Like Tree9Likes
Old 03-02-2012, 07:29 AM
  #30376
JPG
JPG's Avatar
Originally Posted by elex300
Just to confirm the Losi 22 1mm shock limiting spacers can be used when putting the low friction orings in. You don't have to buy a whole 1/8 shock rebuild kit to get them. Lucky for me I have a 22 and already had both.
Orings
http://www.amainhobbies.com/product_...haft-O-Rings-8
Spacers
http://www.amainhobbies.com/product_...ter-Set-TLR-22
Thanks Eric!
JPG is offline
Old 03-02-2012, 08:28 AM
  #30377
Trader Rating: 23 (100%+)
Originally Posted by JPG
Thanks Eric!
Yea thx for the update. I will give them a try!!
nitro0619 is offline
Old 03-02-2012, 08:53 AM
  #30378
ChrisAttebery's Avatar
Trader Rating: 121 (100%+)
Thanks for verifying this for me. I have a limiter kit on order but had not been able to try them out yet.
Orings
Spacers
ChrisAttebery is offline
Old 03-02-2012, 08:58 AM
  #30379
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Default Update on fluids...
just bought a used SCTE... YEAH YEAH lol
Im going to strip her down and rebuild it checking for unseen problems...My question for you guys is whats the best set up on fluids? (running out door clay)
Diffs - front/center/rear
Shocks - Front/Rear
I know you guys have talked about it but DAMN over 2000 pages.....lol kinda hard to find them...
Thanks for your input - remember by helping we save the sport!
BlackStarRacing is offline
Old 03-02-2012, 09:10 AM
  #30380
gawith0413's Avatar
Trader Rating: 86 (100%+)
Shocks - Front/Rear
I would start with either 7/5/3 or 5/5/3 in the diffs. If it is a big open track I would do 7/5/3. I run #3/27.5 and #4/27.5 in my shocks, but I race on a smooth indoor track. You might check the losi website for setups. Good luck!
gawith0413 is offline
Old 03-02-2012, 09:31 AM
  #30381
Shocks - Front/Rear
Outdoor has so many more variations than indoor. For example, I ran the short course nats in CT last year and ran my normal indoor setup and it worked great. But that isnt always the case.
Does the track get rutted up?
Are there very large 8th scale sized jumps?
etc...
If it gets rutted up, go 5/3/3 on the diffs, it will be easier to drive. If not, go 5/5/3 or if you want it a bit more numb 7/5/3.
If there are large jumps go with 30 or if its hot there go to 32.5 front and rear with 3 in front anf 4 in back for pistons. If its a tenth scale track, then 27.5 should be great.
hacker07 is offline
Old 03-02-2012, 09:34 AM
  #30382
Good look thanks for the insight!
  #30383
etc...
Old 03-02-2012, 10:28 AM
  #30384
Gergely's Avatar
Default 22T shocks on SCTE?
Hello guys,
I am new here. Sorry that I am not going to check back the pervious 2000+ pages but if somebody could help that would be great.
Does the TLR5072 Shock kit 22T Rear and TLR5071 Shock Kit 22T Front fits on SCTE? I love these shocks and I would prefer to use them directly instead of practically changing all SCTE shock spares to optional ones.
Thanks a lot in advance!
Gergely
Gergely is offline
Old 03-02-2012, 10:38 AM
  #30385
Originally Posted by Gergely
Hello guys,
Gergely
They are quite close. I guess you could probably make them work although the body versus shaft stuff is a bit different here and there.
Going by my eye...the 22T rear shock would not have as much up travel but only by about 1.5mm. and the same is true with the fronts. See, the shock caps are taller on the 22 so this makes the body area versus the shaft area a bit different ratio.
Also, if you want to use the SCTE sprins, you have to change the shock bottoms. You also have to drill out the 22 shock bushing to fit the scte.
hacker07 is offline
Old 03-02-2012, 10:45 AM
  #30386
Makarrov's Avatar
After rebuilding my diffs I noticed that they feel "notchy" even after backing the screws out. I seem to remember this being mentioned before but cant remember what the fix was. Did it end up being bad diff cups or just adding another paper gasket to open the gear mesh?
Makarrov is offline
Old 03-02-2012, 10:49 AM
  #30387
Gergely's Avatar
Hello Ryan,
Thank you very much for the quick and useful response!
Many thanks,
Gergely
Gergely is offline
Old 03-02-2012, 11:51 AM
  #30388
Trader Rating: 33 (100%+)
from what i understand, the rules say you cant convert a buggy into a SC truck.. but the new XRAY thing uses 1/8th drive train..
isnt that basically a converted buggy?
dgrobe2112 is offline
Old 03-02-2012, 12:03 PM
  #30389
This happens when the little metal square inserts dont get seated or pushed all the way against the housing and so it pushes the gear forward. Once you run it a pack or two, it should seat itself and be all good. I would nto recommend ever not fully tightening the screws as this seals the diff.
Hello Ryan,
Is the mounting of the 22T shocks are direct (or easy) fit on SCTE?
Many thanks,
Gergely
It will take some manipulation and drilling and mixing of parts, but it could be done. Now if its better, I am not sure other than they are a little lighter. The SCTE shock with all the HA and TiNi stuff are butter smooth built with the stock x ring and all.
I personally do not recommend using a 22 o ring in the scte shock. This is only for the extreme racer, not the everyday user.
hacker07 is offline
Old 03-02-2012, 12:29 PM
  #30390
BmainStar's Avatar
My stock shocks work xxx-Cellant,,,That must mean I am an everyday user
BmainStar is offline
