.amainhobbies.com/product_...n-Keeper-Set-2 An alternative to that, is the new Losi ones that use a set screw to hold the pin in. That's a great choice too, but I don't have the part number for you. Hopefully someone like Hacker can give it to you.
ScottKelly911 is offline
Old 03-19-2012, 02:35 AM
  #31358
Trader Rating: 20 (100%+)
yes that is what I was trying to say. not the drive shaft it shelf but the little pin that runs though dog bone and coupler.
xxxtruck is offline
Old 03-19-2012, 03:42 AM
  #31359
New pins have the same part number as the old ones, LOSB3556
Lomb4rd is offline
Old 03-19-2012, 04:48 AM
  #31360
Dos Andos's Avatar
Trader Rating: 32 (100%+)
Save your money on hopups.... " TIRES WIN RACES!"
Dos Andos is offline
Old 03-19-2012, 05:02 AM
  #31361
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
Hi
Thx!
I just got my TLR kit last week and I thought I was going to have that problem after reading about other peoples issues with them, but to my surprise the collars and caps went on easy also the bearings in the hubs went in easy!
maybe they changed up the molds or something in the new tuning kits IDK.
MOE is offline
Old 03-19-2012, 05:57 AM
  #31362
scracer68's Avatar
Originally Posted by SEF View Post
I've been running on a large 1/8 track (Revelation Raceway) with large jumps.
I run carbon towers, and the rear tower has visible cracks forming.
The rear aluminum towers always bent around the gearbox. But now I am having issues with the carbon towers. Anyone else that runs on large tracks having this problem?
Just thinking about replacing it since it has lasted a while, and there's not too many other options that are stronger.
A cheap fix for this would be to quit landing upside down.
scracer68 is offline
Old 03-19-2012, 05:58 AM
  #31363
gawith0413's Avatar
NOPE, it is an unusually size bearing for the motor mount!
Old 03-19-2012, 07:08 AM
  #31364
gawith0413's Avatar
What is the difference in using the inside hole on the tlr servo horn, to the outside hole?
Old 03-19-2012, 07:14 AM
  #31365
ChefDementia's Avatar
Trader Rating: 19 (100%+)
1. Which motor mount are you using?
2. Why are sealed 5x11x3 bearings so hard to come by? I can find plenty of unsealed, or ones with a seal on one side.
ChefDementia is offline
