Like Tree9Likes
Old 02-24-2012, 02:13 AM
  #29896
.AJ.'s Avatar
Originally Posted by Suteki
Just checked them out but they didn't list an international shipping price.
Badhorsie had socks from $10, then it was $30 postage
Thinking maybe the rc-skins rubber socks but I am curious as to whether rubber will bind or eventually stretch.
Send him a msg, hes a member of a forum which im a very active member of in the UK and a hes top bloke, im sure he can sort something out
.AJ. is offline
Old 02-24-2012, 07:39 AM
  #29897
Originally Posted by gawith0413
Hey Ryan or Casper,
Is losi looking to upgrade the front spindles to aluminum?
I have thought about that off and on but there has been very little breakage of the spindles and so it keeps getting put on the back burner as I have a LOT of other things I am working on for the SCTE right now.
Originally Posted by kahuna2793
Anyone run Orion r10 pro in scte if so what motor?
Yeppers, I do and LOVE it. So smooth. I run it with the tekin 4600 right now and have run it with the Orion 4.5 550 as well.
Originally Posted by Kevin_M
Hobbywing ESCs? Anyone using one of these? How will it perform with the Tekin pro 4. Is there a difference between the sct pro and the one for 1/8 cars?
Hobbywing is like the orion r10, they are great esc's.
I would just take the stock ones off and run with out.
hacker07 is offline
Old 02-24-2012, 09:08 AM
  #29898
Got a quick question how have you all mounted the rpm sensor on the scte. I have a new airtronics mt4 that has a the rpm sensor option thanks for the help
neal90 is offline
Old 02-24-2012, 09:16 AM
  #29899
.AJ.'s Avatar
HD out drives now at Amains
.AJ. is offline
Old 02-24-2012, 09:35 AM
  #29900
gawith0413's Avatar
Trader Rating: 86 (100%+)
Not centers though.
gawith0413 is offline
Old 02-24-2012, 09:37 AM
  #29901
gawith0413's Avatar
Where should I mount my transponder on this truck?
Old 02-24-2012, 09:53 AM
  #29902
goehm's Avatar
Trader Rating: 45 (100%+)
I'd mount it in the receiver box if it fits.
goehm is offline
Old 02-24-2012, 10:04 AM
  #29903
The stock MT4 sanwa/airtronics ones requires you put the little sticker (white on black or black on white) on the spur gear and mount the sensor. no thanks... i just forgot bout it. there is the Yeah Racing product, which i bought, but it is a PoC and I dont use it. I just dont use RPM. I do use the temp though. BTW, look at the RX-462. I bought that from a HK site for like $90 something bux and now on my MT-4 I see the voltage of my battery (2S max), and can set a vibrate/audible-tone for when i reach lower voltage so i can pull off. pretty neat. BTW, also the vibrate/EL-backlight for the MT-4 is a nice thing to have ($40 or so online, pretty easy install).
AgroAMG is offline
Old 02-24-2012, 10:10 AM
  #29904
goehm's Avatar
I think there are three Hobbywings that are contenders.
  • Xerun 120A
  • EZrun 120A (SC8)
  • SCTPro
I have the HobbyWing Xerun 120A paired with the Tekin Pro4 (4600) right now and it's great. The conclusion I came to is if you might use the ESC later on in another 1/10, especially if you want to really tweak boost/turbo then the HobbyWing 120a v2.1. If you're looking at the Pro4 motor, then since it's sensored the 120A might also get a nod since it supports sensored motors as well.
If you might use the ESC later on in 1/8 scale, then the HobbyWing EZRun SC8 120A would be a good choice since it supports 3S and 4S batteries.
The SCT Pro looks like the best of both worlds, combining the Xerun tuning and sensored abilities, along with the EZrun's ability to use 3S and 4S.
If I bought again, I'd buy the SCT Pro.
goehm is offline
Old 02-24-2012, 10:18 AM
  #29905
.AJ.'s Avatar
  • Xerun 120A
  • EZrun 120A (SC8)
  • SCTPro
You can add the Xerun 150a to that list as well, i run my Tenshock SC411 and used it with my Tekin SC4X on it as well without issues
.AJ. is offline
Old 02-24-2012, 10:31 AM
  #29906
cavg's Avatar
  • Xerun 120A
  • EZrun 120A (SC8)
  • SCTPro
Actually the SCT Pro share firmware with the Hobbywing 1/8 esc's, alas there are no more tuning abilities than the EZrun. However they are working on firmware that will alow this, soon to be released.
cavg is offline
Old 02-24-2012, 10:47 AM
  #29907
Panda-PR's Avatar
A little irresponsible on my part but lots of fun
Panda-PR is offline
Old 02-24-2012, 11:04 AM
  #29908
Originally Posted by cavg
I run a Tenshock SC411 4600 kv which is also a 4-pole motor like the pro4. This together with a sct pro and they run great together.
Difference is that the 1/8 esc is 2-6s capable, but not recommended with 2s, whereas the sct pro is 2-4s capable and recommended for 2s application. They do however share firmware.
Hey cavg, no temperature issues? That was my only concern with the HW sct-pro. I definitely will be running a sc411 4600kv, but I heard that a HW 150A esc/ sc401(sensorless) 4600kv combo runs hot. BTW, where did you buy the HW SCT-PRO from? And what gearing are you running with that combo?
groundpounder30 is offline
Old 02-24-2012, 11:09 AM
  #29909
wcrase101's Avatar
shoulda rolled your window up, lol
wcrase101 is offline
  #29910
BFoley's Avatar
Not centers though.
Nitro House shows them in stock.
BFoley is offline
