Like Tree9Likes
Old 03-09-2012, 10:24 AM
  #30841
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Originally Posted by gawith0413 View Post
What is a really good replacement for a Savox 1258tg servo for the scte, comparable specs, price, etc.......?
Spektrum 6040: 0.08 second transit time with 166 oz-in of torque at 6.0V
If you can find them used they should go for around $50
ilanstylz is offline
Old 03-09-2012, 10:30 AM
  #30842
scracer68's Avatar
Originally Posted by theproffesor View Post
I was wondering if anyone out there has used the extreme cf chassis. I bough a used ten scte and the TLR chassis was cracked at one of the gaurd mounting holes. The three chassis I am lookin at are the TLR, Jammin, and Extreme. I am sure the bump or BCE chassis are good, I just dont like the shiny aluminum look. any help would be great
Just an FYI, the Bump chassis is hard anadized like the TLR not shiny aluminum.
scracer68 is offline
Old 03-09-2012, 10:37 AM
  #30843
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
Originally Posted by BashemSmashem View Post
Depends on how you are hitting the face of the jumps , you cant jump a 4x4 like a 2WD because of the added weight and drag of the front driveline . Most of the time you need a little extra throttle to keep the front end up .
Chassis tuning also plays a huge part in how you car will launch off of jumps , I use the battery in the rear posistion and my truck flys nice and level , but my springs and oils have been changed as well .
Every 4x4 I have driven (not tried a SC10 4x4 with the sadle pack setup or the Durango) has been a little nose heavy .
Sc10's jump ass down but I think it's a combination of approach/technique, the center diff that everyone is running (locks the front and rear gearboxes full time instead of the standard slipper setup) and the rear spring rate. I can go level and nose down but not consistently yet.
The Losi's clearly have the advantage there. They can control themselves in the air like a 1/8 scale buggy which is cool.
If budget allows I definitely want to get one of these by mid summer.
I would rather have a truck that jumps nose down and land on the downside consistently and that you can level by giving throttle.
JEFFs SC10 is offline
Old 03-09-2012, 10:43 AM
  #30844
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
From pictures I have seen the SC10 is tail heavy, with around a 45/55 weight distribution. The SCTE balances quite a bit father forward, like 51/49.
ChrisAttebery is offline
Old 03-09-2012, 10:51 AM
  #30845
JEFFs SC10's Avatar
agreed
Old 03-09-2012, 11:17 AM
  #30846
SEF
SEF's Avatar
Trader Rating: 39 (100%+)
When you guys jump, does the truck naturally nose over or do you have to hit the brake to make it come down?
I'd like to get one of these to run on the bigger 1/8 scale kind of tracks.
On an indoor track, the jumps were small enough where if the truck was too nose down, it wasn't too noticeable. But when the jumps where large, there were times when I was getting close to doing front flips.
I found weight distibution made a big difference in how this truck jumped, especially on big jumps. I put the battery in the back most position. I use a Bump chassis. And I still found that the weight was still biased towards the front. I actually added weight to the rear just in front of the rear gearbox and now the weight is almost exactly 50/50 front to back and side to side.
This made the biggest difference for me to have the truck jump more like my 1/8 scale buggies.
SEF is offline
Old 03-09-2012, 11:24 AM
  #30847
Trader Rating: 33 (100%+)
here is a pic of my new body painted by Jschwartz.. think thats his screen name on here.. supa fast turnaround too..
thanks bro.. sorry for the crappy phone pic.. i will post more when the sun is out!! been raining for 2 days here now..
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-scte2.jpg
dgrobe2112 is offline
Old 03-09-2012, 11:34 AM
  #30848
ScottKelly911's Avatar
O-Face!
Originally Posted by symmetricon View Post
HMMMMM, how does titanium wear? I'd just be worried about the pin hole for th cvd wearing out. Looks good though.
My only concern as well. Other than that, less unsprung weight is always a good thing and they sure are purty!
ScottKelly911 is offline
Old 03-09-2012, 11:56 AM
  #30849
gawith0413's Avatar
Trader Rating: 86 (100%+)
But is it power hungry like the Savox?
gawith0413 is offline
Old 03-09-2012, 11:58 AM
  #30850
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
No it's not. I like mine over the savox one I have. I need a big o cap with the savox where as the 6040 does not require one at all.
Mr.juarez is offline
Old 03-09-2012, 12:01 PM
  #30851
happywing's Avatar
Trader Rating: 93 (100%+)
Originally Posted by Cult Racing View Post
Well you must feel cool, because everyone at my track had heating problems with it. I would rather get a novak 4.5 than that tekin motor.
I must have a magic SC4X too. No problems, runs very cool.
happywing is offline
Old 03-09-2012, 12:30 PM
  #30852
BmainStar's Avatar
You or I really want a truck that leaves the jump and flys level then with small brake input drops the nose a bit for the downside landing.Alot of folks talk about having trouble with 4x4 trucks jumping nose down.It is mostly track time with a 4x4 that will fix this,it is all technique and good set up That said out of all the 4x4 I have run this one takes small inputs in the air very much like an 1/8 scale does Cheers!!!!
BmainStar is offline
Old 03-09-2012, 12:31 PM
  #30853
lbckevin's Avatar
Trader Rating: 96 (99%+)
Savox is the OEM manf of the Spektrum servos
lbckevin is offline
Old 03-09-2012, 12:46 PM
  #30854
Chad Smith's Avatar
What body is that?
Chad Smith is offline
Old 03-09-2012, 12:52 PM
  #30855
Cult Racing's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Chad Smith View Post
What body is that?
you should know proline race team lol, its a proline flo-tek
Cult Racing is offline
