Like Tree9Likes
Old 03-05-2012, 10:03 AM
  #30541
gawith0413's Avatar
Trader Rating: 86 (100%+)
Originally Posted by dgrobe2112
are you asking how to get 3* toe.. im sure ryan has the TLR tuning kit.. has adjustablility. i think its the 0 inserts on the rear blocks..
That's what I have also, but with the 0 inserts my RPM toe gauge reads 5.5?
gawith0413 is offline
Old 03-05-2012, 10:06 AM
  #30542
wrightcs77's Avatar
Trader Rating: 551 (100%+)
Hey guys, thought I would post here, sorry for the spam.
Used HA Losi SCTE shock bodies
Front and rear spring tuning kits (1 pr of front and 1 pr rear used, rest are new)
PM me for price.
wrightcs77 is offline
Old 03-05-2012, 10:12 AM
  #30543
gawith0413's Avatar
Ryan, Casper and thoughts?
Old 03-05-2012, 10:20 AM
  #30544
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
The stock suspension holders are at 3 degrees of toe.
Originally Posted by gawith0413
Hey Ryan,
How did you get 3 rear toe on your setup on the losi website for an indoor track?
ChrisAttebery is offline
Old 03-05-2012, 10:24 AM
  #30545
Originally Posted by SC-Racer
Think I am going to try to run a 5.5t 550 Novak instead of my 4.5t 550 Novak to get a long run time. Where should I start on the pinion? This will be running on a large outdoor track. Running the 4.5t on a small indoor track now. The 4.5t is just not going to make a 10 minute main that is required on the outdoor track.
I have one for sale, sent you a pm if you are interested.
Rcnemesis is offline
Old 03-05-2012, 10:26 AM
  #30546
Casper's Avatar
Trader Rating: 34 (100%+)
Yes stock settings are 3 deg of toe and 2 deg of antisquat. This is also what you get if you have the adjustable pivots and install 0's all around.
Casper is offline
Old 03-05-2012, 10:45 AM
  #30547
gawith0413's Avatar
Thanks for your help Casper!
Old 03-05-2012, 10:48 AM
  #30548
Just put tekin pro4 4600 into my rtr. first issue thermal melt down of stock esc. Also 2 buddies put 4000 pro4 in and having same things happen but mine is toasted. I figure ez fix get rx8 problem solved. Nope everywhere is backorder. I have seen on here people talking up the hobbywing esc. Which one is best option, how much they cost, where can i get my hands on one, and what wire do I need to program it?
scoobymx79 is offline
Old 03-05-2012, 11:05 AM
  #30549
BLKNOTCH's Avatar
Wait for Tekin
BLKNOTCH is offline
Old 03-05-2012, 11:16 AM
  #30550
symmetricon's Avatar
Trader Rating: 27 (100%+)
http://www.hobbypartz.com/07e-c-xerun-120a-sd.html
http://www.hobbypartz.com/hobbywing-...ogram-box.html
symmetricon is offline
Old 03-05-2012, 11:24 AM
  #30551
rcgod's Avatar
Trader Rating: 33 (100%+)
HW SCT PRO. Get the programming card too. Look on eBay. Got mine for $90 shipped and have had no issues with it. Runs just as well as the RX8 I had in it before.
rcgod is offline
Old 03-05-2012, 11:31 AM
  #30552
Casper's Avatar
Did you guys change the pinion when you put in the 4600? The stock pinion at 18T is WAY too tall for the 4600. You should be down in the 13-14 tooth range.
The RTR ESC should have handled the 4600 no problem but you had to change the gearing.
Casper is offline
Old 03-05-2012, 11:42 AM
  #30553
8ight-e's Avatar
Trader Rating: 58 (100%+)
I'm also still baffled why so many people actually want the 4600kv, it has no more power/speed than a geared up 4000kv but has WAY less gearing options. It Just doesn't make much sense iMO. The 4000kv will give you the ability to gear properly for smaller or larger tracks, and other than normal batch differences they should run at the exact same temp while pushing the same MPH.
8ight-e is offline
Old 03-05-2012, 11:49 AM
  #30554
Casper's Avatar
Sorry but if both are geared properly the 4600 will out run a 4000 all day long. Now depending on how big your track is and your driving skill the 4000 may produce as good or even better lap times then a 4600 but I don't agree with your statment that the 4600 does not have more power/speed then a 4000. That is like saying my 13.5 will go just as fast as my 7.5
Casper is offline
Old 03-05-2012, 11:56 AM
  #30555
gawith0413's Avatar
Hey Casper or Ryan,
I was just wondering, what have you guys had to tweak on your setups when you use a lighter chassis example the TLR, Bump or BCE chassis'? (if you use one) I know this is a pretty general and open question depending on other factors. I was just wanting to hear your guys thoughts and experiences.
