Like Tree9Likes
Old 03-05-2012, 05:26 PM
  #30571
R/C Tech Elite Member
JayL's Avatar
My front KingHeadz coupler: the boot keeps sliding back off of the coupler
Idea's?
I was thinking maybe cut alittle on the small side of the boot so the angled cvd can rotate in the boot better?
JayL is offline
Old 03-05-2012, 05:33 PM
  #30572
MotoGod's Avatar
Trader Rating: 118 (100%+)
Originally Posted by ChrisAttebery
You can adjust it on the RX8 with the Hotwire PC interface.
Ahhh that's what I figured. I run an MMP at the moment.
MotoGod is offline
Old 03-05-2012, 05:41 PM
  #30573
Kevin_M's Avatar
I have Hobbywing 150a ESC but need a BEC to supply power for servo and reciever. Or can buy a SCT PRO.
Kevin_M is offline
Old 03-05-2012, 06:21 PM
  #30574
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Idea's?
I use a small piece of fuel tubing and slide it up to the boot.
KIK is offline
Old 03-05-2012, 06:42 PM
  #30575
Trader Rating: 166 (98%+)
Yes, the copperhead has been working great. I have ran about 10 packs through it with no issues.
Originally Posted by Mr.juarez
So the new copperhead combo are doing fine now? Anyone running the newer versions are any issues? Looking at getting one of these now
jasontraci is offline
Old 03-05-2012, 06:48 PM
  #30576
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
what run time are you getting out of it? im looking for some a little more efficient for the moment
Mr.juarez is offline
Old 03-05-2012, 06:51 PM
  #30577
ilanstylz's Avatar
Trader Rating: 142 (100%+)
Ok everyone I just got my scte in today, running a tekin rx8 and pro4 4000kv motor, what is a good gearing to start out at as well as setup for tight indoor track? Thanks
ilanstylz is offline
Old 03-05-2012, 06:57 PM
  #30578
Cult Racing's Avatar
Trader Rating: 42 (100%+)
14t or 15t pinion
Cult Racing is offline
Old 03-05-2012, 07:05 PM
  #30579
ilanstylz's Avatar
Originally Posted by Cult Racing
14t or 15t pinion
Thanks imma see what is on there now (bought the scte used) as well as check out tekins new esc software......
Old 03-05-2012, 07:07 PM
  #30580
yeah I saw that on fb. What does the new software do?
Old 03-05-2012, 07:08 PM
  #30581
ilanstylz's Avatar
1. Includes Vegas software 223 for RS, RSPro and RX8 esc:
a. Improved throttle performance and feel
b. Improved braking performance and feel
2. Load, Save and Transfer custom ESC profiles
3. Big Event "LockOut" Spec Mode
4. Active Braking adjustment for boosted TC
Old 03-05-2012, 07:53 PM
  #30582
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by gawith0413
Can someone post the part number and size of the screws for the front upper plate that secures the steering rack and attaches to the front bulkhead.
gawith0413 is offline
Old 03-05-2012, 07:57 PM
  #30583
thecman26's Avatar
Trader Rating: 112 (100%+)
Have you looked at the diagram, should be on there???
I just used some screws that fit from my toolbox. That is the racers best friend, a TON of extra screws! $1.99 for a pack of 10 at amain! Great screws!
http://losi.com/ProdInfo/Files/LOSB0...al_English.pdf
page 18, in the diagram: losa6277
thecman26 is offline
Old 03-05-2012, 08:43 PM
  #30584
embryoguy's Avatar
Trader Rating: 15 (100%+)
help please and sorry for the novice question.
i recently changed from stock to tekin 5.5 motor. initially used the stock 18T spur gear and it heated up. than changed to 14T and a lot cooler but it seems i have a lot less power. struggle to clear triple jumps. with stock did it easily.
its nice its sensored so a lot smoother throttle but lost power.
advice? thank you in advance.
embryoguy is offline
Old 03-05-2012, 08:51 PM
  #30585
KingdomRacer's Avatar
That's what I have also, but with the 0 inserts my RPM toe gauge reads 5.5?
RPM Toe Gauge is not a very good tool for toe and is not going to give you good, accurate, easy to read numbers.
On the MMP it is called Punch Control and works kind of like Current Limiting on the RX8 (kind of).
Another feature to try on the MMP is Torque Control.
When I used to run the MMP for racing I would start around 12 for Torque Control and go from there.
There are some who like one feature over the other so play around with them and only you can say what works good for you. But use one or the other because they don't work well together.
KingdomRacer is offline
