Like Tree9Likes
Old 03-11-2011, 07:56 PM
  #3091
FangsCPO's Avatar
Originally Posted by hacker07 View Post
I am not sure how your front diff has died. Even with the bad pins, the front diff takes much less load and should still last for months. Usually its the rear and then the center. And in one pack...wow. We will be replacing the diff pins as they are not to spec. The outdrives do wear. They are to spec at this time and when they do, they do not drastically affect performance. If you are looking for the ultimate in performace, then you will want to try out the HD lightened outdrives.
What is the part number for the HD lightened outdrives?? Is it # LOSA3554Also, I noticed that the center diffs out drives wobble, is that normal? I know my center diff's outdrives on my Losi 8 buggy don't wobble. Is that part of the pin issue as well??
FangsCPO is offline
Old 03-11-2011, 08:01 PM
  #3092
FangsCPO's Avatar
I've got a few extra pins from my Losi 8 buggy and other rigs, I wonder if this will work in this application. I may have to check. If anyone knows, please chime in. Thanks!
FangsCPO is offline
Old 03-11-2011, 08:26 PM
  #3093
colter's Avatar
Trader Rating: 22 (100%+)
Thought I had dodged the pins issue, but guess not. They looked good when I opened them up this week and cleaned grease out and put 5-3-3 in. Ran 2 packs tonight and took a look at the center diff the pins are showing pretty good wear. Went ahead and put 7k in the center diff hoping that this will help me slow down the wear until the new pins are available. I appreciate Ryan and everybody else working towards getting these couple of things fixed ASAP. Registered on the Losi website and guess I'll be calling Monday morning to request new pins.
On the bright side, the truck was really nice on 5-3-3 and AKA wishbones. Truck was planted. Like the Losi guys said, seems to keep the rear end of the truck really in the track for whatever reason. Looking forward to the 7k in the center diff for a little more pop, but not sure how it will change the overall feel of the truck. Will be racing on Sunday so we'll see how it goes.
colter is offline
Old 03-11-2011, 08:27 PM
  #3094
Frank L's Avatar
Trader Rating: 148 (100%+)
Did anyone ever post what aka premoumt rims will fit this truck the slash stuff seems to he the wrong offset. Sc10 maybe?
Frank L is offline
Old 03-11-2011, 08:29 PM
  #3095
Frank L's Avatar
What rim did you use on the wishbones?
Frank L is offline
Old 03-11-2011, 08:43 PM
  #3096
Trader Rating: 28 (100%+)
Default SCTE
Anyone out there running a Tekin RS or RS Pro in one of these? If so, what turn and what tooth pinion? Thanks
T
mxtoeknee is offline
Old 03-11-2011, 08:47 PM
  #3097
Frank L's Avatar
I'm running a mmp and tekin 4.5 550 on 2s. I ran it for 5 mins and it was the 1st time I have ever seen the mmp fan kick on. It's geared with a 14 tooth motor was 125.
Frank L is offline
Old 03-11-2011, 09:00 PM
  #3098
colter's Avatar
I ordered 2 sets of Losi wheels before they got back ordered. Only others that have the right offset are Proline Protrac wheels I think?? You can make others work with modification either on the wheels or fenders I would guess. Hopefully, more Losi wheels will be available in the next few weeks.
colter is offline
Old 03-11-2011, 09:05 PM
  #3099
colter's Avatar
T
Randy from Tekin may chime in here, but I posed the same question and the short answer is the RS is definitely a no and the RS Pro is not really ideal. Go with the RX8 and be done with it. I am glad that I did. Running the RX8 with SC4 5.5T and currently a 16 tooth pinion. Ran 17 tooth last weekend and it was fine, but ambient temps close to 80 degrees today and glad I went to the 16. Need to take all of the timing out and see what that does as I ran a little warmer than expected today. (160-170 on the motor. ESC was cool as a cucumber!! )
colter is offline
Old 03-11-2011, 09:45 PM
  #3100
Default SCTE
Good info thanks
T
Old 03-11-2011, 09:46 PM
  #3101
Not sure what the part # is but the wobble is part of the pin issue. I remember having a intermittent bind. thought it was in the front but it was the gears in the center moving around because of the wear. Rear diff cups seem to be the other thing wearing out. Mine look terrible after only having the truck for a week. I hope they send me some of those too.
SC_RAGE is offline
Old 03-11-2011, 09:50 PM
  #3102
Not to be a mmp hater but it wont last. Salad and I have tried to tell people but nobody listens. We test these things all the time. Out of 5 mmp's 0 survivors on 2s. Also tried the external bec. glitch caps all the so called fixes. Buy an RX8 and do yourself a favor. You can run anything on it. anything. sensored or sensorless. 2s 3s it all works. no need for caps or bec's. And ive never even heard the fan kick on yet. Longer runtimes than the mmp and novak.
SC_RAGE is offline
Old 03-11-2011, 09:53 PM
  #3103
What battery pack you are running with the MMP's?
fireflysti is offline
Old 03-11-2011, 09:57 PM
  #3104
smokinu's Avatar
Trader Rating: 71 (99%+)
frank L dont like Tekin. He hear's about a lot of Failures..
His trusty MMP is the longest one ive seen running.
smokinu is offline
Old 03-11-2011, 09:59 PM
  #3105
Originally Posted by minit76 View Post
I 2nd the outdrives are wear items, but mine has about 45 min run time with the center and rear showing definite notching already. The pins are not wearing but outdrives themselves are. Not like my 8th scale Losi quality at this point on the out drives. This is even on a two cell lipo with a 4.5 motor. Seeing Iím more used to nitro or even 8E running a 2040 on four cell doesnít eat through outdrives this quick.
My diff pins don't look like the ones in the picture yet but are worn down to 2.65- 2.75mm on front, center, and rear. Glad to see Losi is taking care of this problem under a warranty call.
I would also like to see the plastic stepped up to 8th scale Losi grade.
Don't get me wrong it's a nice unit but has a long way to go in the durability department at this point.
It is being taken care of. Why do you think associated pushed their release date back. There were some issues. This was just overlooked, and it really isnt uncommon. Happens to alot of first runs from any company. I think it was a translation problem between hardened and piloshed. I ran my worn pins under a scope and wasnt too impressed with the grade of the pins. We'll have to see how the new ones come out. Might still be making my own. I like overkill especially when it comes to a wearable part.
SC_RAGE is offline
