Like Tree9Likes
Old 03-07-2012, 06:46 AM
  #30646
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Ethan5050
Can you guys tell me a good gearing for the pro 4 4600kv? I don't wanna run crazy hot, and I'm on a small outdoor track (Pegasus) thanks...
Oh yeah I'm running an 8th scale t8 right now..
I'm running 1900kv on 4s, would a 2650kv on 3s be a better setup if i stay with 8th scale electronics thanks.
Gear the pro4 at 13t to start out.
gawith0413 is offline
Old 03-07-2012, 09:05 AM
  #30647
Trader Rating: 36 (100%+)
I have a custom project I'm attempting. I've searched TLRs web and AMain and can't find what I'm lookin for. Could one of you measure and post the dimensions of the battery tray? Also, is it secured to chassis with ( what would be SAE comparable ) 3 or 4 mm screws? TIA
NitroOB4You is offline
Old 03-07-2012, 09:09 AM
  #30648
Yes gear at 13t for the 4600 pro4. And turn your limiter to 80 or 90 and turn the timing off. Im running that and im hitting 145-148 in temps.
rrussell is offline
Old 03-07-2012, 09:25 AM
  #30649
Trader Rating: 21 (100%+)
Has anyone tried setting an SCTE up like a lot of the 1/8 scale buggies are going to with the motor in the left front and dual batteries in the rear? I wish the four screws that hold the center diff in were symmetrical so you could just flip it around 180 deg. I set one of my ofna buggies up like this and it made a big difference in handling.
MX304 is offline
Old 03-07-2012, 09:56 AM
  #30650
uWtech14's Avatar
Trader Rating: 18 (100%+)
Just got mine going a couple of weekends agoand straight out of the box its already smooth. Question is what are most important hop up / mods you guys are doing?
uWtech14 is offline
Old 03-07-2012, 11:12 AM
  #30651
Tlr tuning kit is great for the money and ger the hd outdrives
rrussell is offline
Old 03-07-2012, 11:15 AM
  #30652
FLHX1550's Avatar
Don't forget to ask which aftermarket chassis is best
FLHX1550 is offline
Old 03-07-2012, 11:20 AM
  #30653
HighLife420's Avatar
Trader Rating: 49 (100%+)
Hahahahahaha!!!!!
HighLife420 is offline
Old 03-07-2012, 11:25 AM
  #30654
scracer68's Avatar
Bump!
scracer68 is offline
Old 03-07-2012, 11:28 AM
  #30655
gawith0413's Avatar
AWESOME!!!!
TLR and BUMP!!!!
Old 03-07-2012, 11:35 AM
  #30656
Trader Rating: 33 (100%+)
bwahahahah..
dgrobe2112 is offline
  #30657
Trader Rating: 90 (100%+)
LOL, but NO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! (at the same time)
Kuya_Kimo is offline
Old 03-07-2012, 11:42 AM
  #30658
lowroad's Avatar
Trader Rating: 79 (100%+)
Originally Posted by scracer68
Bump!
no.
lowroad is offline
Old 03-07-2012, 11:43 AM
  #30659
Cult Racing's Avatar
Trader Rating: 42 (100%+)
The stock one duh
Cult Racing is offline
Old 03-07-2012, 11:45 AM
  #30660
lowroad's Avatar
Got my spring sets in today. They are better. No rubbing, and although the black fronts most folks are using are nearly the exact same weight as the stock scte springs, they do feel much better. Maybe my stockers were just worn, or maybe these are a better type of spring steel, I don't know, but they definitely compress differently.
A pricey upgrade at $30 for a set of fronts and rears when almost everyone only uses black and orange, but a good leap from the silver rears stock fronts I think. one could probably just get away with the rear set.
p.s. bce is the best, the rest are just ok.
lowroad is offline
