Like Tree9Likes
Old 03-16-2012, 10:25 PM
  #31276
omenwolf's Avatar
Trader Rating: 37 (100%+)
so the ne HA steering tube(TLR4004) showed up today so i threw it in when i got home. And im glad I did, when i took out the old one besides being grimy as hell I noticed how grooved out it was. I put a little loctite on the saver collar because they like to back down and yer servo saver gets too loose.
omenwolf is offline
Old 03-16-2012, 11:15 PM
  #31277
gawith0413's Avatar
Trader Rating: 86 (100%+)
For those of you running the bump chassis how do you position the battery in the tray? Front, middle, or rear.
gawith0413 is offline
Old 03-17-2012, 01:24 AM
  #31278
elex300's Avatar
Trader Rating: 110 (100%+)
How much did it help with slop.
elex300 is offline
Old 03-17-2012, 01:49 AM
  #31279
omenwolf's Avatar
it helped a little the spots where the bearings went in were alot tighther than before.
omenwolf is offline
Old 03-17-2012, 02:28 AM
  #31280
vasidudu's Avatar
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-01-old-body.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-02-outerwear.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-03-bumper.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-04-outdrive.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-05-strc-diff-central.jpg
vasidudu is offline
Old 03-17-2012, 02:29 AM
  #31281
vasidudu's Avatar
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-06-kingheadz-arbre.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-07-snr-front-top-plate.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-08-snr-center-top-plate.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-09-jamin-hex.jpg
Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-10-new-body.jpg
vasidudu is offline
Old 03-17-2012, 02:30 AM
  #31282
Mr.juarez's Avatar
Does the steering rack still have that slop up and down?
Mr.juarez is offline
Old 03-17-2012, 05:02 AM
  #31283
gawith0413's Avatar
Old 03-17-2012, 05:35 AM
  #31284
.AJ.'s Avatar
what are the pros and cons of doing the emulsion shock mod?????
.AJ. is offline
Old 03-17-2012, 05:41 AM
  #31285
.AJ.'s Avatar
And when doing this should there be any rebound in the shocks??
.AJ. is offline
Old 03-17-2012, 05:50 AM
  #31286
wcrase101's Avatar
I liked it, seems to settle down the truck faster off of bumps, no rebound.
wcrase101 is offline
Old 03-17-2012, 05:53 AM
  #31287
wcrase101's Avatar
I'm starting in the middle, if I end up needing more steering, I will move it up, if I need less I'll move it back, any other perment changes will depend on when I get it to some scales
Old 03-17-2012, 05:57 AM
  #31288
scracer68's Avatar
I run mine all the way to the rear.
scracer68 is offline
Old 03-17-2012, 06:04 AM
  #31289
BFoley's Avatar
Without going to look at it. I run the battery in the tray, in the box stock position. Jumps and handles great. The chassis does move the box back half an inch.
BFoley is offline
Old 03-17-2012, 08:48 AM
  #31290
Jake C6R's Avatar
Default A Couple of Questions...
A couple of questions for you experts...
For any of you running the Hitec 7955TG, did you use the rubber grommets on the mounting tabs? The reason I ask is the make the steering angle a bit more steep than without them.
Also, maybe a dumb question - what are the transparent green tinted plastic pieces that come in their own bag? Two are sort of triangular and they have mounting holes in them and the other two are sort of rectangular and also have mounting holes...
Thanks!
Jake C6R is offline
