Like Tree9Likes
Old 03-03-2012, 08:07 PM
  #30436
Steve737's Avatar
As everyone can see from my sig, I've made a switch. Ran the SCTE today for the first time, what a difference! I know that Symmetricon (sp) recently switched over as well, and after today, I don't think I'm looking back. Because it's a RTR (Ready To Rebuild), I changed out the shock oil and diffs. Instead of an hour long diff job, 20 minutes and I was put back together.
Steve737 is offline
Old 03-03-2012, 08:09 PM
  #30437
Mr.juarez's Avatar
Trader Rating: 37 (100%+)
Originally Posted by elex300
Does anyone make an over tray for these? I guess a body for the 8ight buggy would fit,right?
20 dollar losi 810 buggy body beats 45 for an outtawear cover
Mr.juarez is offline
Old 03-03-2012, 10:53 PM
  #30438
1tenner's Avatar
You need to paint that buggy body black or something. That last pic looks kinda creepy...
1tenner is offline
Old 03-03-2012, 11:27 PM
  #30439
Feint Motion's Avatar
Trader Rating: 24 (96%+)
-10000 for Jconcepts
all 4 of my Rulux wheels cracked. Threw off my wheel alignment (
Noticed it after my truck started drifting to the left during qualifying.
Anyone know if jconcepts replaces their faulty wheels? Guess I'm sticking to the stock wheels for now.
Feint Motion is offline
Old 03-03-2012, 11:41 PM
  #30440
Oasis's Avatar
Trader Rating: 38 (100%+)
I haven't had problems..yet..to bad on the cracking of the rims..they fit better than any of the other rims I've tried..This is gluing the tires..
Oasis is offline
Old 03-04-2012, 12:02 AM
  #30441
.AJ.'s Avatar
its still got the nitro holes for the engine and tank tho
.AJ. is offline
Old 03-04-2012, 12:58 AM
  #30442
Mr.juarez's Avatar
It already comes painted that way, I don't care lol
True, but they are small and nothing some mesh can't cover. Even with the holes open it covers a lot and does a great job keeping the mud out. Again better than nothing. The only downside is that it blocks airflow, but this tenshock motor doesn't go over 107 so I don't worry about heat issue.
Old 03-04-2012, 01:05 AM
  #30443
ScottKelly911's Avatar
Originally Posted by BmainStar
It may be the jumps themselves!!Also adjust your rear springs up or down and then re run the same jump to see if that helps!My truck has never jumped nose down,even with two different chassis and so forth.Like Scott said it may just be a practice makes perfect deal,also turn your brake EPA down a bit and it wont be so touchy when you need it. Cheers
Hey Scoot are you at the JBRL at O.C.?
How is the turn out? New job is going well when I get the promised increase $$$$$ I will be able to play more and come race wit ya guys!!Also what tires do you run at ocrc? Thanx Bro ..Ric,
Nope, went to 111 Raceway today to run with a bunch of friends that I hadn't run with in months. They're more of bashers than racers but we had a great time at open practice at 111. But I heard 385 entries today for the JBRL! Yeah man, be glad to have you down at the OC soon! Near the end of the night my truck started nose diving like crazy over this big jump they have right now, couldn't figure out why, pulled my truck off and the two front screws that hold in the front diff and bumper backed out, so everytime I hit the jump, it was scoopin up dirt But for a little track, it's really fun.
Originally Posted by Iron-T
I know that this has probably allready been ansered before, but im runnig a pro4 4600 with a 13 tooth pinion and I came off the track last night at 180 degrees. Is this normal or what is everybody else running for gear.
definitely not normal. Which ESC are you running? Make sure you don't have any timing in it. I'm running a 13 tooth on my 4600 also and I come off the track at about 140-145ish all day. Do as others have said about checking for binding, bearings etc.
Congratulations man, I'm sure you'll like it a lot and there's a lot of really good mods for it out there too. Not that it needs a ton, but it's fun to tinker right?
Not if you don't cut them out
http://www.amainhobbies.com/product_...Stickers-Clear
ScottKelly911 is offline
Old 03-04-2012, 01:23 AM
  #30444
.AJ.'s Avatar
Im going to go for shell over a outerwears, they are well over priced imo
.AJ. is offline
Old 03-04-2012, 03:42 AM
  #30445
Briguy's Avatar
Trader Rating: 125 (100%+)
Have you tried DE Racing wheels ? They seem to hold up pretty good .
Briguy is offline
Old 03-04-2012, 04:28 AM
  #30446
Are many of you running M2C or RC shox pistons in your trucks? If so how do you like them?
plumslow is offline
Old 03-04-2012, 05:40 AM
  #30447
Trader Rating: 23 (100%+)
Yea i have 10 sets of tires w de wheels and no probs w any of them. Runnin them since they came out....wont run anything else
nitro0619 is offline
Old 03-04-2012, 06:12 AM
  #30448
Trader Rating: 166 (98%+)
Jconcepts wheels - Same problem - tried once and had cracked issues, too.
I use the stock wheels.
jasontraci is offline
Old 03-04-2012, 07:38 AM
  #30449
BDRMBULLY's Avatar
Trader Rating: 40 (100%+)
Sc10 4x4 rears are holding up good for me. Black de are pretty good, my white de cracked . Stockers are great too,
BDRMBULLY is offline
Old 03-04-2012, 08:00 AM
  #30450
Default Mud guards
In this thread I've seen some people using the DE mud guards while other use the Jammin mud guards.
Is there a difference between those two or are those guards just mud guards nothing less - nothing more?
boba.slave is offline
