Like Tree9Likes
Old 03-18-2012, 04:57 PM
  #31336
Originally Posted by 05PSD
Just watched the SCTE dominate round 1 of the Scotty Ernst Short Course Showdown. Root and Castallano kicked some serious tail against what I consider the two really great AE drivers (Micheal Shoettler and Scott Brown).
Its nice to see Frank and Matt do well, they are both really good guys. And I know Michael and Scott are fast, especially with SCT's...Way to go TLR
hacker07 is offline
Old 03-18-2012, 05:39 PM
  #31337
Trader Rating: 20 (100%+)
has anybody bought the tekno stuff I keep braking the center front drive shaft. Three races is all I`am gettting
xxxtruck is offline
Old 03-18-2012, 06:14 PM
  #31338
lbckevin's Avatar
Trader Rating: 107 (99%+)
never broke that....you must be lawn darting ...
lbckevin is online now
Old 03-18-2012, 06:15 PM
  #31339
8ight-e's Avatar
Trader Rating: 58 (100%+)
You typically wear the small pin on the front shaft before you have any other issues.. as noted you must be doing some serious crashing or have a messed up chassis or bad bearing set on the diff pinion.
8ight-e is offline
Old 03-18-2012, 06:37 PM
  #31340
no I,m in the top three in 4wd sct. I keep snapping the pin on accelartion.
xxxtruck is offline
Old 03-18-2012, 06:41 PM
  #31341
lbckevin's Avatar
are you running 2s and which motor...? How are your outdrives, any grooves in them...Are they the HD version...?
I have not snapped a pin, wore through one in over 10 months...
Old 03-18-2012, 07:08 PM
  #31342
8ight-e's Avatar
I replaced my pins long ago with a hardened shaft from an old bit driver.. just use a dremel to cut it to size. You can make several from one shaft.. sorry forget what size driver it was, just compare till you find one
8ight-e is offline
Old 03-18-2012, 07:10 PM
  #31343
wcrase101's Avatar
I used some harden pins that were 2x11mm, can't remember what brand
wcrase101 is offline
Old 03-18-2012, 07:55 PM
  #31344
johnson19's Avatar
Default SCTE Motor advice
I know this has been stated before somewhere in the 2090 pages but I'll ask again for the heck of it.
Purchasing a RX8 for my SCTE. I will be running indoor and some larger outdoor tracks. I am totally new the the SC4x4 scene.
I want to purchase either the Pro4 4000kv or 4600kv.
What is the pros and cons. What I get so far is get the 4600kv and turn down your EPA on smaller tracks. What effect will one motor have over the other for run time, heat etc?
Any advice is appreciated.
johnson19 is offline
Old 03-18-2012, 08:04 PM
  #31345
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
Default tlr carbon tower
I've been running on a large 1/8 track (Revelation Raceway) with large jumps.
I run carbon towers, and the rear tower has visible cracks forming.
The rear aluminum towers always bent around the gearbox. But now I am having issues with the carbon towers. Anyone else that runs on large tracks having this problem?
Just thinking about replacing it since it has lasted a while, and there's not too many other options that are stronger.
SEF is offline
Old 03-18-2012, 08:16 PM
  #31346
Default TLR upgrade kit
Hi
On my TLR upgrade kit, the aluminum shock collars and shock caps are both too tight to be threaded on!??!?
Did anyone else have the same problems? What should I do???
Thx!
zzztech is offline
Old 03-18-2012, 08:53 PM
  #31347
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by gawith0413
Where can I find a 5mm/11mm/3mm sealed bearing?
gawith0413 is offline
Old 03-18-2012, 09:02 PM
  #31348
wcrase101's Avatar
avid should have every bearing you will need
  #31349
Jake C6R's Avatar
Originally Posted by zzztech
Hi
Thx!
I just did this upgrade with no issues. So you could get the plastic caps and collar off but can't get the aluminum ones on? The threads are pretty fine, did you try turning them backwards first to get them threaded correctly? Maybe add some oil to get them started easier?
Jake C6R is offline
Old 03-18-2012, 09:39 PM
  #31350
R/C Tech Elite Member
thecman26's Avatar
Trader Rating: 112 (100%+)
Hi
Thx!
Get the HA shock bodies and they go on nice and smooth! Don't bother putting them on the blue stock shocks, you will end up mangling them and being pissed... Trust me! It will look better with the HA bodies also!
thecman26 is offline
