Like Tree9Likes
Old 03-09-2012, 06:50 AM
  #30826
Dano628's Avatar
Originally Posted by Cult Racing
Well you must feel cool, because everyone at my track had heating problems with it. I would rather get a novak 4.5 than that tekin motor.
Originally Posted by WORC1
Ditto!
I have both like the Tekin better it doesn't have as much torque on the bottom as the Novak but is smooth easy to drive and fast .
Dano628 is offline
Old 03-09-2012, 06:56 AM
  #30827
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Must have parts?
Hey guys been skimming through all of the pages and whoa..... a lot of info and thanks for that!
I want to know what are the must have parts to have on deck at the track?
Daryl
BlackStarRacing is offline
Old 03-09-2012, 07:47 AM
  #30828
chucko's Avatar
extra tires. ...if you drive big jumps crash a lot maybe. losi cf towers. .. or a manufacturer of your choice. and after you get really good at driving,,,... a good chassis. I like my BCE but there are others out there... your call... shocks. by rcshox valves are working for me. makes the car planted. it really depends how you drive. but out of the box you should be able to last and have a good time
chucko is offline
Old 03-09-2012, 08:41 AM
  #30829
Wow, those are SEXY!
Daryl
Extra parts to have on hand eh...depends on how you drive but...
one extra set of diff parts LOSB3569
center drive line coupler set LOSB3556
ackerman screws LOSB2279
a set of drive shafts LOSB3564
if you are gonna run the plastic hubs, an extra set LOSB2103
extra pinion bearings LOSA6947
These are the things people ask me for the most...
hacker07 is offline
  #30830
theproffesor's Avatar
Trader Rating: 66 (100%+)
Default aftermarket chassis
I was wondering if anyone out there has used the extreme cf chassis. I bough a used ten scte and the TLR chassis was cracked at one of the gaurd mounting holes. The three chassis I am lookin at are the TLR, Jammin, and Extreme. I am sure the bump or BCE chassis are good, I just dont like the shiny aluminum look. any help would be great
theproffesor is offline
Old 03-09-2012, 08:43 AM
  #30831
BDRMBULLY's Avatar
Ive broken several shock bottoms , wouldnt hurt to get them
BDRMBULLY is offline
Old 03-09-2012, 08:48 AM
  #30832
gawith0413's Avatar
Trader Rating: 86 (100%+)
Bump's not shiny, it looks like the TLR, hard anodized.
gawith0413 is offline
Old 03-09-2012, 08:58 AM
  #30833
JEFFs SC10's Avatar
Trader Rating: 15 (100%+)
When you guys jump, does the truck naturally nose over or do you have to hit the brake to make it come down?
I'd like to get one of these to run on the bigger 1/8 scale kind of tracks.
JEFFs SC10 is offline
Old 03-09-2012, 09:21 AM
  #30834
Trader Rating: 33 (100%+)
depends on your driving style and setup..
i drive mine all the way to the jump.. and let off right at the top.. to get the nose down.. this also helps with parachuting effect of the body.
dgrobe2112 is offline
Old 03-09-2012, 09:25 AM
  #30835
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
Depends on how you are hitting the face of the jumps , you cant jump a 4x4 like a 2WD because of the added weight and drag of the front driveline . Most of the time you need a little extra throttle to keep the front end up .
Chassis tuning also plays a huge part in how you car will launch off of jumps , I use the battery in the rear posistion and my truck flys nice and level , but my springs and oils have been changed as well .
Every 4x4 I have driven (not tried a SC10 4x4 with the sadle pack setup or the Durango) has been a little nose heavy .
BashemSmashem is offline
Old 03-09-2012, 10:22 AM
  #30836
gawith0413's Avatar
What is a really good replacement for a Savox 1258tg servo for the scte, comparable specs, price, etc.......?
Old 03-09-2012, 10:24 AM
  #30837
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Spektrum 6040: 0.08 second transit time with 166 oz-in of torque at 6.0V
If you can find them used they should go for around $50
ilanstylz is offline
Old 03-09-2012, 10:30 AM
  #30838
scracer68's Avatar
Just an FYI, the Bump chassis is hard anadized like the TLR not shiny aluminum.
scracer68 is offline
Old 03-09-2012, 10:37 AM
  #30839
JEFFs SC10's Avatar
Sc10's jump ass down but I think it's a combination of approach/technique, the center diff that everyone is running (locks the front and rear gearboxes full time instead of the standard slipper setup) and the rear spring rate. I can go level and nose down but not consistently yet.
The Losi's clearly have the advantage there. They can control themselves in the air like a 1/8 scale buggy which is cool.
If budget allows I definitely want to get one of these by mid summer.
I would rather have a truck that jumps nose down and land on the downside consistently and that you can level by giving throttle.
Old 03-09-2012, 10:43 AM
  #30840
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
From pictures I have seen the SC10 is tail heavy, with around a 45/55 weight distribution. The SCTE balances quite a bit father forward, like 51/49.
ChrisAttebery is offline
